+nanochess Posted November 23, 2014 Author Share Posted November 23, 2014 And now back to IntyBASIC, questions/comments for nanochess: The DEFINE ALTERNATE - just so I understand, this is so you can load 32 GRAM cards in a single frame? Wow, that's some aggressive animation but it does give me ideas... No, the limit of 16 GRAM update per frame stands up, the only difference is that you now can update separate sections of GRAM data. An idea that came to my mind was one player and one enemy with a variety of animations. For example: DEFINE 0,2,player_left_frame2 DEFINE ALTERNATE 8,2,enemy_right_frame1 PRINT <>number - it took me a while to realize that you need the <> but that was just me not reading the example first. Having an example of many of these things in the manual, by the way, has been invaluable. It makes it very obvious what the syntax is. So far this routine has very good performance although I haven't tried it with very large numbers yet. But wow - I'm going to be able to strip out SO much code. All of my score calculation and printing routines were dumping large values into arrays and such, to avoid repetitive /10 operations. This may be the single biggest performance enhancement (the rest of the changes are all new features and such). So - thanks! I don't print a lot of numbers but I do use PRINT for a lot of newbie-style debugging. This will save a LOT of cut/paste. Yes! being optimized in assembler it saves LOTS of cycles! (you should give thanks to intvnut for providing such an useful routine ) Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 23, 2014 Author Share Posted November 23, 2014 intvnut, what routine did you provide nanochess for printing decimals? Are those the ones in the SDK-1600 (prnum16.asm and prnum32.asm)? He offered the code and I've taken what I could use I've used prnum16.asm from jzintv download. BTW, with the new USR call routine you can integrate very easily your PRNG routines, using something like this: '.... some code.... A = USR PRNG(4) ' 4 bits of PRNG '.... more code..... ASM INCLUDE prng.asm In fact I've put also a VARPTR function to get the address of a variable and do optimized assembly processing DIM B(10) A = USR complicated(VARPTR B(3),4) ' Passes pointer to B(3) and the 4 for processing, let us say, 4 numbers 2 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted November 23, 2014 Share Posted November 23, 2014 (edited) He offered the code and I've taken what I could use I've used prnum16.asm from jzintv download. I ask because at some point in time in the past, Joe had discussed the use of a binary search tree look-up for decimal number encoding, and I was wondering if that was in play here. I see that prnum16.asm does repeated subtraction. I wonder how it performs against a routine that alternates between subtraction and addition, provided by GroovyBee in this thread. Update: The decision-tree routine was discussed in that same thread. Edited November 23, 2014 by DZ-Jay 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 23, 2014 Share Posted November 23, 2014 (edited) I ask because at some point in time in the past, Joe had discussed the use of a binary search tree look-up for decimal number encoding, and I was wondering if that was in play here. I see that prnum16.asm does repeated subtraction. I wonder how it performs against a routine that alternates between subtraction and addition, provided by GroovyBee in this thread. Update: The decision-tree routine was discussed in that same thread. Why not write up a benchmark and see? Both of those approaches should be faster, although I don't know by how much. PRNUM16 does have the benefit of being available and public domain. Most of the savings will be in replacing the repeated subtract, which already isn't terribly expensive as it repeats by powers of 10. It's 16 23 cycles per iteration plus 8 cycles fixup, so around 152 215 cycles for the worst-case digit. EDIT: Fixed some numbers above. Also: For Groovy's approach, his loop is 2 cycles faster than mine I believe, so 21 cycles/iter and less fixup means he'll be about 8-10% faster overall. The decision tree approach, if I recall correctly, was around 95 cycles for the worst case branch, so that'd be over 2x, but at a huge bloat in code size. Edited November 23, 2014 by intvnut Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted November 23, 2014 Share Posted November 23, 2014 Why not write up a benchmark and see? Both of those approaches should be faster, although I don't know by how much. PRNUM16 does have the benefit of being available and public domain. Most of the savings will be in replacing the repeated subtract, which already isn't terribly expensive as it repeats by powers of 10. It's 16 23 cycles per iteration plus 8 cycles fixup, so around 152 215 cycles for the