Gazoo Posted April 8, 2015 Share Posted April 8, 2015 Lowly Gazoo? You've always been "The Great Gazoo" to me! Being able to call TML from a running program could have it's advantages. Suppose you wanted a LOAD program to load and activate TML, then run an XB program, such as this: 10 CALL TML::RUN "DSK1.PROGRAM" !must be in same line as CALL TML When it starts, TML erases the XB program, but it should finish the line it is running. Not sure if CALL TML in the middle of a program would crash or just exit to the command line. Well, your example does work. As you know I've tested it. It causes a screen glitch but works otherwise. But only in a real short program such as the one you listed. My preference is to not allow the user to f--k things up. That's why I put in the 'Rules'. A CALL TML crashing would depend on the size of the program. The one in the example that runs another program right off the bat would always work. But there would be a case where it wouldn't and someone would call it a 'bug' and complain to all hell about what a POS software this is. And then I'd have to kill him, and we'd have a real mess with the police showing up and all that crap. So should we take our chances on people using the software conscientiously and not complaining, or do I take out the 'Don't do that, stupid!' error checking, and go to the electric chair? Gazoo 1 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted April 8, 2015 Share Posted April 8, 2015 Actually, your last set of comments makes a nice tongue-in-cheek introduction to the capabilities of this fine product, Gazoo. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted April 8, 2015 Share Posted April 8, 2015 The Great Gazoo with a healthy collection of new avatars, no less! 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted April 8, 2015 Share Posted April 8, 2015 Well, your example does work. As you know I've tested it. It causes a screen glitch but works otherwise. But only in a real short program such as the one you listed. My preference is to not allow the user to f--k things up. That's why I put in the 'Rules'. A CALL TML crashing would depend on the size of the program. The one in the example that runs another program right off the bat would always work. But there would be a case where it wouldn't and someone would call it a 'bug' and complain to all hell about what a POS software this is. And then I'd have to kill him, and we'd have a real mess with the police showing up and all that crap. So should we take our chances on people using the software conscientiously and not complaining, or do I take out the 'Don't do that, stupid!' error checking, and go to the electric chair? Gazoo Imagine a menu program that lets you choose from several programs, some written in standard XB and some requiring The Missing Link. It would be nice to be able to have the program load and activate TML, then run the program. Those color blotches happen when you run the TML loader and then run a program from that. I wish it didn't happen, but don't think it is all that troubling. My loader for TML will erase itself when it activates TML and then finish up the line it is running before exiting the program. You do not have CALL TML erase the program because there is no program to erase. One advantage of this is that if you started writing a program and then realized you forgot to load TML you can do it without erasing your work. There is no way you can start up a program in XB, then CALL TML and expect the program to continue, other than something simple like RUN "DSK1.Program" in the same line. Have you experienced crashing when CALL TML is in a program? The few tests I did just spit out an error message, but not what I would call a crash. And for what it's worth, I don't think you have to worry about riding the lightning. With the amount of time we spend on this foolishness, I'm sure an insanity plea would be successful! 