Competition Pro worth $65?
28 replies to this topic
#26 bikeguychicago OFFLINE
bikeguychicago
  • 1,349 posts
Posted Sun May 5, 2019 8:05 PM
I have a Competition Pro and it's a good stick for some games but I find it has the following issues as well:
  • It has a very short throw for such a tall joystick
  • I find it awkward if I need to use both buttons as they're on opposite sides
  • Since it requires a stock 5200 stick be connected as well, you need to make sure the 5200 stick is centered before using the Comp Pro. If the stick is leaning in any direction, the character will movie in that direction, even if the Comp Pro isn't being moved. Since it doesn't have any sort of calibration built-in, you may need to fiddle with the centering the 5200 stick a bit before the Comp Pro centering is 'just right'.
  • I find it hard to hit the diagonals with this stick. It's almost impossible to use with games like Popeye or Gyruss.
Edited by bikeguychicago, Sun May 5, 2019 8:07 PM.
#27 masschamber OFFLINE
masschamber
  • 1,615 posts
Posted Sun May 5, 2019 9:11 PM
I have a competition pro. Not very good. Never Worked right since I ebayed it.
the competition pro relies on the 5200 for calibration, if the 5200 stick jitters or doesn't provide good centered values the comp pro doesn't work
#28 0078265317 OFFLINE
0078265317
  • 6,715 posts
Posted Sun May 5, 2019 11:32 PM
Even if I unplug it after I press start or use a masterplay clone.
Edited by 0078265317, Sun May 5, 2019 11:33 PM.
#29 masschamber OFFLINE
masschamber
  • 1,615 posts
Posted Sat May 11, 2019 8:13 PM
I don't know about a master play clone but if you unplug the 5200 controller it definitely won't work correctly.
