Create and burn eproms for standard Jaguar 2 chip cartridges
89 replies to this topic
#51 af0l OFFLINE
af0l
    Moonsweeper
  • 272 posts
Posted Fri Jan 26, 2018 5:48 AM
No, I actually meant 93C46, for high scores, savegames and such. I've got 27C160 down :)
#52 santosp OFFLINE
santosp
    Dragonstomper
  • 787 posts
Posted Fri Jan 26, 2018 5:59 AM
Ah ok then.
Hmmm, I don't know if the higher numbers are compatible.🤔
#53 Zerosquare OFFLINE
Zerosquare
  • 2,752 posts
Posted Fri Jan 26, 2018 9:54 AM
They're not.
#54 af0l OFFLINE
af0l
    Moonsweeper
  • 272 posts
Posted Fri Jan 26, 2018 11:05 AM
They're not.
So, BSG has 2k EEPROM, and all the others (except some of CJ's ports) use the 128b ones?
#55 Zerosquare OFFLINE
Zerosquare
  • 2,752 posts
Posted Fri Jan 26, 2018 11:09 AM
Yes.
#56 ArcadeJunkie OFFLINE
ArcadeJunkie
    Moonsweeper
  • 318 posts
  • Respect your digital roots....
Posted Sat Feb 3, 2018 2:28 PM
Would someone be willing to burn the eproms and sell them?
#57 madman OFFLINE
madman
  • 2,818 posts
Posted Sat Feb 3, 2018 3:37 PM
That's when you start to get into a bit of a grey area around here.
#58 rayik OFFLINE
rayik
    Moonsweeper
  • 421 posts
Posted Sat Feb 3, 2018 7:23 PM
I posted so everyone could make their own carts. While I'm sure there are people using this to make and sell, with this knowledge you don't need to be buying from them on ebay. Try making some yourself.
#59 ArcadeJunkie OFFLINE
ArcadeJunkie
    Moonsweeper
  • 318 posts
Posted Mon Feb 5, 2018 9:37 PM
These would really be only for personal use. I'm just trying to see if there is a second option in case I can't accomplish this myself. I don't endorse anything that would degrade the hobby.
#60 Wyluli Wolf OFFLINE
Wyluli Wolf
    Moonsweeper
  • 389 posts
Posted Thu Feb 8, 2018 11:47 AM
You should be able to figure it out but feel free to post questions if you run into trouble.  If you don't want to de-solder used boards to reuse I sell new Jag PCBs for $6.50 each.
#61 icemanxp300 OFFLINE
icemanxp300
  • 4,759 posts
Posted Mon Aug 27, 2018 11:19 PM
Ok I need to post this.
Let me just say you are better off changing any .j64 extension to .rom, trust me it does make a difference!!
Take your .j64 file and rename it to .rom, split it and then program it. This information should be extremely helpful.
While some games will program and run as a .j64 some or at least one will NOT!
#62 UHATEIT OFFLINE
UHATEIT
    Dragonstomper
  • 592 posts
Posted Tue Aug 28, 2018 11:07 AM
I had found that out a while ago when I wasn;t getting any of the roms to show up in Skunkgui to load onto a skunk. Changing from .j64 to .rom fixed all of them!
#63 rayik OFFLINE
rayik
    Moonsweeper
  • 421 posts
Posted Sat Oct 20, 2018 8:06 AM
I finally purchased a Hakko FR-301 desoldering iron.  If you can afford it, I highly recommend you desolder using that rather than a Souldault.  Including time learning to use the tool, it took me about 45 minutes to remove chips from 40 pcbs.  You will save a lot of time and effort with the FR-301.
It is so easy to use and does such a good job, I had a lot of chips just falling out from the pcb.  Pics are example of how good it desolders.
#64 Stephen OFFLINE
Stephen
  • 7,366 posts
  • A8 Gear Head
Posted Sat Oct 20, 2018 5:31 PM
Yep - I think that is the replacement for my discontinued Hakko 808.  I love the thing.  Desolder 40 in dips in under a minute, and like you said, they just fall out of the boards.
