Js99'er
Emulator JavaScript
492 replies to this topic
#451 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 131 posts
Posted Sat Aug 25, 2018 1:41 AM
Hi guys
Does anyone know if there is a precompiled executable binary available of the Angular version that one can use on Windows?
I am struggling to build using Angular and Typescript under Windows, and at this stage my only access to a Linux box is using Windows Subsystem for Linux, and building under there doesn't work.
If there is no executable available, is there anybody that has successfully built in under Windows?
#452 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Sat Aug 25, 2018 7:29 AM
Hi guys
If you just want to use the emulator there's no need to build it. Just go to https://js99er.net
Everything is running in your browser. There are no binaries since JavaScript is an interpreted language.
#453 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 131 posts
Posted Sat Aug 25, 2018 7:53 AM
Asmusr
I want to use it offline.
I do not always have access to the internet, and would like to keep myself busy with playing a bit LOL.
Regards
#454 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Sat Aug 25, 2018 9:46 AM
OK, cool. I will explain how to get the development environment up and running.
I assume you have cloned the git repository to a folder on your computer.
First you need to install Node.js. You can get it here: https://nodejs.org
Then you need to install Angular CLI: npm install -g @angular/cli
Change to the directory containing the source code and install the dependencies by typing: npm install
Now you should be able to run js99er locally by typing: ng serve
Go into a browser and enter the address as: http://localhost:4200
There are tons of other options, but try to get this working first.
#455 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 131 posts
Posted Sat Aug 25, 2018 11:58 AM
Thank you.  Working perfectly
#456 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Sat Aug 25, 2018 1:05 PM
If you now enter "ng build --prod" it will build the optimized version into the dist directory. This is the version I deploy to js99er.net, and it's a lot faster than the dev version you have been running so far.
You need a web server to run this, even locally. You can install a simple one with "npm install -g http-server". To run it from the js99er directory, just type "http-server dist". This will serve the js99er prod version at http://localhost:8080.
#457 TheMole OFFLINE
TheMole
    Dragonstomper
  • 820 posts
Posted Wed Sep 12, 2018 7:19 AM
Small bug report, I think...
Using Chrome version 68.0.3440.106 (Official Build) (64-bit) on macos 10.13.6, the emulator always starts up with the bilinear interpolation filter turned on, regardless of the setting in the options menu. If I toggle the setting ("pixelated image") off and on, it does end up working, it's just a bit of a hassle to have to do this every time I re-open a js99'er tab.
Other than that, I love the new angular version.
#458 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Thu Sep 13, 2018 12:15 PM
Thanks, this should be fixed now.
#459 TheMole OFFLINE
TheMole
    Dragonstomper
  • 820 posts
Posted Thu Sep 13, 2018 2:19 PM
Indeed it is, thanks!
#460 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,467 posts
Posted Sun Oct 7, 2018 3:45 PM
I have been having some trouble while using js99er, though I don't know if it is my system or the emulator.  I am running win7 with firefox.  Here is what I've been experiencing:
1. Certain keys are not recognized by js99er.  The colon/semicolon, addition/equal sign, and a few others.  I can flip to the keyboard tab and click the 'button' on the TI keyboard picture and that works ok.  I have tried changing the keyboard-related options to no avail.   The keys are even unresponsive at the TI title screen.
2. I had a bug that modified R14 resulting in a subroutine returning to the wrong address, blanking the screen, and making the program seem unresponsive.  When I tried pressing control keys within the program, instead of just doing nothing (or passing to the TI program) , Firefox started opening up dialogue boxes and menus corresponding to the keys.
3. Pressing the PC keyboard function keys sometimes causes all subsequent key responses to be shifted (I think by >80).  Even resetting to the title screen didn't fix the problem - I could not select '1' or '2' for the cartridge options.  The only way I found to return to normal was to reset js99er and hit ESCape at the TI title screen.
I know... strange stuff :)
#461 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Mon Oct 8, 2018 1:06 PM
Yes I can see that the keyboard no longer works as expected in Firefox. I will try to get it fixed in the next update.
#462 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Sat Oct 13, 2018 2:07 PM
I have been working on a new keyboard emulation routine for a few days. It seems to be working now, so I have released it. This is based on relatively new browser technology that works in Chrome and Firefox but I'm not sure about Microsoft Edge.
I will use this opportunity to explain the difference between normal keyboard mode and PC Keyboard mode. The former is mapping physical keys to TI keys. So the key next to the tab key is always mapped to Q on the TI, although on an AZERTY keyboard this is the A key. In PC Keyboard mode, however, it is not the physical location of the keys, but the characters they produce on your PC, that determines which TI keys they are mapped to. So, for instance, when I press Shift+2 on my Danish keyboard, which produces a quote character, this is mapped to Fctn+P on the TI. This mode is more complex and therefore more likely to have compatibility issues with software, so you should always try to turn it off if you experience any issues. But for those of us without a US keyboard it makes typing a whole lot easier.
