richphotos Posted July 1, 2015 Share Posted July 1, 2015 (edited) I recently acquired an Atari 2600 from my girlfriends dad who found it while he was moving. Being heavily into gaming I was extremely happy about this. I immediately went to radio shack and got the RCA to coax adapter to hook it up to the TV. Hooked it up, turned the TV to channel 3 which is what I had it set to on the Atari, and nothing. I opened it up, everything looked good, flipped the board over and re flowed all the solder joints on the board. Next up was testing the AC adapter. Left the Atari plugged in for about 5 minutes, unplugged it and felt the voltage regulator and it was warm. So it is getting power. I am not really sure where to go from here? Can the regulator still get warm even if it is not functioning properly? Thanks very much for the help. *edit* By the way, its the 4 switch woody Edited July 1, 2015 by richphotos Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 1, 2015 Share Posted July 1, 2015 I recently acquired an Atari 2600 from my girlfriends dad who found it while he was moving. Being heavily into gaming I was extremely happy about this. I immediately went to radio shack and got the RCA to coax adapter to hook it up to the TV. Hooked it up, turned the TV to channel 3 which is what I had it set to on the Atari, and nothing. I opened it up, everything looked good, flipped the board over and re flowed all the solder joints on the board. Next up was testing the AC adapter. Left the Atari plugged in for about 5 minutes, unplugged it and felt the voltage regulator and it was warm. So it is getting power. I am not really sure where to go from here? Can the regulator still get warm even if it is not functioning properly? Thanks very much for the help. *edit* By the way, its the 4 switch woody Dumb question but did you have a game cartridge inserted? And did you clean both the game and the cartridge slot with isopropyl alcohol or electrical contact cleaner? Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 (edited) Dumb question but did you have a game cartridge inserted? And did you clean both the game and the cartridge slot with isopropyl alcohol or electrical contact cleaner? That I have not done yet. I will give that a try and report back. But yes, there was a game in there. How do I remove the plastic of the cartridge slot? I have removed both the top and bottom shield from the board to gain access to the 2 tabs that hold it to the board, but it wont budge. Edited July 1, 2015 by richphotos Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 1, 2015 Share Posted July 1, 2015 That I have not done yet. I will give that a try and report back. But yes, there was a game in there. How do I remove the plastic of the cartridge slot? I have removed both the top and bottom shield from the board to gain access to the 2 tabs that hold it to the board, but it wont budge. The cartridge slot guide is probably stuck to the board with double-sided tape. If so, you can use Goof Off or straight naphtha (lighter fluid) to loosen up the adhesive. Now that said, you don't really need to do that. A good way to clean cartridge slot connectors is to wet the edge connector of a cartridge with alcohol and then insert and remove it several times while wet. Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 (edited) The cartridge slot guide is probably stuck to the board with double-sided tape. If so, you can use Goof Off or straight naphtha (lighter fluid) to loosen up the adhesive. Now that said, you don't really need to do that. A good way to clean cartridge slot connectors is to wet the edge connector of a cartridge with alcohol and then insert and remove it several times while wet. Thanks, I just cleaned it out and cleaned multiple games and tested it out and still nothing is happening. Not sure where to go from here. Everything that was under the shields looks immaculate. The rest of the board and the components look great too. The voltage regulator on the other hand looks in rough shape. Also, some of the leads that go to each component on the board are raised up in sections, most likely has separated itself from the board, but the connection itself is not broken, and that is not happening at any of the solder connections, and like I previously said, I re flowed all of the solder connections. I really appreciate the help, I really want to get this thing running. I know its possible, for the most part unless the board is shot *quick update* I just left it on with a game cartridge in there for about 5 minutes, went back after I unplugged it, the voltage regulator was warm, and all the processors were warm as well, which makes me thing that it is "working" but for some reason video is not going out of it. I am wondering if the RF cable is bad? Edited July 1, 2015 by richphotos Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 1, 2015 Share Posted July 1, 2015 (edited) Well, it's possible the voltage regulator is malfunctioning, but VCS models are, by and large, pretty durable. If it's the regulator, it'll have to be replaced. However, don't rule out a dirty cartridge slot and games. They can get very grimy over the years, especially if they're unused in storage long-term. Fortunately, the cart connectors and cartridge slot pins are gold-plated so corrosion isn't generally a real problem. If you have more than one game, try cleaning the utter crap out of them and test each one. Another thing you might try is to very, very carefully remove and reseat the socketed chips on the VCS motherboard - there should be three - the 6507 processor, a 6532 I/O and RAM chip (the large one nearest the cartridge slot) and the TIA, which generates the video signal. Only do that as a last resort unless you're very comfy with old IC's. The pins are fragile and easy to bend; trying to bend them back can easily break them clean off. Edited July 1, 2015 by DrVenkman Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 Well, it's possible the voltage regulator is malfunctioning, but VCS models are, by and large, pretty durable. If it's the regulator, it'll have to be replaced. However, don't rule out a dirty cartridge slot and games. They can get very grimy over the years, especially if they're unused in storage long-term. Fortunately, the cart connectors and cartridge slot pins are gold-plated