mehguy Posted September 23, 2014 Share Posted September 23, 2014 I bought an nes from a threft store and booted it up. it didnt work. I opened it up and bent the pins back and cleaned the contacts and still, blue screen. The screen doesn't flash nor does the power button. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted September 23, 2014 Share Posted September 23, 2014 (edited) Disable lockout chip? Maybe it's the cart, tried more than one? Edited September 23, 2014 by Rex Dart Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 23, 2014 Author Share Posted September 23, 2014 Disable lockout chip? Maybe it's the cart, tried more than one? I already tried disabling it. it didn't work. I borrowed a copy of mario bros from a friend and his cart was working fine (the last time i saw it boot up on his nes) Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted September 24, 2014 Share Posted September 24, 2014 (edited) Alright, sounds like the only thing left to try is juju. You'll need a pigeon, your gris-gris bag, a tri-wing screwdriver, and a lock of Miyamoto's hair. edit: and a copy of T&C Surf Designs. Always forget that one... Edited September 24, 2014 by Rex Dart 1 Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 24, 2014 Author Share Posted September 24, 2014 Alright, sounds like the only thing left to try is juju. You'll need a pigeon, your gris-gris bag, a tri-wing screwdriver, and a lock of Miyamoto's hair. edit: and a copy of T&C Surf Designs. Always forget that one... What? Quote Link to comment Share on other sites More sharing options...
TPA5 Posted September 24, 2014 Share Posted September 24, 2014 Sometimes if the 72-pin connector is bad enough, even bending the pins and cleaning it may not be enough. Check the power supply as well, a friend of mine ended up replacing the power supply on his NES and that solved his flashing screen problem. Quote Link to comment Share on other sites More sharing options...
