Super Pong Ten/Pro-Am Ten - "Basketball"
BassGuitari
The Atari Super Pong Pro-Am Ten console has a game called Basketball (I believe Super Pong Ten does too), which is actually just Handball except you can control the height of the wall and leave an opening at the top (or middle, or wherever you want depending on the level of challenge you want :) ). I don't have the manual, nor can I locate a scan or transcription of one, so I'll ask here: is there a "regulation" height for the basketball hoop a.k.a. hole in the Handball wall?
I dug my system out yesterday and played around with it a bit. I've found that lining up the top of the wall with the top of the score numbers provides a reasonable challenge; it's not easy, but not impossible, either. I was just wondering if there was a "correct" way the Basketball game should be set up.
(Side note: this game is actually more fun than it sounds like.)
  • 2 months later...