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 8, 2015 Share Posted April 8, 2015 (edited) RXB 5.55 used to have a Phoney DSK DSR to save and load program from lower 8K, but could be installed at upper 24K and change the pointers to leave it there. Only difference was I put this into GRAM and made it a GRAM disk, but if you changed a pointer could be used in RAM or VDP too. Here is the original program that may solve your problem. 100 !Saved program will stay in memory as long as you do not CALL INIT or turn memory expansion off. 110 !It will ever stay in memory when switching cartrides with a WIDGET. 200 CALL CLEAR 220 CALL CHAR(42,"AA55AA55AA55AA55",91,"7E8199A1A199817E") 230 CALL CHAR(45,RPT$("0",&"FF"&RPT$("0",10)&"10387CFEFE") 240 CALL CLEAR :: CALL HCHAR(2,4,42,26) 250 CALL VCHAR(3,4,42,5) :: CALL VCHAR(3,29,42,5) 260 DISPLAY AT(5,9)SIZE(12):"RAM-DISKETTE" 270 CALL HCHAR(8,4,42,26) 280 DISPLAY AT(12,4):"[ MARTIN KOTULLA 1985" 290 CALL HCHAR(13,6,45,22) :: DISPLAY AT(17,7):"DATAs CHECK? Y" 295 DISPLAY AT(20,4):"CALL LINK("SAVE") store prog" 296 DISPLAY AT(22,4):"CALL LINK("LOAD") retrieve" 300 ACCEPT AT(17,22)BEEPSIZE(-1)VALIDATE("YN"):JN$ 310 IF JN$="N" THEN 360 320 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: SUM=SUM+A+B :: NEXT I 330 DISPLAY AT(20,5):"THE DATA-LINES ARE" 340 IF SUM<>20638 THEN DISPLAY AT(22,10):"INCORRECT!" :: END 350 DISPLAY AT(22,11):"CORRECT!" 360 CALL INIT :: RESTORE 370 FOR I=8192 TO 8458 STEP 2 :: READ A,B :: CALL LOAD(I,A,B) :: NEXT I 380 CALL CLEAR :: STOP 390 DATA 032,068,255,255,000,000,170,085,000,000,041,097,032,056,033,126 400 DATA 032,056,033,226,032,056,035,076,032,056,036,050,032,056,036,110 410 DATA 032,056,036,132,032,056,036,144,247,147,248,118,255,231,247,146 420 DATA 255,255,076,079,065,068,032,032,032,196,083,065,086,069,032,032 430 DATA 032,122,000,000,002,001,032,050,002,129,032,066,027,014,192,001 440 DATA 002,002,131,074,140,176,022,006,140,176,022,004,140,176,022,002 450 DATA 192,048,004,080,002,033,000,008,016,239,002,000,037,000,200,000 460 DATA 131,034,002,224,131,224,004,096,000,206,002,224,032,008,192,032 470 DATA 131,132,096,032,131,048,002,032,033,012,002,128,064,000,026,003 480 DATA 002,000,011,000,016,236,007,032,032,048,192,032,131,048,002,001 490 DATA 033,012,220,112,136,000,131,132,018,252,200,032,131,048,032,040 500 DATA 200,032,131,050,032,042,200,032,131,132,032,044,200,032,131,134 510 DATA 032,046,016,029,002,224,032,008,200,032,032,048,032,048,022,003 520 DATA 002,000,029,000,016,204,192,032,032,040,002,001,033,012,220,049 530 DATA 136,000,032,044,018,252,200,032,032,040,131,048,200,032,032,042 540 DATA 131,050,200,032,032,044,131,132,200,032,032,046,131,134,004,192 550 DATA 216,000,131,124,002,224,131,224,004,096,000,112 560 END Edited April 8, 2015 by RXB 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 8, 2015 Share Posted April 8, 2015 This is fantastic, I definitely want to make a cart for myself on this one. TML was always my favorite extension back in the day, it's awesome that we have new versions kicking around. Quote Link to comment Share on other sites More sharing options...
JamesD Posted April 8, 2015 Author Share Posted April 8, 2015 Awesome work! If I had known someone could implement this so fast I probably would have asked sooner.But seeing as how I only used TML for the first time for drawing the Fedora image plot a few weeks ago it wouldn't have made much difference. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 8, 2015 Share Posted April 8, 2015 Tested with the only app I still have (my old TMNT game), and it works fine, although I had to make a slight change to the start up code. (Nothing wrong with TML - the code installed a sample audio playback by overwriting one of TML's functions, and it turns out that they moved around a bit and it now overwrites one it needs ). 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 8, 2015 Share Posted April 8, 2015 TEENAGE MUTANT NINJA TURTLES game on the TI?!?!?! Wha.whaaaaat?? 1 Quote Link to comment Share on other sites More sharing options...