#65 RobPattonDotCom OFFLINE
RobPattonDotCom
    Star Raider
  • 67 posts
Posted Mon Dec 3, 2018 7:37 PM
Could someone post a high and low rom image set to be burned, I have all the needed parts, but i'd like to prove I can make the 2nd half work before I take off upon the file processing part of it.
Thanks
#66 RobPattonDotCom OFFLINE
RobPattonDotCom
    Star Raider
  • 67 posts
Posted Fri Jan 11, 2019 5:10 PM
Ok, I gave it a go on my own, but never got more than the jag red screen of death.   Do I understand that its fine to use M27C160? Is there anything special?   I guess since I've done all the steps, I'm not sure which of the steps I've messed up.
Is there anyone that can give me a set of hi/lo that are tested, just so I can confirm I'm STARTING with something good?  I cut up a raiden rom, since I own several copies, I figure I'm good to do what I want for non commercial reasons
I'm really tired of soldering and unsoldering. I need to find zif sockets for these!  Has anyone done that?
#67 rayik OFFLINE
rayik
    Moonsweeper
  • 421 posts
Posted Fri Jan 11, 2019 9:20 PM
I'd recommend you socket at least one board. After burning ROMs use the socketed board to make sure they work before you solder them in. I also found that a small percentage of boards are just bad.
#68 oracle_jedi OFFLINE
oracle_jedi
    Moonsweeper
  • 495 posts
  • Nothing to Declare
Posted Fri Jan 11, 2019 10:59 PM
Attached are the Tube SE ROMs with appropriate encryption header.  AFAIK its okay to distribute these.
I have burned these to 27C160 ROMs and have a working cart of the game, so these do work.
As Rayik suggests, I have an uncased prototype board with sockets to test ROMs before soldering them to a unsocketed board and putting them in a case.
Good luck.
#69 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,074 posts
Posted Sat Jan 12, 2019 7:32 PM
Is there an alternative to romsplit? All of my pcs are windows 64 bit and I cant get the program to run as it is 32 bit only. Currently I have most of my games already split (somebody gave me the the hi and lo files for 2 chip boards) but I would like to be able to split the files without having to share with somebody else.
I could just get an older windows xp 32 bit laptop just for this, but I was hoping there may be another way.
Thanks
#70 rayik OFFLINE
rayik
    Moonsweeper
  • 421 posts
Posted Sat Jan 12, 2019 8:10 PM
Thanks
Use DosBox on your 64bit win machine. See here
#71 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,074 posts
Posted Sat Jan 12, 2019 8:31 PM
Thank You
#72 LinkoVitch OFFLINE
LinkoVitch
  • 2,601 posts
Posted Sun Jan 13, 2019 6:25 AM
Thanks
They are not difficult to write, just code one up for your purposes, should take only 10-15 minutes to write from scratch in pretty much any native PC based language (C, C++, C#, PHP, Python, JAVA etc), choose your preferred language and just write it.
#73 omf OFFLINE
omf
    Dragonstomper
  • 783 posts
Posted Sun Jan 13, 2019 2:42 PM
Ahh, you must mean one of these:
#74 CyranoJ ONLINE
CyranoJ
    RAPTOR Wrangler
  • 5,602 posts
  • reBOOTed
Posted Sun Jan 13, 2019 2:49 PM
This is a video tutorial
How to ROM split
#75 RobPattonDotCom OFFLINE
RobPattonDotCom
    Star Raider
  • 67 posts
Posted Sun Jan 13, 2019 10:04 PM
Good luck.
I have had a heck of a time finding the correct sockets for these boards, I keep smaller, up to 40pin, but nothing 42.    Does https://www.mouser.c.../XorZIrGZxBfeI=seem correct?
I've burned the posted sample, guess I'll try them after work on day this week and see if I can some success...
