chrispitude Posted December 28, 2014 Share Posted December 28, 2014 I have an Xtension upright arcade cabinet from Rec Room Masters. It uses an X-Arcade Tankstick for control. Stella works extremely well with the Tankstick's default MAME keyboard mapping, if you do the following: Use Stella 4.5-beta2 or later. You can find the beta2 build attached to this post. In Options > Input Settings > Devices & Ports, deselect the "Use Control key combos" checkbox item. This allows 2-player games to work without the Tankstick's P1 key mappings triggering various control-key sequences in Stella. In Options > Input Settings > UI Events, change the Move Up, Move Down, Page Up, Page Down, and Select item actions to the Tankstick events of your choice. I use the left joystick for up/down, the right joystick as page up/down, and the left-side primary button for item select. In Options > UI Settings > Misc., change the "List quick delay" drop-down to Disabled. (This requires a restart to take effect.) This allows your event mappings from the previous item to work properly without attempting to snap the game list to that letter/number. Stella uses the trackball as the P1 analog paddle, but it's not very sensitive by default. In Options > Input Settings > Devices & Ports, increase the "Mouse paddle sensitivity" to 15. I hope this is helpful! 2 Quote Link to comment Share on other sites More sharing options...
+stephena Posted December 28, 2014 Share Posted December 28, 2014 Good to see that the changes we've discussed over the past few weeks have been useful. Quote Link to comment Share on other sites More sharing options...
chrispitude Posted December 28, 2014 Author Share Posted December 28, 2014 Good to see that the changes we've discussed over the past few weeks have been useful. They work perfectly! It's now a flawless experience with the Tankstick. Even my four-year-old is able to select and change games by himself now. Thank you so much! Quote Link to comment Share on other sites More sharing options...