worst-case digit. EDIT: Fixed some numbers above. Also: For Groovy's approach, his loop is 2 cycles faster than mine I believe, so 21 cycles/iter and less fixup means he'll be about 8-10% faster overall. The decision tree approach, if I recall correctly, was around 95 cycles for the worst case branch, so that'd be over 2x, but at a huge bloat in code size. Very interesting, thanks. Also, not to speak for GroovyBee, but presumably he posted that code in a public forum--with no explicit copyright claim--to make it available and public for others to use. My interest on this routines right now is because I'm working this week-end on the "Print Number" routine for P-Machinery v2.0. I was going to adapt the one I used in Christmas Carol, which in itself was adapted from Groovy's code on that thread (after a thorough explanation provided by catsfolly). However, I'll be interested in trying other approaches that may be faster. I'll try to benchmark all of them with some random numbers. I'm also interested in playing with the decision tree approach, but I'll have to dig deeper into it to understand it. I'm not too afraid of a "huge bloat in code size." Thanks, -dZ. 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 23, 2014 Share Posted November 23, 2014 Very interesting, thanks. Also, not to speak for GroovyBee, but presumably he posted that code in a public forum--with no explicit copyright claim--to make it available and public for others to use. My interest on this routines right now is because I'm working this week-end on the "Print Number" routine for P-Machinery v2.0. I was going to adapt the one I used in Christmas Carol, which in itself was adapted from Groovy's code on that thread (after a thorough explanation provided by catsfolly). However, I'll be interested in trying other approaches that may be faster. I'll try to benchmark all of them with some random numbers. I'm also interested in playing with the decision tree approach, but I'll have to dig deeper into it to understand it. I'm not too afraid of a "huge bloat in code size." Thanks, -dZ. Well, the divide-and-conquer tree based approach should be the fastest without hardware acceleration. If you want to provide left-justified, right-justified and leading-zero forms that'll obviously take some additional work. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted November 23, 2014 Share Posted November 23, 2014 Very interesting, thanks. Also, not to speak for GroovyBee, but presumably he posted that code in a public forum--with no explicit copyright claim--to make it available and public for others to use. Yep! Anybody can use it any project they like. Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted November 24, 2014 Share Posted November 24, 2014 Everyone wanted it, so now there is Intellivoice support using the VOICE statement, the library also provided by all-powerful intvnut. (note: not yet tested in real hardware, but it should work) I had someone with a CC3 test the Intellivoice code on a real console. "I tested on an Intellivision and an Intellivision II, with and without the Intellivoice attached. Didn't notice any crashing or anything unusual." Which means my Voice statements seemed to be nicely handled if the IntelliVoice module isn't plugged in; without me having to always check first. Well done. Also good news is that many of my voice commands were also recognizable as speech 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 24, 2014 Share Posted November 24, 2014 (edited) I had someone with a CC3 test the Intellivoice code on a real console. "I tested on an Intellivision and an Intellivision II, with and without the Intellivoice attached. Didn't notice any crashing or anything unusual." Which means my Voice statements seemed to be nicely handled if the IntelliVoice module isn't plugged in; without me having to always check first. Well done. Also good news is that many of my voice commands were also recognizable as speech Awesome. My Intellivoice driver is supposed to detect the Intellivoice on initialization, and if it doesn't see it, it silently drops all requests to play voices so that games can proceed unimpeded, just voiceless. While I've tested my original driver on real hardware—heck, it's in SG&R I'm pretty sure—it's good to see that the version in IntyBASIC retains this property. I'll try to benchmark all of them with some random numbers. I'm also interested in playing with the decision tree approach, but I'll have to dig deeper into it to understand it. I'm not too afraid of a "huge bloat in code size." Yeah, the decision tree code is pretty big. You and anyone else are welcome to use my code from the other thread for any purpose. The main "trick" in the code (aside from the decision tree itself) is using subtracts and adds to double as