jimbox114 Posted November 19, 2014 Share Posted November 19, 2014 So I have started my own Atari game. Right now its mainly a learning experience. My finished game I plan to have two fish who are fighting for a female fish. The first fish to get hit 10 times loses. It will then cut to a simple cutscene and show a pink fish swim to the winning player and play a little tune and thats pretty much it. The game is set up for 1 or 2 players. Anyways my first major hangup is I can't get player 2 missile to fire.when joy0fire is does exaclty what I want it to do. I have looked it over and over and Im sure its something small but it just puts it right on the player and it doesn't move. Also when trying to play it in two player mode while player 1 is moving player 2 can't seem to move. Do I need some more code in there to prevent this or maybe something else? In any case here is my code I tried to add some rem statements to explain what I have done so far: rem Generated 11/11/2014 3:13:05 PM by Visual bB Version 1.0.0.554 rem ********************************** rem *<Deep.bas> * rem *<Fish Wars!> * rem *<jimbox114@gmail.com * rem **********************************opening const noscore = 1 rem p is player 1 health and q is player 2 health whichever hits 10 first loseslet p = 0:let q = 0:h = 0 playfield: .XXXX..XXXXX...XXXXX...X...X.... .X.......X.....X.......X...X.... .XXX.....X.....XXXXX...XXXXX.... .X.......X.........X...X...X.... .X.....XXXXX...XXXXX...X...X.... ................................ ..X...X......X......XXXX..XXXXX. ..X...X.....X.X.....X..X..X..... ..X...X....X...X....XXXX..XXXXX. ..X.X.X...XXXXXXX...X.X.......X. ..XX.XX...X.....X...X..X..XXXXX.end COLUBK=$A4 COLUPF=$0E let a = 0 drawscreen rem tells the game to enable 2player mode if joy0fire then goto main if joy1fire then let a = 1:goto main: goto opening main playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ .....................X.......... .....X..............X........... ....X................X.......... XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXend COLUPF=$FE COLUBK=$80 player0x=20:player0y=50 player1x=140:player1y=50 missile0height=1:missile0x=170 missile1height=1:missile1x=0 NUSIZ0 = 16 NUSIZ1 = 16sprites COLUP0=$FC player0: %00000000 %00010000 %00001000 %01011100 %00111011 %01011100 %00001000 %00010000end COLUP1=$BA player1: %00000000 %00001000 %00010000 %00111010 %11011100 %00111010 %00010000 %00001000end if missile0x>155 then let missile0y=200:goto skip if missile1x<3 then let missile1y=200:goto skip missile0x = missile0x+2:goto draw_loop missile1x = missile1x-2:goto draw_loopskip if joy0fire then missile0y=player0y-4:missile0x=player0x+4:goto playsound if joy1fire && a = 1 then missile1y=player1y-4:missile1x=player1x+3:goto playsound draw_loop drawscreen if q = 10 then goto final if p = 10 then goto final rem prevents players from leaving screen if player0x < 5 then player0x = 4 if player0x > 70 then player0x = 69 if player0y < 8 then player0y = 8 if player0y > 80 then player0y = 80 if player1x > 150 && a = 1 then player1x = 150 if player1x < 80 && a = 1 then player1x = 81 if player1y < 8 && a = 1 then player1y = 8 if player1y > 80 && a = 1 then player1y = 80 if a = 1 then 1s: rem skips autocontrol and allows joy1 commands for player 2 if player0y=player1y then missile1y=player1y-4:missile1x=player1x-1:missile1x = missile1x-2 if player1x = 139 then player1y = player1y-1 if player1x = 140 then player1y = player1y+1 if player1y > 80 then player1y = player1y-8:player1x=139 if player1y < 5 then player1y = player1y+1:player1x=140 if player1y = 5 then let h = h + 1 1s if collision(missile0,player1) then p = p +1:missile0y=255:goto playsound1 if collision(missile1,player0) then q = q +1:missile1y=255:goto playsound1 if joy0up then player0y = player0y-1:goto jump if joy0down then player0y = player0y+1:goto jump if joy0right then player0x = player0x+1:goto jump if joy0left then player0x = player0x-1:goto jump if joy1up && a = 1 then player1y = player1y-1:goto jump if joy1down && a = 1 then player1y = player1y+1:goto jump if joy1right && a = 1 then player1x = player1x+1:goto jump if joy1left && a = 1 then player1x = player1x-1:goto jump 1p if switchreset then let player1y=200:player0y=200:missile1y=200:missile0y=200:goto openingjump goto spritesplaysound AUDV0 = 5 : AUDC0 = 4 : AUDF0 = 10 u = u + 2 drawscreen if u < 1 then playsound u = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto jumpplaysound1 for u = 1 to 30 AUDV0 = 5 : AUDC0 = 12 : AUDF0 = u next u rem p = p + 2 drawscreen if u < 1 then playsound1 rem p = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto jumpfinal rem working on final cutscene need to match some colors up with the fish etc. player0x=20:player0y=50 player1x=140:player1y=50 player1x=player1x-4 if player1x=player0x then player0y=player0y-2 if player0y<0 then COLUP0=$54:player0y=50:player0x=1 if joy0fire then goto main if joy1fire then goto main Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted November 19, 2014 Share Posted November 19, 2014 You should alias the variables to make your code easier to read. Instead of this: rem p is player 1 health and q is player 2 health whichever hits 10 first loses Do this: dim _Player1Health = p dim _Player2Health = q dim _Is2PlayerMode = a Now the alias can be used in the code instead of the single letter variable name. Note that the bB manual recommends a __ (2 underscores) prefix for labels and _ (single underscore) prefix for variable alias. It would be a good idea to follow this convention. See the "Using dim to Create More Descriptive Names" subtopic of http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#variables I wasn't able to compile the source code you provided. Probably due to extra formatting included in your post. Maybe you can attach the .bas file instead of pasting the contents into your post. Finally, there is a sub-forum for bB that would be a better place to post questions regarding bB programs. Quote Link to comment Share on other sites More sharing options...