Gazoo Posted April 8, 2015 Share Posted April 8, 2015 (edited) Imagine a menu program that lets you choose from several programs, some written in standard XB and some requiring The Missing Link. It would be nice to be able to have the program load and activate TML, then run the program. Those color blotches happen when you run the TML loader and then run a program from that. I wish it didn't happen, but don't think it is all that troubling. My loader for TML will erase itself when it activates TML and then finish up the line it is running before exiting the program. You do not have CALL TML erase the program because there is no program to erase. One advantage of this is that if you started writing a program and then realized you forgot to load TML you can do it without erasing your work. There is no way you can start up a program in XB, then CALL TML and expect the program to continue, other than something simple like RUN "DSK1.Program" in the same line. Have you experienced crashing when CALL TML is in a program? The few tests I did just spit out an error message, but not what I would call a crash. And for what it's worth, I don't think you have to worry about riding the lightning. With the amount of time we spend on this foolishness, I'm sure an insanity plea would be successful! Ok, I took out the requirement of not being able to use a CALL TML(xxx) in a program. The Grom file to do so is attached to this message. Be aware that if you already have TML loaded and do a CALL TML(xxx) in a program, the error routine that TML is already loaded will kick in, and not in a good way as you will be joining Peter Pan in never-never land. Gazoo [DELETED attachment=386821:XBtmlOKinPROGRAMg.bin] Edited April 9, 2015 by Gazoo 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 8, 2015 Share Posted April 8, 2015 Harry, I am running into a couple of issues with TML: - When using CALL LINK("INPUT"...) with a prompt string, the input cursor is placed over the beginning of the string instead of at the end, so any input will overwrite the string - When clearing the screen with CALL LINK("CLEAR") after loading a bitmap image with CALL LINK("LOADP"...), the screen does not completely clear Any thoughts on this? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted April 9, 2015 Share Posted April 9, 2015 (edited) Harry, I am running into a couple of issues with TML: - When using CALL LINK("INPUT"...) with a prompt string, the input cursor is placed over the beginning of the string instead of at the end, so any input will overwrite the string - When clearing the screen with CALL LINK("CLEAR") after loading a bitmap image with CALL LINK("LOADP"...), the screen does not completely clear I guess calling it a "prompt string" is not quite right; maybe "suggested string" would be a better description. If you want a prompt like "Enter your name: " you can put it on the screen with CALL LINK("PRINT"...) and then use CALL LINK("INPUT"...) to accept the name. CALL LINK("CLEAR") will only clear out the pattern table; the color table is left alone. So to totally clear the screen you should CALL LINK("CLEAR")::CALL LINK("COLOR",FG,BG) and this will clear the pattern table and set the colors to FG and BG. Gazoo wrote: Ok, I took out the requirement of not being able to use a CALL TML(xxx) in a program. The Grom file to do so is attached to this message. Be aware that if you already have TML loaded and do a CALL TML(xxx) in a program, the error routine that TML is already loaded will kick in, and not in a good way as you will be joining Peter Pan in never-never land. I see what you don't like about this; In a running program CALL TML does indeed send you off the edge of the world. Maybe have CALL TML check if it is already loaded and if a program is running then skip the error message and go on with the XB program. Or maybe you could break the program, (as in Fctn 4), return to the command line, and then print the error message. Edited April 9, 2015 by senior_falcon Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 9, 2015 Share Posted April 9, 2015 I guess calling it a "prompt string" is not quite right; maybe "suggested string" would be a better description. If you want a prompt like "Enter your name: " you can put it on the screen with CALL LINK("PRINT"...) and then use CALL LINK("INPUT"...) to accept the name. CALL LINK("CLEAR") will only clear out the pattern table; the color table is left alone. So to totally clear the screen you should CALL LINK("CLEAR")::CALL LINK("COLOR",FG,BG) and this will clear the pattern table and set the colors to FG and BG. Got it. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 9, 2015 Share Posted April 9, 2015 TEENAGE MUTANT NINJA TURTLES game on the TI?!?!?! Wha.whaaaaat?? It's not very good. But I guess now that TML is available in distributable forms, I can go ahead and post it! Maybe this weekend. But it's not very good. 2 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 9, 2015 Share Posted April 9, 2015 I'm sure it is amazing. Cant wait. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 9, 2015 Share Posted April 9, 2015 You expect too much from me 30 years ago. http://harmlesslion.com/software/tmnt (tested on all three versions of TML). Video here (will take another hour to upload): http://youtu.be/GZy95VYyeJY 4 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 9, 2015 Share Posted April 9, 2015 Hey man, that is pretty impressive for a game written with no modern tools!!! I'll be DLing it later today... Just watched the video. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
JamesD Posted April 9, 2015 Author Share Posted April 9, 2015 I just looked at the TMNT game video and it looked great for BASIC. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 9, 2015 Share Posted April 9, 2015 ^^YUP Quote Link to comment Share on other sites More sharing options...
