metzger130 Posted September 27, 2014 Share Posted September 27, 2014 There is a garage sale around here and they have a 4 port system, 2 controllers, power supply, the box to hook it up to the TV, 3 games (pac man, Star Raiders, and Missile command), plus the track ball for $50. it says 'untested" on it and I asked and they said they were going to hook it up to show someone else but it sparked (I know 4 ports always spark, they don't know that) and port 3 has a bent pin on it. How much would you offer them for it? Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted September 27, 2014 Share Posted September 27, 2014 $25 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted September 27, 2014 Share Posted September 27, 2014 yeah, I'd assume none of the controllers work, including the trackball so get it for as little as you can if you really want to deal with the expense and hassle of trying to enjoy a 5200. Quote Link to comment Share on other sites More sharing options...
metzger130 Posted September 27, 2014 Author Share Posted September 27, 2014 I have a 2 port and a 4 port system already, i just want the track ball and they are very expensive online right now. Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted September 27, 2014 Share Posted September 27, 2014 If the trackball works its well worth the $25 alone, The rest can be fixed or sold to cover the cost of the trackball. You MUST have a trackball! 2 Quote Link to comment Share on other sites More sharing options...
metzger130 Posted September 27, 2014 Author Share Posted September 27, 2014 If there is an issue with the trackball, is it easy to fix or impossible? I have missle command already which is the reason i need the trackball. it is unplayable with the stock sticks. Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted September 27, 2014 Share Posted September 27, 2014 Its not fragile like the joysticks if that's what you mean, I personally haven't come across a 5200 trackball that I couldn't repair (6-7 of them) or just needed cleaning. If it were me I would offer $25 and maybe mention the spark Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted September 27, 2014 Share Posted September 27, 2014 You'll probably just have to clean the gunk out of the Trak-Ball. They are sturdy controllers. We're trying to put together as much info as possible related to Trak-Balls over in our Facebook group. Dan Kramer, the man who created the 2600 and 5200 Trak-Balls is an active member... https://www.facebook.com/groups/trakbombers/ 1 Quote Link to comment Share on other sites More sharing options...
Shawn Posted September 27, 2014 Share Posted September 27, 2014 The 5200 trackball is a tank compared to the joysticks. Offer him $35 and call it a win. $35 is going blind of course assuming that everything but the trackball is non-working. Parts alone you should be able to recoup the investment and get a free trackball. 2 Quote Link to comment Share on other sites More sharing options...
HammR25 Posted September 27, 2014 Share Posted September 27, 2014 I'd give him $75 and post that stuff on eBay as RARE!!!!!!! for $350. 2 Quote Link to comment Share on other sites More sharing options...
Yokopup Posted September 28, 2014 Share Posted September 28, 2014 Man, if the trackball seems to be in good condition, I would give him the 50 bucks and call it a day. You can clean the trackball if there's a problem and still make money on it. My 2cents.... Quote Link to comment Share on other sites More sharing options...
metzger130 Posted September 29, 2014 Author Share Posted September 29, 2014 so I offered them $40 for it since we had no idea if it worked or not and they agreed. First thing I did was hook up the trak ball to my 2 port system While it works, it is very rough and loud, which tells me it needs cleaned. The one button works with missile command so I'm guessing it works (what game uses more than 1 button?). I then plugged the 4 port into a TV I had just laying around since it would be much easier to hook it up. at first I was getting nothing, and I mean NOTHING. Power light wouldn't come on at all. finally after tapping around the power button the light came on. I found that the only way it works is if you hit the bottom R corner of the power button. Not sure if cleaning would help this or not. The picture looks excellent, even with that stupid box and the connection not being great on the end of the box to the TV, actually looks a little cleaner than my 2 port. All 3 games load up fine. Controllers....... well what can you say about the 5200 controllers..... First one I plugged in I got missile command to start up and I could move the cursor all around, however, no shock to ANYONE, none of the side buttons would work. Start, reset, and pause all work, but side buttons don't work. I'll have to rip it apart and clean it and maybe dot trick it to see if it will work. The other one, I couldn't get the game to start at all, so I put it as controller 2 as a 2 player game for missile command. moves around with no problem, but again, side buttons don't work at all. have to open that one up, clean it and see if it works. Odd thing though, I hooked up the trak ball and the cursor wouldn't move, so I unplugged it and tried again, it went to the Upper L and if I moved the trak ball it wouuld go the way I wanted it to but then would go back tot he upper L again. This is odd since it works on the 2 port and the stock controllers move just fine. any ideas here? Overall, I'd say well worth the $40 I paid for it. Quote Link to comment Share on other sites More sharing options...
thucom Posted September 30, 2014 Share Posted September 30, 2014 (edited) so I offered them $40 for it since we had no idea if it worked or not and they agreed. First thing I did was hook up the trak ball to my 2 port system While it works, it is very rough and loud, which tells me it needs cleaned. The one button works with missile command so I'm guessing it works (what game uses more than 1 button?). I then plugged the 4 port into a TV I had just laying around since it would be much easier to hook it up. at first I was getting nothing, and I mean NOTHING. Power light wouldn't come on at all. finally after tapping around the power button the light came on. I found that the only way it works is if you hit the bottom R corner of the power button. Not sure if cleaning would help this or not. The picture looks excellent, even with that stupid box and the connection not being great on the end of the box to the TV, actually looks a little cleaner than my 2 port. All 3 games load up fine. Controllers....... well what can you say about the 5200 controllers..... First one I plugged in I got missile command to start up and I could move the cursor all around, however, no shock to ANYONE, none of the side buttons would work. Start, reset, and pause all work, but side buttons don't work. I'll have to rip it apart and clean it and maybe dot trick it to see if it will work. The other one, I couldn't get the game to start at all, so I put it as controller 2 as a 2 player game for missile command. moves around with no problem, but again, side buttons don't work at all. have to open that one up, clean it and see if it works. Odd thing though, I hooked up the trak ball and the cursor wouldn't move, so I unplugged it and tried again, it went to the Upper L and if I moved the trak ball it wouuld go the way I wanted it to but then would go back tot he upper L again. This is odd since it works on the 2 port and the stock controllers move just fine. any ideas here? Overall, I'd say well worth the $40 I paid for it. do the controllers do the same thing? if so, sounds like the 5200 system position pot is off. it's something that the system needs to be opened and adjusted for sometimes. Edited September 30, 2014 by thucom Quote Link to comment Share on other sites More sharing options...
metzger130 Posted September 30, 2014 Author Share Posted September 30, 2014 I hooked it back up and tried the controllers again to verify what I thought. The controllers work fine, they stay in the middle of the screen til I move it and they don't go to the L side automatically. I then verified it with a controller that I know works and everything works great. Just does not like the trak ball for some reason. Quote Link to comment Share on other sites More sharing options...
