mickcris Posted June 22, 2016 Author Share Posted June 22, 2016 Hello there! Are any boards/din connectors/euro scart cable kits still available? yes, sent you a pm Quote Link to comment Share on other sites More sharing options...
mickcris Posted July 24, 2016 Author Share Posted July 24, 2016 bump Quote Link to comment Share on other sites More sharing options...
Hesterfu Posted August 8, 2016 Share Posted August 8, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
nra0707 Posted August 20, 2016 Share Posted August 20, 2016 Hi Mickcris, Any upgraded RGB amps available? Do you also have 9-pin mini DINs? Quote Link to comment Share on other sites More sharing options...
mickcris Posted August 20, 2016 Author Share Posted August 20, 2016 Hi Mickcris, Any upgraded RGB amps available? Do you also have 9-pin mini DINs? yes. i have amps ready to ship. also do not have 9 pin mini dins but do have 8 pin ones. Quote Link to comment Share on other sites More sharing options...
mickcris Posted September 19, 2016 Author Share Posted September 19, 2016 duo-rx added Quote Link to comment Share on other sites More sharing options...
mickcris Posted September 30, 2016 Author Share Posted September 30, 2016 added a few ten no koe 2 with RGB output Quote Link to comment Share on other sites More sharing options...
kuro68k Posted October 5, 2016 Share Posted October 5, 2016 PM incoming, thanks! Quote Link to comment Share on other sites More sharing options...
mickcris Posted October 21, 2016 Author Share Posted October 21, 2016 since the board is very low profile now with the tantalum caps, i started using a new install location on the duo.http://imgur.com/a/DazFGthere is still plenty of clearance between the rgb amp and the bottom shielding. i put some kapton tape under the amp just in case it would happen to fall, which is highly unlikely. Quote Link to comment Share on other sites More sharing options...
crazedbinary Posted November 2, 2016 Share Posted November 2, 2016 PM sent! Quote Link to comment Share on other sites More sharing options...
mickcris Posted November 4, 2016 Author Share Posted November 4, 2016 added a couple consoles Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 12, 2017 Author Share Posted January 12, 2017 bump. amp now uses a THS7374 instead of a THS7314 Quote Link to comment Share on other sites More sharing options...
SveinsWorld Posted January 23, 2017 Share Posted January 23, 2017 Sent you a message Quote Link to comment Share on other sites More sharing options...
MarxDuo Posted January 30, 2017 Share Posted January 30, 2017 Hi , I am interested on your RGB board and region free board for the PC Engine Duo , I would like to buy 6 RGBs and 2 Region free boards , but I am in UK , do you ship to UK ? Thanks ! Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 30, 2017 Author Share Posted January 30, 2017 Hi , I am interested on your RGB board and region free board for the PC Engine Duo , I would like to buy 6 RGBs and 2 Region free boards , but I am in UK , do you ship to UK ? Thanks ! yes, i ship to the uk Quote Link to comment Share on other sites More sharing options...
MarxDuo Posted January 30, 2017 Share Posted January 30, 2017 How much does it cost , and how can I place an order ? Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 30, 2017 Author Share Posted January 30, 2017 How much does it cost , and how can I place an order ? sent you a pm Quote Link to comment Share on other sites More sharing options...
cjameslv Posted January 31, 2017 Share Posted January 31, 2017 Sent you a pm, waiting to hear back. Quote Link to comment Share on other sites More sharing options...
genfuyung Posted February 1, 2017 Share Posted February 1, 2017 Why is it so hard to find mini 9 pin dins? Thats the only way to use a genesis scart cable with this right? Quote Link to comment Share on other sites More sharing options...
mickcris Posted February 1, 2017 Author Share Posted February 1, 2017 Why is it so hard to find mini 9 pin dins? Thats the only way to use a genesis scart cable with this right? I would not recommend using a genesis scart cable as they "should" have caps and resistors in the cable already and they are already present on this board. also a lot of them are not built correctly so you dont know what you are getting. Quote Link to comment Share on other sites More sharing options...
mickcris Posted February 9, 2017 Author Share Posted February 9, 2017 bump. added a coregrafx Quote Link to comment Share on other sites More sharing options...
unusedowl Posted February 21, 2017 Share Posted February 21, 2017 PM sent. Quote Link to comment Share on other sites More sharing options...
unusedowl Posted February 21, 2017 Share Posted February 21, 2017 Are you required to use a 9-pin mini DIN? I'd like to use an 8-pin and match the pinout to the Framemeister input, so I can use that with my existing cables (and since you didn't recommend using the Genesis SCART cable). If I use an 8-pin mini DIN, can I go straight to the FM input? Quote Link to comment Share on other sites More sharing options...
mickcris Posted February 21, 2017 Author Share Posted February 21, 2017 yes, you can use an 8 pin din and use a male to male cable for the xrgb mini. a 9 pin din i do not recommend due to the genesis cable issues. here is how to do it: http://www.mmmonkey.co.uk/pc-engine-rgb-mod/ here is the xrgb mini pinout to use instead of what is one that page above http://imgur.com/t9jMB6l Quote Link to comment Share on other sites More sharing options...
mickcris Posted March 2, 2017 Author Share Posted March 2, 2017 have replaced the sync strip scart cable with a small add on board to be installed in the console. It could also be installed in the scart head if you really wanted to, but better to do it inside the console. Board outputs 75 ohm sync, but could be easily modified to output TTL sync if one required it. Quote Link to comment Share on other sites More sharing options...