comparisons. (GroovyBee's non-restoring divide—the technical term for switching between add and subtract on alternate digits—also takes advantage of the flags set by ADD/SUB.) As I recall, my decision tree code is a restoring divide, meaning that if it goes down the wrong branch and takes too much off the remaining quotient, it'll restore the quotient. If you really want to blow up the code size, you could avoid restoration, and instead replicate the code with adjusted comparisons. For 5 digits, though, you could be looking at a 16x increase in size. As for benchmarking random numbers, you might try certain "endpoint numbers" such as 59999 and 1, which should be worst-case and best-case 16-bit numbers for iterative methods, and numbers like 11111, 22222, 33333, 44444, 55555, x6666, x7777, x8888, x9999 (where x could be any digit 0-5) to see how balanced the decision tree approach is. From a game performance point of view, worst-case performance is probably the main care-about. You don't want a sudden spike in cycles because you've decided to refresh the score on the screen. That's part of what makes the decision tree code attractive: Not only is the peak lower, but also the ratio of peak to best-case is lower too. FWIW, 4-Tris used a more primitive version of the PRNUM16 code (called DEC16), and it was never short on cycles despite updating the score once a frame every frame. (Recall, 4-Tris "animated" score updates by rolling the score upward like a pinball machine might.) EDIT: And if you really, really don't care about ROM size, check out the attached "stupid bindec" code. It runs crazy fast (314 cycles for any number) and could possibly be optimized a little further. But about that code-size... In case you're interested, the call to the function occurs at $5041, and the function itself resides at $5052. The function has a few... erm... data tables that reside... well, everywhere else. "We're going to need a bigger cartridge." stupid_bindec.zip Edited November 24, 2014 by intvnut 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted November 24, 2014 Share Posted November 24, 2014 My hacky BCD wannabe code (written entirely in BASIC) is also very fast, but consumes a fair bit of ROM (and RAM, for that matter). Which isn't much of a concern these days, but... to be honest GoatNom is past 36KB at this point and there's still a fair bit more to add. So I don't mind trimming that part out Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 24, 2014 Share Posted November 24, 2014 (edited) My hacky BCD wannabe code (written entirely in BASIC) is also very fast, but consumes a fair bit of ROM (and RAM, for that matter). Which isn't much of a concern these days, but... to be honest GoatNom is past 36KB at this point and there's still a fair bit more to add. So I don't mind trimming that part out My ROM up there is over 640kB and all it does it print a number.... But it's hella fast! Edited November 24, 2014 by intvnut Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted November 24, 2014 Share Posted November 24, 2014 My ROM up there is over 640kB and all it does it print a number.... But it's hella fast! 640K?! I think I can compromise on the speed a bit... 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 24, 2014 Share Posted November 24, 2014 640K?! I think I can compromise on the speed a bit... But... it's fast! Quote Link to comment Share on other sites More sharing options...
freewheel Posted November 24, 2014 Share Posted November 24, 2014 And it should be enough space for anyone. 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 24, 2014 Share Posted November 24, 2014 But... it's fast! And now 5% faster... An even 300 cycles. And it should be enough space for anyone. Indeed! You can tell just how efficient it is by the fact the ROM image compresses 98%. ;) stupid_bindec.zip Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 24, 2014 Author Share Posted November 24, 2014 I had someone with a CC3 test the Intellivoice code on a real console. "I tested on an Intellivision and an Intellivision II, with and without the Intellivoice attached. Didn't notice any crashing or anything unusual." Which means my Voice statements seemed to be nicely handled if the IntelliVoice module isn't plugged in; without me having to always check first. Well done. Also good news is that many of my voice commands were also recognizable as speech So cool! thanks for the test! Quote Link to comment Share on other sites More sharing options...
vazquezrick Posted November 25, 2014 Share Posted November 25, 2014 Hello all, I'm not new to the Intellivision but new to Intellivision programing. Is there a forum posting that outlines how to setup the compiler? Is there an IDE? Thanks. Rick Quote Link to comment Share on other sites More sharing options...
