LCD Monitor that supports ST Low Res! NEC MultiSync LCD 1970VX
221 replies to this topic
#51 bluemonday OFFLINE
bluemonday
    Star Raider
  • 57 posts
Posted Sat Jan 24, 2015 8:53 AM
Auto-adjust sorted the high res bars, thank you!
I've also tweaked some of the settings and improved medium res a bit, but it is still a bit iffy. I'm still really pleased with it overall though.
#52 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Sun Jan 25, 2015 2:57 PM
Awesome, just found one of the monitors listed in the thread, online not to far away... :) picking it up tomorrow... and I will make the cable this week :)
i have 2 13 pin Din males i can use... so that will allow me to make up two cables if I get lucky enough to find another one...
Cheers guys,  this is great... i have 6 atari ST's and only 3 monitors... (124, 125,1224) i have a vga that works with monchrome already ( I wonder if it will work with low res? ) the high res looks like the picture above with the vertical banding, but when i hit auto adjust, it looks great... i wonder if that means the low res will work? i will have to make a cable and see... :)
thanks again :)
Edited by Waltermixxx, Sun Jan 25, 2015 3:00 PM.
#53 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Sun Jan 25, 2015 4:03 PM
thanks again :)
here is the Dell 1703FPt  with the mono cable I built a while back... it looks good... I'm wondering if colour would look just as good? at least low res?  I will have to build a cable and see...  i will still pick up the other monitor, as it does not hurt to have a few of these around... if it does work, i may change this mono cable into a multi cable... :)
Edited by Waltermixxx, Sun Jan 25, 2015 4:06 PM.
#54 bluemonday OFFLINE
bluemonday
    Star Raider
  • 57 posts
Posted Sun Jan 25, 2015 4:20 PM
I think ST mono works on almost any VGA monitor. You'll need a multisync that supports lower frequencies for low res to work though.
Worth a try though - the more monitors that do support ST low that we can list here, the better!
#55 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Sun Jan 25, 2015 9:55 PM
I think you are right... my dell did not work with my atari rgb to vga cable... R(1) to R(7), G(2) to G(6), B(3) to B(10), Gnd (5,6,7,8,9,10) to Gnd(13), Hsync(13) to Hsync(9), Vsync(14) to Vsync(12)....
oh well, hopefully when I pick up that NEC 1970nx monitor others have used it will work... :)
Cheers folks and wish me luck... :)
#56 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Mon Jan 26, 2015 1:02 PM
Well I picked up my NEC 1970nx multisync monitor...
for an LCD screen it's surprisingly heavy... :) but lighter and easier to carry than a 1224 colour monitor at only 14" :)
thanks for the hints folks... tonight when i get home i will try it out...
and if it works... i will then try and install my  STE IDE interface and MMC card... fingers crossed... :)
now that I think of it, i may bask in the glow of low res graphics for a week or so first, then try the ide interface. :)
Cheers and I will report in later. :)
#57 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Mon Jan 26, 2015 6:29 PM
Well the good news is, the monitor ( NEC 1970nx ) works great in low res, and even medium res looks pretty good as well, with the correct adjustments, it can look pretty good:
instead of attaching all the pics, here is a link to the flickr folder with the pics in it... :)
https://www.flickr.c...57650088133410/
Cheers. :)
Edited by Waltermixxx, Mon Jan 26, 2015 6:30 PM.
#58 TheNameOfTheGame OFFLINE
TheNameOfTheGame
    Dragonstomper
  • 697 posts
Posted Mon Jan 26, 2015 9:44 PM
Awesome!  Thanks for the update and the pics!
#59 bluemonday OFFLINE
bluemonday
    Star Raider
  • 57 posts
Posted Tue Jan 27, 2015 1:34 AM
A related question. Anyone know if the NEC 1970 NX will work as well with the Atari Jaguar? I'm not sure of the Jaguar's output frequency.
#60 bluemonday OFFLINE
bluemonday
    Star Raider
  • 57 posts
Posted Tue Jan 27, 2015 9:33 AM
Also, an update on medium res. If you make the horizontal size ('H. SIZE' in the menu) wider then medium res is improved.
Edited by bluemonday, Tue Jan 27, 2015 9:37 AM.
#61 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Tue Jan 27, 2015 12:44 PM
what are your settings for size, fine, etc... lets compare numbers... ( at work so i cant, but my flickr pics have some settings...) :)
#62 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Tue Jan 27, 2015 2:05 PM
A guy called Troed saw my Facebook post about this, and found a DELL monitor that works too:
Thanks for the inspiration. We can add the Dell 2001FP to this list - also a 31-80kHz scanner according to the manual, however, since it has composite and S-Video connectors I (thanks to your post) got the idea to test whether it'd do 15kHz via the VGA connector as well. I already knew it supported ST hi.
