chart45 Posted September 11, 2016 Author Share Posted September 11, 2016 I just downloaded and installed the latest version of the Maxflash Studio Software which is now at v2.9. I see that Steve has now added support for dumping "Activision banked cartridges (64kB)" as well as an interestingly named new feature, "Start Connection Assistance LED". I've asked Steve what this feature does over in the AtariMax forums but thought I'd also ask the question here in case someone knows. thanks i can now play boxxel in coolcv but is there some plan to be able to play those rom in the atarimax sd? Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted September 11, 2016 Share Posted September 11, 2016 thanks i can now play boxxel in coolcv but is there some plan to be able to play those rom in the atarimax sd? Yes - apparently beta firmware supporting the Activision PCB roms is available from Steve - http://www.atarimax.com/flashcart/forum/viewtopic.php?f=15&t=974 Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted September 11, 2016 Share Posted September 11, 2016 Yes - apparently beta firmware supporting the Activision PCB roms is available from Steve - http://www.atarimax.com/flashcart/forum/viewtopic.php?f=15&t=974 Yep, and the EEPROM savegame feature is not supported, only the 64K bankswitching, according to the forum post linked above. Quote Link to comment Share on other sites More sharing options...
NIAD Posted September 12, 2016 Share Posted September 12, 2016 Pixelboy is correct, the only EEPROM savegame feature that is supported by the AtariMax Ultimate SD Cart is for "Lord of the Dungeon". You can play The Black Onyx and Boxxle, but your data will not be saved. Quote Link to comment Share on other sites More sharing options...
Ikrananka Posted September 16, 2016 Share Posted September 16, 2016 Steve gave me a little info about the new LED connection assistance feature" "There are a few new cartridges that have split power/ground pins and have issues connecting properly with the edge connector on the adapter (or even in the consoles for some people). This feature will cause the LED on the interface to only illuminate once all the pins are making good contact. Once the LED is lit in this mode, go ahead and try to perform the dump." So, plug in the programmer to your computer, select the "Start Connection LED Assistance" feature in the MaxFlash Studio software and the programmers LED will start to slowly blink. Plug in a cart to the adapter and only when the LED stays on continuously is the cart properly connected and recognised and ready for dumping. Quote Link to comment Share on other sites More sharing options...
