babrasch Posted June 30, 2015 Share Posted June 30, 2015 I grabbed a 4-port Atari 5200 lot today, and after configuring/fixing the switch box, it worked on my little 13 inch tv. But this tv isn't my primary one, I just didn't have room for the 5200 in my room. I finally found a spot for it, though. I configured the box again, and I switched my primary tv's input to antenna. But for some reason, the 5200 was picking up a tv signal and started playing local tv stations! Just to check that this was the case, I turned my tv off, disconnected the switch box, and then the tv couldn't get a signal. After this, I tried to turn the 5200 on to see if it would override the tv signals, but it didn't. Instead, the show that happened to be on became a little distorted, froze, and made strange sounds. What I thought was the issue was that the power cable was picking up a local signal, but funny enough, I unplugged the system and the tv was still going. Side question, does this mean that I can just put any antenna cable in my tv and it'll play? But more importantly, what can I do to get it to work on my tv? If it helps, it's a ViewSonic 21 inch. I know I could always just keep it in the other room, but I want to know if there's anything I could possibly do to fix this. Quote Link to comment Share on other sites More sharing options...