I'm picking up one of these this evening... :) hoping it works as well :)
Cheers. :)
Edited by Waltermixxx, Tue Jan 27, 2015 2:09 PM.
#63 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Tue Jan 27, 2015 7:31 PM
Sadness, just blew $50.00 for nothing... HiRes works but not low, or medium res on this monitor...
i will try it with my Amiga which is Pal, i just noticed that the picture above indicates PAL... :)
Tried it with my PAL A1200 and it works fine with multisync mode.
but for some reason, (ok I know the reason) it wont work with Low or Med. res on Atari... hires does look great. :)
Edited by Waltermixxx, Tue Jan 27, 2015 7:46 PM.
#64 ParanoidLittleMan OFFLINE
ParanoidLittleMan
  • 1,605 posts
Posted Wed Jan 28, 2015 2:02 AM
Your ST(E) is apparently NTSC. But you may try what happens if set it to 50 Hz refresh rate.  There will be no color most likely, but possible that then low/med res will work. And maybe worth to try with RGB connection if not already - then will be color :)
Edited by ParanoidLittleMan, Wed Jan 28, 2015 2:03 AM.
#65 iratasan OFFLINE
iratasan
    Chopper Commander
  • 218 posts
Posted Thu Jan 29, 2015 3:12 PM
Hello guys.... do you think this monitor would work on all 3 resolutions??
http://www.ebay.it/i...=item4d2caf34ef
Please confirm! Thanks a million!
C.
#66 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Thu Jan 29, 2015 6:58 PM
i would have to go with No,  we have these in our office, and I dont think they are multisync, they have very little in way of control.
I would say try and get the nec monitor that is confirmed...
#67 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 617 posts
Posted Fri Feb 6, 2015 5:00 PM
Has anybody had a chance to try any of these monitors with an 8 bit vbxe non vga core output?
I just purchased the multisync cable from best to try with an NEC 1970vx.
Hope to he able to report back later this weekend. If I get a chance I will try vbxe too and see what happens.
Robert
Edited by venom4728a, Fri Feb 6, 2015 5:02 PM.
#68 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 617 posts
Posted Mon Feb 9, 2015 1:49 PM
I can report that the BEST ELECTRONICS Cable CB102582-6 2nd  does work very well.  I have a Nec 1970vx Multisync and tested the monitor with my ATARI STE,  I am able to view all three modes with pretty clear results.   When switching each mode, I used the Auto Contrast and the Auto Adjust. I am very happy with the resuts.
I planned to connect my Atari 8bit, VBXE out put but I need another adapter, as my vbxe is using the 9 pin ega connector.  I ordered a ega to vga adapter and I will update after I am abe to try it out.
Best Regards
Robert
#69 busterm OFFLINE
busterm
    Dragonstomper
  • 637 posts
Posted Mon Feb 9, 2015 11:21 PM
Cheers. :)
Cheers. :)
Where did you buy the VGA adapter board from?
#70 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 617 posts
Posted Tue Feb 10, 2015 8:06 PM
Most of the monitors listed in this thread are working being connected directly into the Atari ST Monitor Output.  The OP found that the NEC Multisync 1970vx monitor would sync down to 15khz.  The Specs from NEC did not list he ability to sync down that low.   Others have found the NEC 1970nx is the same monitor as the vx, but also has an USB hub built in.  I think the NEC 1550 and another Dell monitor was also found to sync down to 15khz contrary to their documentation.
Robert
#71 Waltermixxx OFFLINE
Waltermixxx
    Space Invader
  • 37 posts
Posted Tue Feb 10, 2015 8:24 PM
It's a vga break out baord... originally designed to be used with parallax propeller Chip. :)
i think a lot of hobby electronic stores will seel "vga break out board"
http://propellerpowe....php?topic=42.0
not sure if they still sell them...
but you should be able to find something similar on ebay?
#72 busterm OFFLINE
busterm
    Dragonstomper
  • 637 posts
Posted Tue Feb 10, 2015 8:40 PM
Robert
I was referring to his breakout board in his photo album
#73 busterm OFFLINE
busterm
    Dragonstomper
  • 637 posts
Posted Tue Feb 10, 2015 8:42 PM
Cool thanks, looks like they dont sell them anymore.
I have a few similar boards Ive used to hook to a few rgb monitors that didnt have standardized pinouts  but this one just caught my eye since I had never seen it
#74 TheNameOfTheGame OFFLINE
TheNameOfTheGame
    Dragonstomper
  • 697 posts
Posted Sun Feb 15, 2015 8:48 PM
Tried this monitor on my Hades060 and it works great.  Most LCD monitors won't show the boot sequence until the NOVA drivers kick in.  This one handles 15khz just fine!
#75 GadgetUK ONLINE
GadgetUK
  • 1,945 posts
Posted Mon Feb 16, 2015 9:15 AM
I've been using the GBA-8220 VGA upscaler - works fine with the ST and looks pretty good.
