+bob1200xl Posted July 7, 2014 Share Posted July 7, 2014 Before I list a high-value item on eBay, I'd like to pre-announce it here. Mostly as a communication path, longer visibility, sanity check type thing. I know you folks have established 'protocols' and are used to dealing in a certain range. I'm going to jump outside the dots a little bit. If it doesn't work, then I'll knock it off. First item: Atari 1090 XL Expansion System. No cover, no cards. Just m/b and cage. I tested this unit on a 600XL with a memory expansion card in the 1090. Worked fine - 39K of memory on a 16K 600XL. **The memory expansion card is not included** Projected listing date: 7/14/2014 Bob Quote Link to comment Share on other sites More sharing options...
+Allan Posted July 8, 2014 Share Posted July 8, 2014 Nice. This is the one item I wish Atari didn't drop. So much potential. I wish someone would reproduce that board and make a run of them. It doesn't look that complicated as far as boards go. Allan Quote Link to comment Share on other sites More sharing options...
