XB Game Developers Package
483 replies to this topic
#476 LASooner OFFLINE
LASooner
    Moonsweeper
  • 373 posts
Posted Thu Jan 31, 2019 3:21 PM
Just a quick glance at the 2 compiled versions, The older compile (on the left) had 1 extra line at the end of the code
line 2835 is not present in the HONDARRABI compile. I do not grok Assembly code, so you'd know better than me if that makes a difference.
#477 senior_falcon OFFLINE
senior_falcon
  • 1,380 posts
Posted Thu Jan 31, 2019 4:06 PM
That makes no difference. The asterisk tell the compiler that line is a comment. If you wanted to put the runtime routines into low memory, the compiler on the left would un-comment the line. The new compiler will add AORG >2008 after ENDCC for the same result.
#478 senior_falcon OFFLINE
senior_falcon
  • 1,380 posts
Posted Thu Jan 31, 2019 8:06 PM
Found the problem. CALL LINK("IRND",A,B,C,D) was not in the list of subprograms. That didn't cause a problem before, but with the new ability to CALL your own subprograms, it assumes that IRND is your own subprogram and treats it differently.
with Grechetto:
L1640
       DATA IRND,NC29,NV46
with Hondarrabi:
L1640
       DATA CALL,IRND,NC29,NV46
The fix is dead simple and I should be able to post it tonight.
#479 LASooner OFFLINE
LASooner
    Moonsweeper
  • 373 posts
Posted Thu Jan 31, 2019 8:08 PM
Good to know
#480 senior_falcon OFFLINE
senior_falcon
  • 1,380 posts
Posted Thu Jan 31, 2019 9:13 PM
Here you go. This fixes the bug that LASooner found.
I thought you might be having memory problems, but the compiler reports over 1K memory available. You only have 2 string variables, so at most they would take up 512 bytes. So that's not an issue for you.
I hope there are no more bugs to find, but if there are, I hope you guys can find them!
#481 LASooner OFFLINE
LASooner
    Moonsweeper
  • 373 posts
Posted Thu Jan 31, 2019 9:26 PM
I'll give it a shot when I get home
#482 senior_falcon OFFLINE
senior_falcon
  • 1,380 posts
Posted Thu Jan 31, 2019 9:52 PM
Just wanted to say, the files you sent were perfect. Exactly what was needed to diagnose what was happening.
#483 LASooner OFFLINE
LASooner
    Moonsweeper
  • 373 posts
Posted Thu Jan 31, 2019 11:43 PM
old version and new version in the same cart
I feel like the player is a little more responsive, but maybe it's the placebo effect.
It takes the player roughly 8 seconds to go from left to right across the top of the screen in the old version and 7 seconds in the new version.
Edited by LASooner, Thu Jan 31, 2019 11:54 PM.
#484 Opry99er ONLINE
Opry99er
  • 10,607 posts
Posted Fri Feb 1, 2019 12:53 AM
Excellent!!!!
