Thomas Jentzsch Posted September 18, 2014 Share Posted September 18, 2014 To me, if there was going to be an initialization slowdown, it would happen at first, not later.Exactly. And since it doesn't behave like this, something odd must be happening. Something else to try: download the official SD2.dll from http://libsdl.org and drop it in the app folder to see if it makes any difference.Makes no differences. The versions are identical anyway. Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 21, 2014 Share Posted September 21, 2014 I took a quick look at the new version of Stella. I have a question about the memory areas that SpiceWare added. It shows the DPC+ memory and mentions the 1K frequency table, and what is accessible to/from the 6507. In batari Basic, which SpiceWare doesn't use, we have a "256K basic stack" where values and ranges of values can be pushed and pulled. Is this basic Stack shown on the data map? In DK Arcade 2600 we use it to push out the score and pull in the countdown timer, then we push out the timer and pull the score back. It is just 3 bytes out of the 256 available, but it is a start at using it. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 23, 2014 Share Posted September 23, 2014 (edited) In batari Basic, which SpiceWare doesn't use, we have a "256K basic stack" where values and ranges of values can be pushed and pulled. Is this basic Stack shown on the data map? Yes, it's somewhere in the Display Data, the first 4K ($0000 - $0FFF) of RAM that's displayed. I took a look in bB11d (I have that on my Mac from when I ported my sound effect driver to bB) and in keywords.c I can see where the stack commands are processed: else if (!strncmp(statement[1],"push\0",5)) do_push(statement); else if (!strncmp(statement[1],"pull\0",5)) do_pull(statement); else if (!strncmp(statement[1],"stack\0",6)) do_stack(statement); in statements.c: you can see do_push, do_pull and do_stack. the function do_stack converts the bB stack command to 6507 assembly like this: void do_stack(char **statement) { removeCR(statement[2]); printf(" lda #<(STACKbegin+%s)\n",statement[2]); printf(" STA DF7LOW\n"); printf(" lda #(>(STACKbegin+%s)) & $0F\n",statement[2]); printf(" STA DF7HI\n"); } So somewhere there's a constant defined as STACKbegin that'll tell you where in Display Data the stack is located. It looks like it's on line 194 of DPCplusbB.h, but it's defined based on what comes before it: STACKbegin = BKCOLS + 256 One of the options for DASM is to output a symbol listing. When I compile my projects I do so like this: dasm draconian.asm -f3 -v0 -sdraconian.sym -ldraconian.lst -odraconian.bin the -s requests a symbol file, which is named draconian.sym. I believe bB is already requesting the symbol file as I see one for my sfx_demo. If you have the *.sym file you should find the location of STACKbegin in there. Edited September 23, 2014 by SpiceWare Quote Link to comment Share on other sites More sharing options...
ericitaquera Posted September 27, 2014 Share Posted September 27, 2014 First of all: thank you very much for your work in Stella. I´m having problem by launching 4.1 from command line passing a rom as argument. H:\HyperSpin\Emulators\Stella\Stella-4.1\64-bit\Stella.exe "H:\Emulators Roms\Atari 2600\ROMS\3-D Tic-Tac-Toe (1980) (Atari).a26" -fullscreen 1 -fullres auto It crashes imediatelly. I´ve tried 32-bits, tried to remove "-fullscreen 1 -fullres auto" from commandline. Tried all "-video" possible options. I have version 3.1.2 and 3.7.2 and both work like a charm. I´m using windows 7 64 bits (all windows updates applied), processor AMD Athlon X2, GPU ATI HD3850. Please let me know if you need further details to check this. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
+stephena Posted September 27, 2014 Author Share Posted September 27, 2014 I will look into this. Does it run correctly when launching from the icon? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 27, 2014 Share Posted September 27, 2014 Is this basic Stack shown on the data map? Any luck tracking down the value for STACKbegin? Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 27, 2014 Share Posted September 27, 2014 Stack seems to be set up or cleared in the DPCstartup.asm My game's sym says: SQUARE_WAVE_VOL4 008a SQUARE_WAVE_VOL5 0089 stack1 00f6 (R ) stack2 00f7 (R ) stack3 00f8 stack4 00f9 STACKbegin dca5 (R ) Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 27, 2014 Share Posted September 27, 2014 STACKbegin dca5 (R ) Not a value I would have expected. DPC does mask the address with $0fff though, so try monitoring addresses $0ca5 thru $0da4 on the Cartridge RAM tab. Quote Link to comment Share on other sites More sharing options...
