Intellivision Flashback Controller Adapters - Round 2
Intellivision Flashback Adapter Adaptor Nurmix Intellivisionaries Colecovision
54 replies to this topic
#1 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Thu Apr 9, 2015 12:46 PM
Hey guys, I'm starting this new thread for the various adapters I make since the old thread was getting a bit long, and the original posting didn't contain the various adapters I now offer.  The original thread can be found here.
Here is the current lineup of adapters and extension cables I have for sale:
Intellivision 1 Flashback Controller Adapters
(for the original console, INTV, Radio Shack etc. variations with the "hard wired" controllers):
These are $24/pair (only sold in pairs).  Approximate length is 18 inches.
Intellivision II / Sears Flashback Controller Adapters
(for the Intellivision II and Sears consoles with the removable db9 connector controllers):
These are $14 each, or two for $26.  If desired, you can specify the color of the decorative heat shrink tubing near the cable ends.  Black is also an option.  If not specified, you will receive whatever color I have in stock at the time.    Approximate length is 6 feet.
Standard db9 controller extension cables - 6 foot length
(for Intellivision II / Sears consoles, Atari 2600 / 7800, Sega Genesis, Atari and Commodore computers; basically anything that uses a standard db9 type connector):
These are $7.00 each.
Colecovision Y-Adapter cable - allows connection of standard Colecovision system controller and an additional compatible joystick (Atari 2600, etc) without the need to unplug / swap controllers one at a time.  Should work fine on other consoles that use db9 connectors - but only tested on a Colecovision):
These are $12 each.  If desired, you can specify the color of the heat shrink tubing, including black.  If not specified, you will receive whatever color I have in stock at the time.  Approximate length is 24 inches.
Please send me a PM here on Atari Age if you are interested in any of these cables.  Include your shipping / address information, and preferably an email address, and I will get back to you with a total.  Payment is via PayPal.  Credit cards (processed through my business - White Flag Computing) are also an option if you don't use PayPal.  You can also email adapters@intellivisionaries.com instead of sending a PM if you prefer.
Shipping is not included in the above prices.  USA orders will be shipped via USPS Priority Mail (usually flat rate small box, which is $6.80 - the price went up January 2016, it used to be $5.95).  I can also ship USA orders via First Class Mail in a padded mailer for a little bit less.  International orders will be shipped via USPS International First Class (padded mailer - price varies depending on weight and destination).
Thanks!
Edited by nurmix, Wed Jan 20, 2016 12:11 PM.
#2 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Fri Apr 24, 2015 2:33 PM
I suppose at this point most of the Atari Agers who wanted them already have them, but just want to clarify that I still have these available.
That said, once I go through my current supply of 'donor cables', I will most likely discontinue making them.
#3 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Mon May 4, 2015 5:38 PM
Bump.
I still have some of these available.
#4 BBWW OFFLINE
BBWW
  • 3,124 posts
  • If it is not fun move away slowly.
Posted Tue May 5, 2015 9:41 PM
Since it's cheaper to buy a Flashback than replace controllers in the original Intellivision...this is cool.
#5 wongojack OFFLINE
wongojack
  • 3,158 posts
Posted Tue May 5, 2015 9:57 PM
Here's an idea, how about making some Intellivision 1 cables that work with the Sears and INTV II controllers.  Just another variation on this great service you are offering!  They would also be valuable if AtGames ever releases a version of the controller that matches the original pinout.
Also, what is the connector called that connects to the Intv 1 board and where did you buy it?
#6 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Wed May 6, 2015 8:51 PM
Sure, that's an option.  I don't think there's a big demand for that, but if anyone wants those, they'll be the same price as a pair of Flashback adapters for the Intellivision 1, since it will be the same parts and time involved.
I can also make adapters that allow the use of a Sears or Intellivision II controller on the Flashback; although I don't know why anyone would want to do that.
As for the motherboard connector, it's called a 9-pin SIP / inline [female] connector.  It typically does not come with the pins installed.  You have to buy the plastic housings, and the [female] pins separately.  And the pins have to be inserted into each hole after attaching the individual wires.  The female pins are usually crimped onto the wires, but I prefer to solder the wires to them.  It's actually faster for me to do it that way, and the bond is better electrically.
I have gotten the housings and pins from a couple different sources.  The last being Mouser Electronics.  I've also found them on ebay.  The pricing varies widely, depending on quantity ordered.
Edited by nurmix, Wed May 6, 2015 8:51 PM.
#7 wongojack OFFLINE
wongojack
  • 3,158 posts
Posted Thu May 7, 2015 9:27 AM
Let me say that what you are doing is awesome, so I do not intend to sound critical.
I guess I am still hoping that AtGames will produce a version of the controller that is fully compatible with the original console - at that point you'd have loose controllers for sale that folks could buy to replace their Model 1 controllers.  I've also built a custom joystick that works with the original pinout, and I know that another user on here did the same.
In my case, I'd be interested in seeing an "original" adapter come out of the model 1 and then the additional flashback adapter IF you want to use those, but that would look like an Octopus that would only be interesting to a few . . . probably.
#8 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Thu May 7, 2015 10:33 AM
I'm adding Flashback-adapted ports to one of my Intellivision 1 consoles.  I'll keep the original controllers installed, as they are, and then have serial port type connectors mounted in the case (most likely in the lower front of the console).  That way I can use the original controllers, or plug in Flashback controllers if desired.
By the way, if I make standard pin-out [SIP to db9] cables to use Sears/Inty II controllers on an original console, all you'd need to do to use a Flashback controller would be to also plug in one of my Sears/Inty II Flashback adapters.  It would make for a LONG cable, but I suppose that could be seen as a benefit?
