compiling on linux give unknown symbol for CLEAR_STACK
unknown symbol CLEAR_STACK linux compile
15 replies to this topic
#1 rawbits OFFLINE
rawbits
    Space Invader
  • 14 posts
Posted Tue Mar 10, 2015 1:59 PM
Hi All! You are my last hope here.
I try to compile a small test program using the CLEAN_START macro from macro.h (v1.06) but it gives me unresolved symbole for CLEAR_STACK in it. I'm using the latest x86-64 release of DASM 2.20.11 from the WUDSN pack. Which BTW seems to bee the latest stable release. (Yeah I know, but I use Eclipse for everything...except for linux. Linux is always problematic.)
If I take out the CLEAN_START macro it's working fine. Directly copy&paste it also not works, took out the '.' so it uses global label and now it complains about CLEAN_START itself.
I'm using these things for about 6 years now on Windows and I'm programming 8-bit assembly since '91 - but I can overlook anything ofcourse. Please help! I feel very lost now. :(
Tell me if you need more information.
#2 Andrew Davie OFFLINE
Andrew Davie
  • 1,836 posts
  • Dr.Boo
Posted Tue Mar 10, 2015 11:18 PM
Please post a minimal "non-working" example, so that we can help you out. Pretty difficult to diagnose from the information you have given.
Have you included " processor 6502" at the start?
Have you included an org statement before calling the macro?
#3 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,684 posts
  • Medieval Mayhem
Posted Wed Mar 11, 2015 8:58 AM
When doing a reply you'll need to click "More Reply Options" down there in the bottom right to access the file attachment options.  Use those options to attach your source code file.
#4 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,972 posts
  • Always left from right here!
Posted Wed Mar 11, 2015 10:13 AM
Or may you simply misspelled CLEAR_START as CLEAR_STACK like the error says? :ponder:
#5 rawbits OFFLINE
rawbits
    Space Invader
  • 14 posts
Posted Wed Mar 11, 2015 3:33 PM
Here is what I get in the console. And I hope I attached the source of a basic kernel with the CLEAN_START marco called. I didn't tried this particular file on Windows but the code worked before.
Compiling for hardware ATARI2600 on 2015.03.11. 19:46: /home/rawbits/BitProcessors/ASM/DASM/bin/dasm.linux-x86-64 /home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm -o/home/rawbits/RustyBits/Atari2600/example.bin -f3 -v5 -l/home/rawbits/RustyBits/Atari2600/example.lst
Compiler 'DASM' output:
START OF PASS: 1
SEGMENT NAME                 INIT PC  INIT RPC FINAL PC FINAL RPC
                             f000                            f000
INITIAL CODE SEGMENT         0000 ????                       0000 ????
1 references to unknown symbols.
1 events requiring another assembler pass.
 - Expression in mnemonic not resolved.
--- Unresolved Symbol List
1.CLEAR_STACK            0000 ????         (R )
--- 1 Unresolved Symbol
Unrecoverable error(s) in pass, aborting assembly!
Running 'Stella': /usr/local/bin/stella /home/rawbits/RustyBits/Atari2600/example.bin
Application returned with exit code 0.
#6 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,972 posts
Posted Wed Mar 11, 2015 4:05 PM
Weird.
.CLEAR_STACK (note the dot before) is a local label inside the CLEAN_START macro. Have you checked the macro and made sure that CLEAR_STACK is written with a dot in both cases?
#7 Andrew Davie OFFLINE
Andrew Davie
  • 1,836 posts
  • Dr.Boo
Posted Thu Mar 12, 2015 7:00 AM
I suggest you turn on listing output, then let us see what's actually happening.
I wonder if it might be a CR/LF issue....?  Something strange is happening inside that macro. Please post the macro.h file, too.
I see you already generate a list file. Post it!!
Thanks
A
#8 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,972 posts
Posted Thu Mar 12, 2015 8:32 AM
Good catch! Assembling files on a Windows OS without CR/LF makes DASM freak out pretty unpredictable.
#9 rawbits OFFLINE
rawbits
    Space Invader
  • 14 posts
Posted Thu Mar 12, 2015 12:50 PM
It works fine on Windows as everything always. Linux is the one having the problematic cases and struggle like this time.