ericitaquera Posted September 28, 2014 Share Posted September 28, 2014 I will look into this. Does it run correctly when launching from the icon? It crashes only from command line. It works perfectly if the game is launched by the rom launcher screen. Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 28, 2014 Share Posted September 28, 2014 Running Windows 7 32-bit Profession and 64-bit Home Premium, I launch Stella 4.1.1 with a ROM from a command line without issue. The 32-bit install has an Intel HD graphics chip within a Core i5 laptop. The 64-bit install has a ATi Radeon HD 5670 card within a Core i7 desktop. Note: I do have a basedir.txt file in place under the Stella folder which specifies the aforementioned folder for storing the *.ini files. ericitaquera, have you tried the following?: Windows XP/Vista/7/8: Open Windows Explorer and type '%appdata%\stella' into the address bar. This will bring you to the directory where Stella stores its settings. Find and delete/rename the file named 'stella.ini'. Source: http://stella.sourceforge.net/faq.php Quote Link to comment Share on other sites More sharing options...
ericitaquera Posted September 28, 2014 Share Posted September 28, 2014 ericitaquera, have you tried the following?: Windows XP/Vista/7/8: Open Windows Explorer and type '%appdata%\stella' into the address bar. This will bring you to the directory where Stella stores its settings. Find and delete/rename the file named 'stella.ini'. Just tried. Nothing changed. Tnx! Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted October 11, 2014 Share Posted October 11, 2014 (edited) Space Instigators is intermittently broken in the current version of Stella (it looks like it was broken as of at least 3.9.1, which it the oldest version I still have around). The title screen is garbled, as are some of the game graphics, and collision detection is way off (you shoot an invader, and a different one disappears). But this doesn't happen on every launch. Relaunch the game, and sometimes it works just fine. http://atariage.com/software_page.html?SoftwareLabelID=2369 Space Instigators+ has the same problems in-game (although it no longer has a title screen, apparently). http://atariage.com/forums/topic/197849-space-instigators/ Edited October 11, 2014 by Nathan Strum Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted October 11, 2014 Share Posted October 11, 2014 I know this doesn't mean anything to you Nathan, but I will give a quick explanation of what is happening here (with Space Instigators, I didn't try the + version). Space Instigators is not clearing the decimal flag at power on. It should really clear this flag. The new version of Stella randomizes the state of some of the flags upon power-up to help authors catch dependent behaviour like this. I don't know whether or not the decimal is truly randomized or clear at start up, but its easy enough to include a CLD instruction into a rom. I will leave it up to the original author to do this. Somebody should shoot him a PM. Also, I did write a rom that shows most of the state of the 2600 at power-up. It could be somewhat useful for developing Stella in this area. Looking at Stella now it appears that the SP is never randomized, and I think it probably should be. 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 11, 2014 Share Posted October 11, 2014 Space Instigators is not clearing the decimal flag at power on. It should really clear this flag. The new version of Stella randomizes the state of some of the flags upon power-up to help authors catch dependent behaviour like this.Maybe we should use a "developer" flag for this. Because it seems that on the real hardware, the flag is usually (but maybe not always) clear at startup. Looking at Stella now it appears that the SP is never randomized, and I think it probably should be.That's hardly forgotten by any developer. But of course you are right, if we randomize, we should randomize everything. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 11, 2014 Author Share Posted October 11, 2014 The issue is indeed randomization of CPU registers that is enabled by default. You can go into the debugger, and under I/O (de)-select "Randomize CPU registers (A/X/Y/PS)". Turning this off allows Space Instigators to work. Also, for some reason I didn't include 'SP' in the randomization; it's even reflected in the description (there's no SP there). I will add this for the next release. Quote Link to comment Share on other sites More sharing options...
