Tupin Posted September 15, 2014 Share Posted September 15, 2014 Scored myself a toploader recently and was blown away when I saw the quality of the NESRGB board. I know it outputs RGB and was planning on having one of those 3D printed AV Multiout things. But from that, I was planning on a SCART cable that connects to some sort of adapter for HDMI? Is this ideal? Anyone here that did this on a toploader that can provide any insight? Quote Link to comment Share on other sites More sharing options...
Tupin Posted September 16, 2014 Author Share Posted September 16, 2014 Anyone have a clue? Quote Link to comment Share on other sites More sharing options...
Reaperman Posted September 16, 2014 Share Posted September 16, 2014 (edited) This part's probably causing the lack of input: Anyone here that did this on a toploader that can provide any insight? Generally, scart to HDMI via a framemeister is a pretty common setup here. It works well for me, but I suppose absolutely ideal for some here would involve a high-end standard definition CRT instead. I'm not personally sure about NES or toploader specifics, however. Edited September 16, 2014 by Reaperman Quote Link to comment Share on other sites More sharing options...
mickcris Posted September 16, 2014 Share Posted September 16, 2014 (edited) I have a NESRGB toploader. I use it with an xrgb mini. The cheaper scart to hdmi convertors work ok, but they are not nearly the same quality. Here is a page that has some reviews of some alternatives: http://retrogaming.hazard-city.de/ or get a PVM or some other sort of CRT monitor that can RGB input. Edited September 16, 2014 by mickcris 2 Quote Link to comment Share on other sites More sharing options...
CGQuarterly Posted September 16, 2014 Share Posted September 16, 2014 Either buy an RGB monitor or pony up for a proper-quality unit like the Framemeister. Yes, it's expensive. But why go through the trouble and expense of RGB-modding a system just to turn around and use an encoder that makes the image look worse? I use RGB monitors at home, but I've seen the Framemeister in person, and it lives up to the hype. 1 Quote Link to comment Share on other sites More sharing options...
Tupin Posted September 16, 2014 Author Share Posted September 16, 2014 I'll probably look for a Sony PVM, they seem to show up enough around here. Just depends on the model. Quote Link to comment Share on other sites More sharing options...
