Wedsau Posted March 12, 2015 Share Posted March 12, 2015 Hey all, I was wondering if you could help me with a technical problem. I just got a Colecovision at a consignment store today and I'm having trouble getting it to display properly on my TV screen. The problem, I believe, has something to do with the AV cable that connects to the TV. Usually, it shows static, but when I jiggle it around, the Coleco log and title screen flash briefly across the screen. The AV cable I am using now(that came with the system) is actually an NES cable. Is this probabaly whats causng the problem? Would I be better off buying a cable specifically for the Coleco, or are there other more readily available replacements that would work just as well? Thanks, -Wedsau Quote Link to comment Share on other sites More sharing options...
Shmup Lover Posted March 12, 2015 Share Posted March 12, 2015 By moving it around, can you move it slowly that you can get it to stay on? Never tried an NES RF on the CV, sounds possible, perhaps someone else can weigh in on this. Maybe a quick spray of electronics contact cleaner on the end of the cable and plug and unplug a few times might be a quick fix? First post btw, welcome! Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted March 12, 2015 Share Posted March 12, 2015 (edited) NO NES (also Genesis) RF cables are of no use with consoles popular before NES hit the market. Nes uses and autos switching RF box, older consoles and computers do not have the proper output to properly switch the signal over fully which is why you get a very grainy / staticy picture at best. You need the older type with manual switcher as found on Colecovision / 2600 etc OR a basic RF cable without the switcher at all but instead plugged into a RF to Coaxial adapter to plug in directly. Edited March 12, 2015 by OldSchoolRetroGamer Quote Link to comment Share on other sites More sharing options...
Shmup Lover Posted March 12, 2015 Share Posted March 12, 2015 Those little RF coax adapters are really nice. Wish they would have had them back in the day. Quote Link to comment Share on other sites More sharing options...
Wedsau Posted March 13, 2015 Author Share Posted March 13, 2015 Thanks guys. I do have an Atari switchbox. I hooked it up with some spare DVD wires I had lying around, and now the image displays fine, but there is an awful buzzing sound in the background. You said a coaxial adapter might help? Like these two? http://www.walmart.com/ip/RCA-3-Y-Adapter/16829790 http://www.ebay.com/itm/CBS-Colecovision-Konsolen-Av-Kabel-Controller-Donkey-Kong-Netzteil-/331500119417?pt=DE_Kabel_Adapter&hash=item4d2ef26579 Thanks again. Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted March 13, 2015 Share Posted March 13, 2015 (edited) You can do one of two things. http://www.atariage.com/howto/connect.html 1. Purchase one of these Female RCA to Male Coax connectors. Then you'll also need an old school RF cable. Using a regular RCA/composite cable would work, but it looks like garbage, or in your case, will sound terrible. They're not made for RF signals. 2. The other option is to purchase a Male RCA to Female Coax adapter. RadioShack has them, too. This will allow you to hook a standard coaxial cable (available in Radioshack, Home Depot, Walmart, etc.) from your TV's RF port to the adapter. The adapter plugs into the system. Most everyone does option 1 because they have an old RF cable with a system. Option 2 is probably better if you can use professional grade coax cables, which is why I always keep extra cabling that Fios leaves me! Edited March 13, 2015 by Greg2600 1 Quote Link to comment Share on other sites More sharing options...
Wedsau Posted March 16, 2015 Author Share Posted March 16, 2015 Thanks for the tip, and the welcome! I'll try to get one of those so I can play Coleco without having the mute on. Quote Link to comment Share on other sites More sharing options...