LS_Dracon Posted October 11, 2014 Share Posted October 11, 2014 (edited) Maybe we should use a "developer" flag for this. Because it seems that on the real hardware, the flag is usually (but maybe not always) clear at startup. That's hardly forgotten by any developer. But of course you are right, if we randomize, we should randomize everything. Not Aways. I didn't put CLD on Bee-Ball and sometimes it do not initialize well. I thought was a cart connection problem at first, removing the cart, plug again and turning on it works. But it is the missing CLD, perhaps just turning power switch off-on gonna work. Still a rare event, would say 1 out of 50. Naturally I'm aways clearing D flag now. That was a beginner mistake. The Stella should keep random cld at start. Edited October 11, 2014 by LS_Dracon Quote Link to comment Share on other sites More sharing options...
seemo Posted October 23, 2014 Share Posted October 23, 2014 Calling Stella 4.1.1 from Crimson Editor (via the User Tools keyboard shortcut) does not show the Emulator Window... a process (named Stella.exe) is shown in the Task Manager list, but no entry appears in the Applications tab (I am on Windows 7 32bit). Calling Stella 4.1.1 from an explorer window opens up the emulator without any problem. Version 3.9.3 works without any problem in Crimson Editor. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 23, 2014 Author Share Posted October 23, 2014 This issue seems to be related to reports of Stella not opening from the commandline (which is essentially what Crimson Editor is doing). I still can't duplicate this on my system, so for now I'm at a loss as to what's happening. I will try Crimson Editor and see if it happens for me. I can't fix this if I can't duplicate it ... One thing to try is downloading the Visual Studio 2013 runtimes, located here. Quote Link to comment Share on other sites More sharing options...
seemo Posted October 23, 2014 Share Posted October 23, 2014 I just tried typing the same exact call that is issued from Crimson Editor inside a command window (ver. 6.1.7601) and Stella 4.1.1 starts without any problem. As about the runtimes, I had already installed them, as the execution of the downloaded file in your link (vcredist_x86) prompted me to either repair or uninstall them. Anyway I went with 'repair', to see if something needed fixing, but even after the repair procedure (which ended without errors) I still could not call Stella from Crimson Editor. Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted October 23, 2014 Share Posted October 23, 2014 For the record, Bee-Ball also has the same issue as Space Instigators. Normal: Glitched: Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 23, 2014 Author Share Posted October 23, 2014 For the record, Bee-Ball also has the same issue as Space Instigators. This is the same issue as before (CPU registers are randomized). The upcoming release will have randomization of CPU registers disabled by default, and also allow to selectively enable randomization for each one. 1 Quote Link to comment Share on other sites More sharing options...
seemo Posted October 24, 2014 Share Posted October 24, 2014 Just to add that Stella 4.1.1 window does not appear if called from Programmer's Notepad (v2.3.4.2350-charles), too. Unfortunately, windows event registry does not show any error/message. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 25, 2014 Author Share Posted October 25, 2014 Just to add that Stella 4.1.1 window does not appear if called from Programmer's Notepad (v2.3.4.2350-charles), too. Unfortunately, windows event registry does not show any error/message. Can you describe exactly how you set up this editor with Stella, so that I can duplicate your setup? Feel free to move this to PM if you like. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 28, 2014 Author Share Posted October 28, 2014 The issue with Crimson Editor and Programmers Notepad above are caused by an incompatibility between Stella output and the apps' capturing the output. Disabling this functionality in the editors works for now, but I'll continue to research why it's happening. Also, Stella 4.2 has been released, so please move all discussion to that thread. Quote Link to comment Share on other sites More sharing options...