freewheel Posted November 25, 2014 Share Posted November 25, 2014 (edited) Hello all, I'm not new to the Intellivision but new to Intellivision programing. Is there a forum posting that outlines how to setup the compiler? Is there an IDE? Thanks. Rick There is no IDE as of yet. Basically the compiler is a command-line tool. If you're comfortable with the command line, it should be pretty straightforward to figure it out (and if you have problems with it, post your OS here and someone will surely be able to help). If you're not familiar with the command line, you're going to struggle a bit getting things set up. There is no way to work around the command line usage for the moment. In total there are 3 components you need here: the compiler (which you've found), the assembler (as1600), and the emulator (jzintv). You edit your source code in a text editor, compile with IntyBASIC, assemble with as1600, and run in jzintv. Many of us have written little command line scripts to automate this 3 step process - so you save your code and run a single command to run it, in essence. Here's the best thread I can find at the moment with links to the 3 major components: http://atariage.com/forums/topic/169024-programming-resources/ It's a bit dated however I don't think as1600 or jzintv need to be updated from that first post? Either way, we should use that first stickied post as a link to the current compiler and everything else. *me waves at GroovyBee* I just go straight the source for the assembler and emulator: http://spatula-city.org/~im14u2c/intv/ . They're both written by the same guy, so it's convenient that way Edited November 25, 2014 by freeweed Quote Link to comment Share on other sites More sharing options...
vazquezrick Posted November 25, 2014 Share Posted November 25, 2014 (edited) Thanks for the help. I would like to set up the compiler in Windows 7. Edited November 25, 2014 by vazquezrick Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 5, 2014 Author Share Posted December 5, 2014 Almost I've forgot it, the IntyColor utility now allows to generate BITMAP statements instead of DATA ones 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 15, 2014 Author Share Posted December 15, 2014 Just updated to IntyBASIC v1.0.1 Please check for changes in first post. 3 Quote Link to comment Share on other sites More sharing options...
intvnut Posted December 16, 2014 Share Posted December 16, 2014 (edited) BTW, freeweed's recent Crazybus post exposed a flaw in both jzIntv and the Intellivoice driver (and therefore IntyBASIC 1.0). :-) I've been testing a fix, and I think its gelled enough to share. Specifically: If you call VOICE INIT while the Intellivoice is speaking, you could crash the real Intellivoice. Here's the issue: Writing $0400 to location $0080 resets the speech buffer chip (SBP640). It only resets the speech buffer chip. It does not reset the actual speech chip (SP0256). In jzIntv, it resets both. The IV_INIT function blindly writes $0400 to $0080, and then does the rest of the initialization. If that happens while the speech chip expects more speech data from the speech FIFO.... Go directly to jail. Do not collect $200. Lose the next three turns. ... That is, the speech chip crashes, and it may not be recoverable without a hard reset on the Intellivision. So, I set about fixing IV_INIT in the intybasic_epilogue.asm. I modified freeweed's Crazybus to be even more crazy annoying, triggering VOICE INIT much more often, but still randomly. (Imagine the looks I got here at home. ) The new code seems clean. With this new version, VOICE INIT forcibly drops the contents of the software speech queue. It does, however, wait for any FIFOed sample to complete. And, it has some extra synchronization steps. Overall, it seems to work pretty well. Here's the modified IV_INIT code. You should be able to edit this into your intybasic_epilogue.asm if you need it. You only need it, though, if you call VOICE INIT more than once in your IntyBASIC program. ;; ======================================================================== ;; ;; NAME ;; ;; IV_INIT Initialize the Intellivoice ;; ;; ;; ;; AUTHOR ;; ;; Joseph Zbiciak <intvnut AT gmail.com> ;; ;; ;; ;; REVISION HISTORY ;; ;; 15-Sep-2002 Initial revision . . . . . . . . . . . J. Zbiciak ;; ;; 14-Dec-2014 Updated to allow INIT called anytime . J. Zbiciak ;; ;; ;; ;; INPUTS for IV_INIT ;; ;; R5 Return address ;; ;; ;; ;; OUTPUTS ;; ;; R0 0 if Intellivoice found, -1 if not. ;; ;; ;; ;; DESCRIPTION ;; ;; Initializes (or reinitializes) the Intellivoice. Note: Relies ;; ;; on memory holding the IV variables to be initialized to zero at ;; ;; reset. ;; ;; ;; ;; ------------------------------------------------------------------------ ;; ;; Copyright (c) 2002, Joseph Zbiciak ;; ;; ======================================================================== ;; IV_INIT PROC MVI IV.QH, R0 ; \ SWAP R0, 2 ; |- If there was none, there still BMI @@no_ivoice ; / is none. MVI $0081, R0 ; \ RLC R0, 2 ; |-- See if we detect Intellivoice BOV @@no_ivoice ; / ; Forcefully discard queued phrases that aren't spoken yet. DIS MVI IV.QT, R0 ANDI #7, R0 MVO R0, IV.QH CLRR R0 ; Kill the current phrase MVO R0, IV.PPTR EIS ; If the FIFO-data pointer is non-NULL, the Intellivoice is ; clearly already initialized. Skip the rest of this jazz. CMP IV.FPTR,R0 BNEQ @@done ; If Intellivoice is non-idle, it's already initialized and ; doing interesting stuff. Just leave. @@ready: MVI $80, R0 ; Get w/ ALD status. 1 == ready SLLC R0 BNC @@done ; Play a silent sample MVII #5, R0 ; Short silent sample MVO R0, $80 ; Say it ; Wait for it to start (which means no data remains in FIFO) @@ready2: MVI $80, R0 ; Get w/ ALD status. 1 == ready SLLC R0 BNC @@ready2 MVII #$0400, R0 ; MVO R0, $0081 ; Reset the Speech Buffer Chip CLRR R0 ; MVO R0, IV.FPTR ; No data for FIFO MVO R0, IV.PPTR ; No phrase being spoken NOP MVO R0, IV.QH ; Clear our queue MVO R0, IV.QT ; Clear our queue @@done: JR R5 ; Done! @@no_ivoice: CLRR R0 MVO R0, IV.FPTR ; No data for FIFO MVO R0, IV.PPTR ; No phrase being spoken DECR R0 MVO R0, IV.QH ; Set queue to -1 ("No Intellivoice") MVO R0, IV.QT ; Set queue to -1 ("No Intellivoice") JR R5 ; Done! ENDP Edited December 16, 2014 by intvnut 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted December 16, 2014 Share Posted December 16, 2014 Yeah, intvnut and I chatted about this. Basically you can avoid this by simply calling VOICE INIT only once (initialization stage of the program makes the most sense). However to prevent newbie coders from breaking things, we either need that very well documented in the manual, or better, the "official" epilogue.asm fixed. IntyBASIC is extremely forgiving with structure and I can see people messing this up (I did on the first program I wrote that was tested on real hardware, ha-ha). 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 16, 2014 Author Share Posted December 16, 2014 Truth to be told I'm surprised by the bug Good to have it reported here, and I'll put this in the intybasic_epilogue.asm 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted December 16, 2014 Share Posted December 16, 2014 Truth to be told I'm surprised by the bug Good to have it reported here, and I'll put this in the intybasic_epilogue.asm I was surprised too. And just to be sure, I went ahead and tested it with two different Intellivoices with widely spaced serial numbers, to see if there was a change in Intellivoice behavior on the unit I had reverse engineered years ago vs. the unit currently installed on my bench system. Both behaved about the same. They also behave in line with what's described in the now-available documentation on PapaIntellivision. I had honestly never tested calling IV_INIT randomly. I always just called it once at the 'beginning of time' and it worked as expected. Now it's considerably more robust. You can do VOICE INIT to kill everything queued up, which is a reasonable thing to do in certain game circumstances. (Like, for example, your ship blows up and its game over.) 1 Quote Link to comment Share on other sites More sharing options...
