daafies Posted July 5, 2015 Share Posted July 5, 2015 hi all, i had/have an issue with my 5200 where after 10-15 mins the screen will start flickering and eventually go away. i figured it might be a voltage regulator overheating. so i opened it up and am now the problem does not occur. probably cause it runs cooler without the case. i did notice tho that resistors r57 and r58 run really hot at ~130F. also Q6 at 125F. is those values normal? thanks david Quote Link to comment Share on other sites More sharing options...
daafies Posted July 5, 2015 Author Share Posted July 5, 2015 please ignore this post. i've reposted in proper spot here: http://atariage.com/forums/topic/240200-resistors-r57-and-r58-running-hot/ Quote Link to comment Share on other sites More sharing options...