so corrosion isn't generally a real problem. If you have more than one game, try cleaning the utter crap out of them and test each one. Another thing you might try is to very, very carefully remove and reseat the socketed chips on the VCS motherboard - there should be three - the 6507 processor, a 6532 I/O and RAM chip (the large one nearest the cartridge slot) and the TIA, which generates the video signal. Only do that as a last resort unless you're very comfy with old IC's. The pins are fragile and easy to bend; trying to bend them back can easily break them clean off. I will do some more cleaning and re-seat the socketed chips. I have some experience with circuit boards, have built a couple to control LED lights on my truck. I also should add, I might have been seeing things earlier, but when I first turned it on and nothing happened I sat there for awhile to see if anything would happen, and I think I saw colored blocks on the screen for a quick second. It was out the corner of my eye so I cant be certain, this was when I had super mario in. I have 38 games, so I will be cleaning for quite awhile. again, Thank you very much for the help. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted July 1, 2015 Share Posted July 1, 2015 Something else you can try... find someone else who has a working 2600 and test their working cart with your system or you working cart with theirs. Maybe swap video cables, power supplies. Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 Thanks for the suggestion fiddlepaddle, but I do not know anyone that has a working 2600 unfortunately. So I cleaned multiple games very well, q-tip came out clean, then cleaned the cartridge slot very well also, and still the same result. I have attached a couple photos of the board and the voltage regulator. Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 So, a small update to this. I was in the chat room on this site and someone suggested to me to set the channel on the atari to 3, and to an autoscan on my TV (I am using a modern TV) so I did that and still nothing happened besides the TV being placed on CH 3 (still no signal) So, I decided to set the atari to ch 2, did an autoscan on the TV again, this time it set the TV to ch 2, but no signal again. I did this a couple more times to test it to make sure I was not losing my mind, and each time I switch the atari between ch 2 and ch 3 the TV would auto program to that channel but no picture. Which makes me believe that SOME kind of signal is being sent to the tv... Quote Link to comment Share on other sites More sharing options...
daafies Posted July 1, 2015 Share Posted July 1, 2015 When you say no signal, you mean static? Or like a black screen? Is there a difference with the atari on and off? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 When you say no signal, you mean static? Or like a black screen? Is there a difference with the atari on and off? Sent from my iPhone using Tapatalk There is no difference with the atari on or off. The TV just has the box in the center of the screen that says "no signal" 1 Quote Link to comment Share on other sites More sharing options...
daafies Posted July 1, 2015 Share Posted July 1, 2015 Hm you sure the tv has an ntsc analog tuner? If not sure you can probably google the model nr. I wonder if some modern tvs lack analog tuners Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 Hm you sure the tv has an ntsc analog tuner? If not sure you can probably google the model nr. I wonder if some modern tvs lack analog tuners It does have an analog tuner, that is one thing that I questioned until I did a channel scan and saw it scanning for both digital and analog channels. This is driving me absolutely insane! I want to play some Atari! Thanks for the help. Quote Link to comment Share on other sites More sharing options...
zylon Posted July 1, 2015 Share Posted July 1, 2015 Try "jumpstarting it". put game in and disconnect power cord from system, but leave plugged into the wall socket. Turn power switch on and then insert power jack. If system starts, regulator is dead. RF modulators have also been known to fail. Quote Link to comment Share on other sites More sharing options...
hookem Posted July 1, 2015 Share Posted July 1, 2015 I've had bad RF cables before, did you manage to try another one? Also, and this may be something obvious that you've already tried... but since you're autoscan test seems to show some signal coming from the unit, you have tried manipulating the cable while it's connected and on? I mean really jiggling it and bending the ends right at the connector. Just to see if anything changes. I also usually do the connector cleaner/deoxit on all the switches of a system that has been sitting for a long time. Power, channel select, reset etc. And switch them back and forth a lot. Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 1, 2015 Author Share Posted July 1, 2015 I've had bad RF cables before, did you manage to try another one? Also, and this may be something obvious that you've already tried... but since you're autoscan test seems to show some signal coming from the unit, you have tried manipulating the cable while it's connected and on? I mean really jiggling it and bending the ends right at the connector. Just to see if anything changes. I also usually do the connector cleaner/deoxit on all the switches of a system that has been sitting for a long time. Power, channel select, reset etc. And switch them back and forth a lot. I have not had the chance to try another RF cable for this, I will need to order one. I tried every bit of the cable bending and moving it to see if it were to make connection. One thing I have not done is the detox that you mentioned. I do have a bit of experience with electronics and taking apart these switches to clean them is not an issue. Which I should do. I looked in with a flash light and they looked clean but seeing in that small area, its hard to tell. Thanks again! Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 2, 2015 Author Share Posted July 2, 2015 Well, I did the connector cleaner for the switches, cleaned the cartridge slot more and cleaned all the games and still no signal is being sent to the TV. Man, I want to play this thing so bad. Quote Link to comment Share on other sites More sharing options...
