Adventure Creator working disk version?
9 replies to this topic
#1 Philsan OFFLINE
Philsan
  • 3,838 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sun Jun 22, 2014 1:11 PM
I found that Spinnaker's Adventure Creator is a very nice tool for kids.
Unfortunately I am unable to find a working disk/xex version.
After game start,
if I select EDIT, press RETURN, press FIRE on CREATURES, press FIRE on OFF (it changes to SLOW), press SPACE BAR,
my real Atari freezes (Altirra emulator gives an error).
Rom version doesn't have that problem.
#2 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,314 posts
Posted Sun Jun 22, 2014 1:29 PM
Have you tried more than one "release" of Adventure Creator?  Could it be a form of copy protection?
#3 russg OFFLINE
russg
  • 1,648 posts
Posted Sun Jun 22, 2014 2:35 PM
After game start,
I have this .ATR version.  It loads up, but I don't know how to use it.  I'll try it on a real Atari.  It seems to work in Atari800wiinplus4.
Tried it on real 800, works.  Seems to work on 800XL also.
Edited by russg, Sun Jun 22, 2014 2:52 PM.
#4 Philsan OFFLINE
Philsan
  • 3,838 posts
Posted Sun Jun 22, 2014 3:00 PM
Thanks but the version you uploaded doesn't work too.
Like all versions I tried before, it seems to work but if you do exactly those steps the computer freezes:
select EDIT
press FIRE
press RETURN
select CREATURES
press FIRE
select OFF
press FIRE (OFF changes to SLOW)
press SPACE BAR
#5 russg OFFLINE
russg
  • 1,648 posts
Posted Sun Jun 22, 2014 3:16 PM
select EDIT
press FIRE
press RETURN
select CREATURES
press FIRE
select OFF
press SPACE BAR
Yes, that sequence freezes, those steps.  If you hit RESET, it goes back to the intro screen.  So, it is working, but crashes when you try to do something with it.
You're trying to use it, which I don't know about.  It is cracked and there is a PRO version I think I have.  I'll try your sequence with the PRO version.
No..... I couldn't find a PRO version.  Maybe you're right, it only came as a cart and hasn't been cracked successfully.  The .ATR I have is a cracked version
that loads with the 'K' at the start.  Atarimania only has the 'K' version also.  So, this may not be a good question, is it disabled such that you can't use it?
Edited by russg, Sun Jun 22, 2014 3:26 PM.
#6 Philsan OFFLINE
Philsan
  • 3,838 posts
Posted Sun Jun 22, 2014 3:22 PM
If I am not wrong, Adventure Creator was released on ROM only.
Perhaps cracked ATR/XEX versions don't work.
My sequence is a quick way to find that the program doesn't work.
#7 FULS OFFLINE
FULS
    Moonsweeper
  • 343 posts
Posted Sun Jun 22, 2014 4:31 PM
Try this Xex and Atr. Is Dos needed? System Reset will wipe out program on XEX file.
Attached File  Adventure Creator.XEX   16.07KB   154 downloads
Attached File  Adventure Creator (1984)(Spinnaker Software)k-file.atr   16.52KB   142 downloads
Good luck,
Doug
#8 russg OFFLINE
russg
  • 1,648 posts
Posted Sun Jun 22, 2014 4:33 PM
I played with it a little.  Yes, your sequence locks up.  You can RESET out of it, then go back to CREATURE and it works properly.  Hitting SPACEBAR is supposed to take you to the
opening menu, which it does after your RESET from the hang.  It says 'Speak' when it hangs.  You may need to give a password, a creature name and other things that I didn't get
far enough to see.  What I'm saying is it may be usable to create your adventure, just have to RESET and go back to where you were.  Without getting further into learning how
to make an adventure, I don't know why RESET won't work.  Maybe RESET makes you lose all your work, but going to CREATURE and editing the creature and then you will
properly go back to the menu with a SPACEBAR, which is what is supposed to happen.  I think a FIRE button also takes you back sometimes.
I briefly looked at the documentation on ATARIMANIA.COM, just enough to learn that SPACEBAR  is supposed to take you back up the menu.
It may be a fatal fault, or it seems to me to be recoverable.  I don't know which.  The .EXE and the .ATR seems to work the same.
The SPACEBAR is detected with a VBI or DLI routine, I think.
Edited by russg, Sun Jun 22, 2014 4:36 PM.
#9 FULS OFFLINE
FULS
    Moonsweeper
  • 343 posts
Posted Mon Jun 23, 2014 6:23 AM
attachicon.gifAdventure Creator.XEX
attachicon.gifAdventure Creator (1984)(Spinnaker Software)k-file.atr
Good luck,
Doug
Also one more version that seems to work.
Attached File  Adventure Creator (1984)(Spinnaker Software).xex   16.6KB   109 downloads
#10 Philsan OFFLINE
Philsan
  • 3,838 posts
Posted Mon Jun 23, 2014 11:44 AM
Thank you very much to all!
The versions attached by FULS don't freeze the computer but only one of them (k-file) can be inserted in a DOS disk and save into it.
So, I attach .xex and .atr working versions.
In the next days I will test .atr version with my daughter!