Gazoo Posted April 9, 2015 Share Posted April 9, 2015 (edited) Gazoo wrote: Ok, I took out the requirement of not being able to use a CALL TML(xxx) in a program. The Grom file to do so is attached to this message. Be aware that if you already have TML loaded and do a CALL TML(xxx) in a program, the error routine that TML is already loaded will kick in, and not in a good way as you will be joining Peter Pan in never-never land. I see what you don't like about this; In a running program CALL TML does indeed send you off the edge of the world. Maybe have CALL TML check if it is already loaded and if a program is running then skip the error message and go on with the XB program. Or maybe you could break the program, (as in Fctn 4), return to the command line, and then print the error message. Here's the solution I like the best, and you don't ever have to be forced to transport to a far away place. If TML is already loaded and you attempt to load it again in a running program, you will be honked at. There will be no warning message to mess up the display, though, and the program will continue running without executing the CALL TML(xxx) command again. The normal command line warning with honk and text if you attempt to load TML twice has been left in place. This should suffice, I hope. Anyway, I like it. Gazoo [DELETED attachment=386951:XBTML.zip] Edited April 9, 2015 by Gazoo 2 Quote Link to comment Share on other sites More sharing options...
Gazoo Posted April 9, 2015 Share Posted April 9, 2015 (edited) Ok, already found a bug. The previous upload won't work on a real TI. This one does. Gazoo XBTML.zip P.S. I had to make a cartridge to test this. The cartridge on a real TI is pretty cool. Edited April 9, 2015 by Gazoo 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted April 10, 2015 Share Posted April 10, 2015 That seems like a good way to do the error checking. Will test it out later. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 10, 2015 Share Posted April 10, 2015 I just looked at the TMNT game video and it looked great for BASIC. It's like Hyper Racer, makes good screenshots, but gameplay will let you down. Still, TML made it easy to make it look good. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 10, 2015 Share Posted April 10, 2015 Yes, unlocking the power of bitmap graphics for the XB programmer is awesome, particularly backgrounds. That said, in the early days, creating such backgrounds was very labor intensive, which may have discouraged users from taking full advantage of TML. Nowadays, particularly with Tursi's image conversion tool, it's a snap Looking back, I could easily have programmed my Chaos Musings program in XB under TML rather than painfully in assembly and the speed of calculations would have been pretty similar. Take foot, kick butt... Quote Link to comment Share on other sites More sharing options...
Retrospect Posted April 10, 2015 Share Posted April 10, 2015 (edited) I don't know of any other micro where you could knock out a game like that in BASIC. I know it's extended, but still - Basic .... look at the C64 and Vic 20 for example ... they would take at least a minute to generate the characters let alone attempt the game. One up for TI and a good show from Tursi. Brilliant stuff. Also cheers to Harry W. for providing us with this great extension. After my horse racing game is done with I'll be having another look into TML to see what I can or can't do. Edited April 10, 2015 by Retrospect Quote Link to comment Share on other sites More sharing options...