Mitkraft Posted July 2, 2015 Share Posted July 2, 2015 One thing I've read about is the Atari's weak RF signal not registering on some modern TV's. Some people have resolved this by using a VCRs tuner to receive the Atari signal. Alternatively you could find an older CRT TV to test it on. If you don't have one a drive around your area on trash day would have a high likelihood of yielding a free one. Quote Link to comment Share on other sites More sharing options...
BigO Posted July 2, 2015 Share Posted July 2, 2015 Any way to try it on a different TV? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 2, 2015 Share Posted July 2, 2015 It's also not out of the realms of possibility that there's a bad RF modulator. They CAN die. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 4, 2015 Author Share Posted July 4, 2015 I am not using a RF modulator, I am just using the RF to coax converter that can be purchased at radio shack. I do have access to an old TV and I will give that a try tomorrow and keep you guys updated. So if it does end up being the ataris weak RF signal being the issue with my new tv, what would fix that issue? an RF modulator? I dont have an old tube TV and do not intend to get one any time soon. As always. I greatly appreciate the help. This is a great community. When I joined and saw that people were making games for these I was blown away. Very awesome to see. Take care! Quote Link to comment Share on other sites More sharing options...
daafies Posted July 4, 2015 Share Posted July 4, 2015 I am not using a RF modulator, I am just using the RF to coax converter that can be purchased at radio shack. I do have access to an old TV and I will give that a try tomorrow and keep you guys updated. So if it does end up being the ataris weak RF signal being the issue with my new tv, what would fix that issue? an RF modulator? I dont have an old tube TV and do not intend to get one any time soon. As always. I greatly appreciate the help. This is a great community. When I joined and saw that people were making games for these I was blown away. Very awesome to see. Take care! drvenkman meant the built-in RF modulator. if its the TV you can get an old vcr and use it's tuner. if its the rf modulator you can replace that or do the A/V mod. or sell it for parts and get a 'new' 2600. they're pretty affordable. 1 Quote Link to comment Share on other sites More sharing options...
richphotos Posted July 4, 2015 Author Share Posted July 4, 2015 drvenkman meant the built-in RF modulator. if its the TV you can get an old vcr and use it's tuner. if its the rf modulator you can replace that or do the A/V mod. or sell it for parts and get a 'new' 2600. they're pretty affordable. That makes more sense that you said that. The TV is very new. I was looking on ebay at working ataris and I might go that rought instead of throwing money into this one not knowing the issue. It would be cheaper to get a working unit. I know it say in the storage for years, but before that it sat in a basement which is known for having water flood it, so I am not sure on water damage. I think i will just keep this for parts and get a working unit from the bay. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted July 4, 2015 Share Posted July 4, 2015 It's also not out of the realms of possibility that there's a bad RF modulator. They CAN die. I am not using a RF modulator, I am just using the RF to coax converter that can be purchased at radio shack. drvenkman meant the built-in RF modulator. Yeah, I meant the one in the Atari that takes the signals from the TIA chip and modulates them with an RF carrier that the TV can then display as a picture. On a six-switch unit, it looks like this: On a four-switch unit, it's the similar shielded component to the lower left of this picture: Anyway, they can go bad. I suppose you could open one and try to diagnose and fix it, or buy a replacement RF modulator, but I'm beginning to wonder if that's not actually what's going on with your system. You might very well have a bad 6507 or TIA chip in your system, or even a bad RIOT (6532) chip. I spent a couple hours yesterday diagnosing a weird problem with the difficulty switches of a 4-switch unit. During my experimenting, I found that a bad or defective RIOT chip can give you black screens as well, at least with some carts. I expect the same would be true of the other two IC's as well, especially those two in fact. The TIA is the graphics chip of the system and the 6507 of course is the CPU. Anyway, if you don't have a diehard need to keep this one unit working for sentimental reasons, it might be easier to just buy a different working unit and keep the old one for parts, or alternately, use parts from the new one to repair the old. Good luck with whatever you do! Quote Link to comment Share on other sites More sharing options...