But yeah, you could also have 2 sets of male db9 connectors coming into the controller bays; one set for standard controllers, the other for Flashback controllers.  I'd just have to double up the wiring/pins on the SIP connector in the correct order(s).
Do you have any pictures of your custom joystick setup?  My only issue with joysticks adapted to the Intellivision (like the awesome ones grips03 makes) is that you only get 8 directions.  And there are so many games on the Intellivision that use (and benefit from) 16 directions.
Edited by nurmix, Thu May 7, 2015 10:34 AM.
#9 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Wed Jun 17, 2015 2:06 PM
Bumping this thread to let everyone know my stock of supply cables is almost gone, and I don't think I'll be ordering any more given demand has dropped off significantly at this point.  So if anyone still wants adapter cables for their Inty II or original console, now would be a good time to let me know, as they likely won't be made again.
Thanks.
#10 Intellfan OFFLINE
Intellfan
    Dragonstomper
  • 787 posts
Posted Wed Jun 17, 2015 4:01 PM
Thanks.
Ill take two more for my  Sears  unit
#11 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Wed Jun 17, 2015 5:38 PM
OK, no problem. I'm sure I still have your info, but PM again just in case.
Thanks!
#12 First Spear OFFLINE
First Spear
  • 1,348 posts
Posted Fri Jun 19, 2015 12:59 PM
I'll take another set, sir.
Thanks.
Thanks.
#13 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Fri Jun 19, 2015 1:43 PM
Thanks.
Intellivision II / Sears, or original console?
#14 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Thu Jun 25, 2015 1:02 PM
OK, guys.  I'm currently out of adapter cables and supply cables.
:-o
I'm planning to get more supply cables, but I won't get the same deal on them this time, as my supplier raised the price + I won't be ordering in bulk this time around.  That said, if you're still interested in getting adapter cables, let me know.  They will be made 'on demand' going forward.
* Each cable will cost an additional $1 US:
Intellivision II / Sears Flashback controller adapters will be $14 each or two for $26.
Intellivision 1 Flashback controller adapters will be $24/pair
6' DB9 extension cables will be $8 each or two for $15
Thanks to all who ordered.  And again, contact me if you still want them.
#15 GenetixJ OFFLINE
GenetixJ
    Moonsweeper
  • 464 posts
  • 8-bit pharmacy
Posted Thu Jun 25, 2015 4:16 PM
Thank you, I just received mine today.
#16 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 970 posts
Posted Fri Jun 26, 2015 6:44 PM
Thank you so much!
These look amazing, I'll be playing this weekend.
I didn't think shipping across the country could be so quick!
#17 First Spear OFFLINE
First Spear
  • 1,348 posts
Posted Fri Jun 26, 2015 10:18 PM
I got mine super fast as well. Speed and quality.
#18 wongojack OFFLINE
wongojack
  • 3,158 posts
Posted Thu Jul 9, 2015 4:46 PM
It took me a while to get back to this, but we were thinking along the same lines in terms of the adaptation of the various controllers.  I think I've asked you this before but what is the connector called that you have on the end of the Model 1 adapter?  Where did you get it?
The joystick I built only has 8 directions and you can see details here
I liked hacking that up over building my own because the parts were all in there and it was big enough to work inside.  There is a forum post on these boards here where a guy played with 16 way.  It isn't so hard, but the easiest way to do it would be to simply have 8 switches.  In a build-your-own arcade stick that isn't out of the question at all.
#19 soporj OFFLINE
soporj
    Chopper Commander
  • 206 posts
Posted Thu Jul 9, 2015 4:53 PM
My grandson uses the Flashback controllers with an old Intellivision without any adapters. He says it's more challenging to play these baby games that way!!!
#20 Lynxpro OFFLINE
Lynxpro
  • 3,698 posts
Posted Sat Jul 18, 2015 2:54 PM
Let's see some pics of 'em plugged in!
#21 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Wed Jul 22, 2015 2:30 AM
Quick update...
I have the supply cables / parts in.  I'm currently on vacation, but will be making more cables and following up with people on the waiting list next week.
Thanks!
#22 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Mon Jan 18, 2016 10:21 PM
Update time!
I decided to make some more of these, as I recently got another small shipment of supply cables and parts.
Flashback controller adapters for your Intellivision II / Sears console are $14/each (or $26/pair).
Flashback controller adapters for your original (model 2609 and compatible) Intellivision console are $24/pair.
Shipping in the US is via Priority Mail (or First Class if you want to save a buck or two).  Shipping outside the US is First Class International.
Post here or send me a PM if you're interested.
Thanks!
#23 travistouchdown OFFLINE
travistouchdown
  • 4,417 posts
  • Do the math!
Posted Mon Jan 18, 2016 10:31 PM
Wait, so will the flashback controllers work on an INTV 2 with standard db9 extension cables?
I'm thinking of picking up a flashback just for the overlays and controllers. Don't mind the INTV 1 controllers, but would sure love to replace my INTV 2 controllers..
#24 nurmix OFFLINE
nurmix
  • 1,729 posts
Posted Mon Jan 18, 2016 10:34 PM
Nope.  My adapters are re-wired extension cables - At Games only got 1 of the 9 wires correct!
#25 intvsteve OFFLINE
intvsteve
  • 3,293 posts
Posted Mon Jan 18, 2016 10:41 PM
And I don't think it was even the ground wire, was it? :P
Also tagged with one or more of these keywords: Intellivision, Flashback, Adapter, Adaptor, Nurmix, Intellivisionaries, Colecovision
