Atari DOS 2.5 source code from OSS - working!
DOS 2.5 source code
13 replies to this topic
#1 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Wed Jul 1, 2015 5:25 PM
Hi together!
Another source code is added:
https://atariwiki.or...2.5 Source Code
Prove:
Edited by luckybuck, Wed Jul 1, 2015 5:26 PM.
#2 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,995 posts
Posted Wed Jul 1, 2015 6:21 PM
But does the binary match?
Though you'll probably get some differences - Dos has the various flags for drives/buffers at the start and I'm fairly sure both Dos/Dup have embedded work areas that change and get written off if you write the Dos files.
#3 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Thu Jul 2, 2015 1:07 PM
Rybags, you are dam right and I am dam wrong. Maybe, it was too late and I was too happy...
Have done a binary compare on Unix:
 differ: char 3387, line 38
column 2 is the original DOS 2.5, column 3 is the one compiled from the source code. Please find the ATR-image of the compiled one attached.
3387 314   0
 3395  31   0
 3409 103   0
 3410 117   0
 3411 120   0
 3412 131   0
 3413  63   0
 3414 124   0
 3415 117   0
 3416  62   0
 3417 103   0
 3418 117   0
 3419 115   0
 3899 263   0
 3900 352   0
 4026  32 340
 4027  32   2
 4028  32 341
 4029  32   2
 4542  27   0
 4543 240   0
 4544 220   0
 4545 140   0
 5109 340   0
 5110   2   0
 5111 341   0
 5112   2   0
 5113 165   0
 5114  40   0
 5115 225   0
 5116  40   0
 5117  26   0
 5118   2   0
 5119 363   0
 5120   1   0
 5121  11   0
 5122   1   0
 6326   4   0
 6327   4   0
 6328  66   0
 6329  71   0
 6330  67   0
 6331  40   0
 6332 106   0
 6333 122   0
 6334 105   0
 6335 105   0
 6336  40   0
 6337 123   0
 6338 105   0
 6339 103   0
 6340 124   0
 6341 117   0
 6342 122   0
 6343 123   0
 6344 233   0
 6345 233   0
 6361  70 116
 6363 103   0
 6364 117   0
 6365 120   0
 6366 131   0
 6367  63   0
 6368  62   0
 6369  56   0
 6370 103   0
 6371 117   0
 6372 115   0
 6373 233   0
 6374 233   0
10140  64   0
10141  64   0
Attached File  DOS_2.5_SD_from_Source_Code.atr   90.02KB   196 downloads
Well, I am just a wannabe padawan 1st year, maybe a jedi master can take over from here? Just a few bytes... ;-)
#4 kenjennings OFFLINE
kenjennings
    Dragonstomper
  • 789 posts
  • Me + sio2pc-usb + 70 old floppies
Posted Thu Jul 2, 2015 7:02 PM
The places with a long run of values in sequential memory don't look a lot like missing code.  The long sequences of zeros that don't match the original suggests there's a lookup table declared without data...  just guessing.
Doesn't Mac/65 make a lot of segments in large object files?  Or am I thinking of another assembler?
#5 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,995 posts
Posted Thu Jul 2, 2015 8:41 PM
Yep, if there's an ORG or +*= change then Mac-65 as most other assemblers will start a new segment.
AFAIK the Dos files as supplied are raw dump for Dos.sys and single code/data segment for Dup.sys plus a segment with the run address.
Note Atari Dos 2.5 boots 3 sectors @ $700 but the DOS.SYS seems to get loaded at $7CB.
#6 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Fri Jul 3, 2015 4:17 PM
Yes, that's the way it's going. Booting was with DOS 2.0s to have access to a disk. The MAC/65's main advantage was to assemble to and from disk. The object code was, as Rybags said, an ORG +*= change in order to not run into the actual DOS 2.0s. Of course, we can use the BUG/65 here, load from cassette and move the needed code the the desired places, but much more work...
Didn't has JAC! the same with the Action! cartridge?
Myself, if I disassemble something and later assemble it, there are always some screws left... ;-)
#7 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 884 posts
Posted Sun Jul 5, 2015 2:00 AM
Mac65 always has segments of about 256 bytes or so regardless. I always run m65 assembled files through a desegmenter before i call it complete.
No good doing a M65 Bsave either, same segmenting happens.
James
Edited by sup8pdct, Sun Jul 5, 2015 2:03 AM.
#8 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Sun Jul 5, 2015 4:28 AM
Thanks James, didn't knew. Left Atari 1985 and reenter 2012... seems, I missed a lot.
#9 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Sun Jul 5, 2015 11:48 AM
What do you use for a "de-segmenter"?
#10 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 884 posts
Posted Mon Jul 6, 2015 1:47 AM
Check out this thread
http://atariage.com/...ac65-obj-files/
You could also use the spartados construction set OFF_LOAD command with limitations.
Edit:
found this.
https://archive.org/...ge/n35/mode/2up
James
Edited by sup8pdct, Mon Jul 6, 2015 2:14 AM.
#11 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Mon Jul 6, 2015 5:38 AM
Thanks for the info.
#12 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Mon Jul 6, 2015 5:43 AM
Thanks to Kevin and Mathy, we have the patched atr image:
Attached File  Streamliner (patched).atr   90.02KB   189 downloads
https://archive.org/...ar_Software.pdf
https://archive.org/...on_Graphics.pdf
Edited by luckybuck, Mon Jul 6, 2015 7:37 PM.
#13 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 884 posts
Posted Mon Jul 6, 2015 7:21 PM
attachicon.gifStreamliner (patched).atr
Arrrrm. is this a patched dos 2.5 image or Streamliner?
Only has dos on it.
James
#14 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 957 posts
Posted Mon Jul 6, 2015 7:38 PM
Sorry, have fixed it above. It is both plus url to the sources.
Also tagged with one or more of these keywords: DOS 2.5, source code
