Tupin Posted September 26, 2014 Share Posted September 26, 2014 So, is the left controller port working randomly/not at all a recurring problem on most Geminis? I've only ever dealt with two and they both have them. Should the solder just be reflowed or is this a sign of another issue? I've tried several controllers and thankfully had Wizard of Wor on hand so I can say the right port works just fine. Quote Link to comment Share on other sites More sharing options...
Tupin Posted September 28, 2014 Author Share Posted September 28, 2014 Okay, it really seems to be random. Or it works perfectly for a few seconds and then starts cutting out... Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted September 29, 2014 Share Posted September 29, 2014 Try reflowing the pins on the controller port, the Gemini has a single-sided board so it's much more susceptible to that sort of thing than an actual Atari system. Quote Link to comment Share on other sites More sharing options...
Video Posted September 29, 2014 Share Posted September 29, 2014 Didn't it have weird custom controllers and need a splitter to use them? I wasn't aware it was fully 2600 compatible, but I have a gemini controller and LOVE it.(wish I could find more, they feel almost analog, kind of like odyssey controllers) Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted September 29, 2014 Share Posted September 29, 2014 (edited) Didn't it have weird custom controllers and need a splitter to use them? I wasn't aware it was fully 2600 compatible, but I have a gemini controller and LOVE it.(wish I could find more, they feel almost analog, kind of like odyssey controllers) There is a special cable to use both the paddle and joystick IIRC. I believe you can still use regular joysticks and paddles like normal, I'm not big on gemini controllers anyway. To answer the original question, yes, it's a common problem. The Gemini used cheap off the shelf components. I have two gemini's with the controller port problem. I had one fixed and yes it was simply a matter of reflowing the solder on the offending joystick port. Happens quite often with the power port as well. EDIT - As I'm want to do, I made a video about this at the time Edited September 29, 2014 by AtariLeaf 1 Quote Link to comment Share on other sites More sharing options...
Amstari Posted September 30, 2014 Share Posted September 30, 2014 So, is the left controller port working randomly/not at all a recurring problem on most Geminis? I've only ever dealt with two and they both have them. Should the solder just be reflowed or is this a sign of another issue? I've tried several controllers and thankfully had Wizard of Wor on hand so I can say the right port works just fine. I've got the same problem with my Gemini. I would have to start the console, unplugged the controller and plug it back in a few times before it would work. Quote Link to comment Share on other sites More sharing options...
Rik Posted September 30, 2014 Share Posted September 30, 2014 I thought the answer to this threads title was going to be " cracked cases ". I always wanted a Gemini, problem is ALL i have seen at thrift and flea markets have had severely cracked cases. Usually cracked where the RF cable goes. Anyways i find the Gemini controllers a really great design conceptually. I am still looking for one. I would probably just have to get what i see and Frankenstein out broken parts with good ones. That's the only solution for me as i've never come across one that doesn't have cracks or holes. Quote Link to comment Share on other sites More sharing options...
