madgitty Posted January 12, 2015 Share Posted January 12, 2015 Hi Has anyone got copy2000 in atr format please thanks Quote Link to comment Share on other sites More sharing options...
Madi Posted January 12, 2015 Share Posted January 12, 2015 Here you go madi copy2000.atr 1 Quote Link to comment Share on other sites More sharing options...
madgitty Posted January 13, 2015 Author Share Posted January 13, 2015 many thanks Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted January 13, 2015 Share Posted January 13, 2015 (edited) Well, there is more than one version of Copy 2000. Afaik, all versions prior to version 2.41 are buggy, so do not use them. Version 2.41D reads/formats/writes 90k/130k/180k with a standard drive (without any speeder) or with an ultraspeed drive that is compatible to Speedy 1050 (will not format on a Happy drive; may or may not format on a USD drive; will format on a Hyper-XF drive, but write only in slow mode). The program was originally written for the german Floppy-2000 drive which had a built-in Speedy enhancement (and this program in ROM). Version 2.51Q does the same but with 90k/130k/180k/360k - it can read the 360k/DSDD XF551 format, but it does not write the XF551 360k format (the difference here is the handling of the backside, Copy 2000 writes the backside of a 360k disk in the opposite way the XF551 does, so don`t use Copy 2000 2.51Q with an XF551 drive...) Copy 2000 is reset-proof, press Reset and it will re-initialize the drives (which is handy, if you added a new drive). To do a coldstart press SHIFT+Control+TAB. To make additional copies if the source is completely in RAM press the Option key. If drive 2 also has a Speedy enhancement, it will format the disk in drive 2 while drive 1 is still reading the disk. Afaik, Copy 2000 works with 64k RAM / 128k RAM / 256k RAM / 320k-Compyshop and 1088k-K.Peters-Megaram-3 RAM enhancements, but I am not absolutely sure. With an U1MB or other 1MB RAM enhancements (as well as 2MB, 4MB, 8MB and 16MB RAM enhancements) it may show "weird" things, so use it at your own risk there... COPY2000.zip Edited January 13, 2015 by CharlieChaplin Quote Link to comment Share on other sites More sharing options...