In this latest revision I have dropped the mapping of F1-F10 to TI function keys to avoid clashes with browser functionality. If anyone is missing this feature I could add it as an option.
@InsaneMultitasker: I'm not sure if this update will fix all the problems you have experienced, so please let me know how it works for you.
Edited by Asmusr, Sat Oct 13, 2018 2:36 PM.
#463 whicker OFFLINE
whicker
    Space Invader
  • 19 posts
Posted Wed Oct 24, 2018 9:15 PM
I am stumped, and missing what the function keys could previously do in PC Keyboard mode.
Could you please tell me what keys to press on an EN-US keyboard for FCT-4 (Clear) in PC Keyboard mode?
When not in that mode, it's simply ALT-4
On my machine, Firefox definitely has command of F3 (search) and F5 (page refresh), and Windows has the sinister ALT-F4 (close).
But I miss having F4 and F6-F9 for BASIC programming and games, respectively.
#464 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Wed Oct 24, 2018 10:37 PM
I thought you could use Alt in PC Keyboard mode, but you're right, it's not working.
The question is whether I should try to fix the Alt keys or reintroduce the function keys? Personally I like being able to press F5 to refresh the page, but I can also do it from the right-click menu.
#465 whicker OFFLINE
whicker
    Space Invader
  • 19 posts
Posted Wed Oct 24, 2018 11:35 PM
I do like the function keys better, but don't know how difficult it is to override them.
Not sure if some cannot be overridden at all, depending on the browser.
I'm thinking keeping F5 as refresh would ultimately cause more frustration than overriding it (again if it's even possible to override). After all, a browser refresh instantly wipes out whatever you happened to be doing.
There is always CTRL-R or the GUI or the right click menu you mentioned to cause page refresh, and probably more ways than that. I just personally press your red reset button.
It's nice to be able to just press F4 on my keyboard to Break a running BASIC program.
Just my thoughts.
#466 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Thu Oct 25, 2018 9:36 AM
Just my thoughts.
OK, I agree. Function keys are back.
#467 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 131 posts
Posted Thu Nov 29, 2018 2:37 AM
Hi guys
Sorry for the ignorance guys, but I simply cannot get actual fctn keys to work without using the "on screen keyboard".  What do i use to emulate the fctn keys?
#468 Lee Stewart OFFLINE
Lee Stewart
  • 3,991 posts
Posted Thu Nov 29, 2018 6:22 AM
Hi guys
ALT+<key>
...lee
#469 pjduplooy ONLINE
pjduplooy
    Chopper Commander
  • 131 posts
Posted Thu Nov 29, 2018 6:44 AM
Thank you Lee
#470 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Sat Dec 1, 2018 2:26 PM
You can now record videos with sound directly from js99er.net. Just click the Rec button to start and click Stop when done. You will then be asked where to save the video file (webm format). Works in Chrome and Firefox.
Edited by Asmusr, Sat Dec 1, 2018 3:10 PM.
#471 thej OFFLINE
thej
    Space Invader
  • 30 posts
Posted Tue Dec 4, 2018 2:56 PM
Asmusr, have you considered packaging js99er for Sandstorm?
Sandstorm is a web app platform intended as a replacement option for Google Docs.
Existing Web apps can be packaged and added as installable apps on the platform.
There are currently 73 apps available for use on the platform.
You should check it out!
https://sandstorm.io
Here is a direct link to the packaging docs:
https://docs.sandsto...est/developing/
J
Edited by thej, Tue Dec 4, 2018 2:59 PM.
#472 Asmusr OFFLINE
Asmusr
  • 3,146 posts
Posted Thu Dec 6, 2018 9:41 AM
J
It's an interesting idea, but after looking at the documentation I don't think js99er is the type of application that would benefit from being available via Sandstorm. It is a pure client side app that doesn't need a server to store or share any data.
#473 retroclouds OFFLINE
retroclouds
  • 1,705 posts
Posted Thu Dec 6, 2018 11:41 AM
What about turning it into an electron application?
https://electronjs.org/
#474 arcadeshopper OFFLINE
arcadeshopper
  • 4,403 posts
Posted Thu Dec 6, 2018 11:47 AM
tried to play st nick last night and mid-game it would lose keyboard control if i clicked on the screen it would work for key input but keyboard did not .. resetting the emu fixed it ..until it did it again
Greg
#475 retroclouds OFFLINE
retroclouds
  • 1,705 posts
Posted Sat Dec 8, 2018 3:24 PM
Not sure if this is a bug in js99er.  If you open the debugger and set a view address (e.g. CPU memory >8300) then afterwards the keyboard doesn't work anymore in the emulator.
You can test it with Pitfall. Even if you press the "Reset" button they keyboard still seems to be disabled.
Either way, that's a fantastic emulator you have there. Very impressive!  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
Also tagged with one or more of these keywords: Emulator, JavaScript
