I_POOD_ON_A_ANT Posted May 25, 2015 Share Posted May 25, 2015 Hi members, First post sorry if its in the wrong place. Ive been reading the forums a while and got off my butt to join to ask some advice. I am reliving my youth and have repurchased a couple of coleco's. Just wanted advice on display issues. One console, - splash screen loads, then letters start getting a little jumbled, grey spotty lines appear in background, some wierd colour flickers. Other console - display is wierd, controllers seem to move character but not displayed correctly, sound is fine. Expansion module 1 works fine and atari games run without problem. Expansion pack 2 unsure if this works yet (i have this console on the way, a friend quickly tested and these were results) I will start with the power switch, then look at power supply. Hoping someone may be able to point me where to start? Im new to restoring and need to work out my limits. Im based in Brisbane Australia if anyone is around this way to help guide me. I can give beer. I also own, 3 x atari light sixers - 100 or so games Green house - game and watch Modern consoles - emulators. Thanks for any help, Nice to meet you all. Pood. Quote Link to comment Share on other sites More sharing options...
I_POOD_ON_A_ANT Posted May 25, 2015 Author Share Posted May 25, 2015 Next step ill try Vram. Seems everyone experiences similar issues and just work through the list to troubleshoot. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted May 25, 2015 Share Posted May 25, 2015 Atari pass thru often works even if Colecovision has problems, so that probably doesn't mean much. Possible fix: clean the cart connectors with contact cleaner real good, (or at least with rubbing alcohol), using qtips. Wrap a cloth around a credit card and soak with alcohol and insert/remove several times from the connector where you insert cartridges, to clean the connector. Clean the power connector prongs with a qtip. And yes, it's possible the switch is dirty and cleaning it may fix the problem. If you can test the output from the power supply, that may also point you to a problem there. If none of that helps, then you may need to replace a chip or two inside... Quote Link to comment Share on other sites More sharing options...
I_POOD_ON_A_ANT Posted May 25, 2015 Author Share Posted May 25, 2015 Cheers fiddlepaddle. I just gave the first console a real tender first clean. It shines (on the outside) I could feel it smiling with its big rainbow smile as i cleaned the years of pepsi stuck in fthe cracks. Ill play later when i get back home. Quote Link to comment Share on other sites More sharing options...
NIAD Posted May 25, 2015 Share Posted May 25, 2015 There's a PINNED thread titled "ColecoVision and ADAM Information" that you should checkout if you haven't already that has some great DIY instructionals for maintenance and repair. Also, the ColecoVision Technical Manual that is available for download at http://ann.hollowdreams.com will help you identify what RAM chips may be bad if that ends up being the issue... turn on the system without a cartridge inserted to view the CV BIOS screen and compare display corruption to what is listed/pictured in the manual. Good luck and welcome aboard. Quote Link to comment Share on other sites More sharing options...
I_POOD_ON_A_ANT Posted May 25, 2015 Author Share Posted May 25, 2015 Thank you, I am actually looking forward to refurbing everything as best i can. I just managed to pick up a couple of expansions for $10 each (1 and 2) so now both systems are a little pimped. Ill take all advice given and follow whatever im told. I def need help here but i learn fast..ish Quote Link to comment Share on other sites More sharing options...
I_POOD_ON_A_ANT Posted June 12, 2015 Author Share Posted June 12, 2015 Seemed to be power switch. I have become a bit of an addict since last post. I now own 4 vision consoles, each with expansions 1 and turbo wheel. And a few carts. Oh and 7 atari 6ers and too many games, and game watches, and old computers.. And pong consoles HELP! Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted June 12, 2015 Share Posted June 12, 2015 I have become a bit of an addict since last post. I now own 4 vision consoles, each with expansions 1 and turbo wheel. And a few carts. Oh and 7 atari 6ers and too many games, and game watches, and old computers.. And pong consoles HELP! Shatner to the rescue! https://www.youtube.com/watch?v=wpkHykA1Z4E Quote Link to comment Share on other sites More sharing options...