It seems, it is finding some strange bytes in that macro though. (had to rename 'cause site didn't let me upload)
#10 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,972 posts
Posted Thu Mar 12, 2015 1:36 PM
CLEAN_START macro looks fine to me.
Have you tried any of the other macros from macro.h? Do they show the same problem? If yes, maybe you have to replace the two byte Windows CR/LF (0x0d/0x0a) with the single byte Linux LF (0x0a).
#11 Andrew Davie OFFLINE
Andrew Davie
  • 1,836 posts
  • Dr.Boo
Posted Thu Mar 12, 2015 2:18 PM
      5  0000 ????
      6  0000 ????				      SEG
      7  f000					      ORG	$F000
      8  f000
      9  f000				   Reset
     10  f000
      0  f000					      CLEAN_START
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic '\F84@'.
      1  f000					      \F84@
      2  f000
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic '5@'.
      3  f000					      5@
      4  f000		       a2 00		      ldx	#0
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic 'P5@'.
      5  f000					      P5@
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic 'h5@'.
      6  f000					      h5@
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic ' 5@'.
      7  f000				   .CLEAR_STACK  5@
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic '\985@'.
      8  f000					      \985@
/home/rawbits/BitWaste/Atari2600/Scene_examples/example.asm (11): error: Unknown Mnemonic '\C05@'.
      9  f000					      \C05@
     10  f002		       d0 00		      bne	.CLEAR_STACK
     11  f004
Given the above errors in the listing file, it looks pretty certain to me that there are encoding problems in the macro.h file.
I would grab a clean one from somewhere else and try that.
Cheers
A
#12 rawbits OFFLINE
rawbits
    Space Invader
  • 14 posts
Posted Thu Mar 12, 2015 3:11 PM
But from where? Also it's working on Windows. And why the vcs.h works? They are from the same place btw and I use them some years now.
I didn't tried others. Will try them soon. Yes, I have tried to save them with only LF line ending and also with different encodings.
#13 RevEng OFFLINE
RevEng
    Bit Player
  • 5,169 posts
Posted Thu Mar 12, 2015 8:11 PM
I think possibly its your "different encodings". I've been using the DASM under Linux for years, and don't have a problem with my macro.h, which I just confirmed has DOS style newlines. The macro file should be encoded as US-ASCII, but unless something weird happened, it should have been so in the first place.
If all else fails, download the latest bB and extract the macro.h from there, as-is. That's the one I've been using. If the problem persists, use the dasm from there too, though it's identical to the latest SourceForge binary package.
#14 Andrew Davie OFFLINE
Andrew Davie
  • 1,836 posts
  • Dr.Boo
Posted Fri Mar 13, 2015 3:03 AM
A look at the binary version of the macro.h file you posted, particularly around the macro, doesn't show any problems.  It has 0D/0A pairs as expected.
So, I now think you have a dud assembler. It looks like you're running a 64 bit linux version. I recall 64 bit code being dodgy due to the really really dodgy C in DASM.
Switch to the 32 bit version and I bet all your problems disappear.
Cheers
A
#15 RevEng OFFLINE
RevEng
    Bit Player
  • 5,169 posts
Posted Fri Mar 13, 2015 6:38 AM
I just confirmed that the version of DASM in the WUDSN compilers package is the older 2.20.11, before we added various fixes, including 64-bit fixes. If I use the 64-bit WUDSN one to assemble with CLEAN_START (or anything for that matter) I get a segfault partway through. If I use the post-fixed 64-bit dasm, it works fine for me.
I've sent JAC! a PM with the info so he can update the WUDSN compiler package.
#16 rawbits OFFLINE
rawbits
    Space Invader
  • 14 posts
Posted Sat Mar 14, 2015 4:40 AM
You are a real hero! :) Thanks! Just compiled the 2014.03.04 source and it works perfectly. BTW versioning is gay or what?
Thank you all for the answers! You are an awesome community to help me this quick.
Also tagged with one or more of these keywords: unknown symbol, CLEAR_STACK, linux, compile
