Desh Posted July 11, 2015 Share Posted July 11, 2015 Hello! I am new to these forums. The first system I ever played was an Atari 2600 my dad had purchased in the late 70 ' s (I still have it). I am a classic gaming collector/ enthusiast and decided to pursue buying a 7800 to experience it's 8-bit wonder as well as play my old 2600 ganes on it. I finally snagged one from a local game store with issues. It came with 2 controller's and the power supply. I knew going in there was a video issue (shop owner showed me before purchase) but, I have repaired/ modified many game consoles and for $15 I couldn't say no. In the shop the console was hooked to an Atari RF switch box and displayed a blurry and skewed black and white picture but the sound works. I got it home thinking maybe something as simple as a dirty cart slot and went to town cleaning it. Still had the issue. So then I started thinking maybe an RF modulator issue and composite/ s-video modded the console since I wanted to anyways. The video is much more clear but still the same skewed black and white picture. I have good power (13 volts in, 4.9 volts at regulator). I can't find any obvious visual defects on the mother board either. The only thing that was a bit strange to me is I am only receiving 4.6 volts at the power switch. Is this normal? I suspect I have a hardware issue somewhere but being new to this console I don't even know where to start looking and there isn't too much info available online. If anyone has any pointers I appreciate any advice. NOTE* I currently only own 2600 games so those are all I have to test with. Quote Link to comment Share on other sites More sharing options...
78001987 Posted July 11, 2015 Share Posted July 11, 2015 Is it a pal console on an ntsc TV? Pal 7800s have a fat rainbow sticker on the silver plating. NTSC has a thin rainbow, surrounded by raised milled metal outline. Quote Link to comment Share on other sites More sharing options...
Desh Posted July 11, 2015 Author Share Posted July 11, 2015 (edited) It's NTSC... at least the shell is anyways. It sure does resemble a sync issue though. Edited July 11, 2015 by Desh Quote Link to comment Share on other sites More sharing options...
Desh Posted July 14, 2015 Author Share Posted July 14, 2015 Just an update. I figured out the problem. The problem ended up being my own stupidity. I got in touch with one of my local collector buddies who is a big Atari freak. I ended up purchasing another confirmed working 7800 off of him. When I got the replacement 7800 home I installed my composite/ s-video mod and just copied my install from the previous machine. When I tested it I had the e act same issue. At this point I realized it had to have been something I did. I originally followed the install guide from electronicsentimentalities.com but the pictures are pretty poor. I looked at longhorn engineer's install guide and found I had remove the wrong resistors and hooked up to the wrong connection points (I counted one too many). Anyways, now that I corrected the issue it works flawlessly. I also reassembled my original 7800 and it too works just fine. There are worse things in life than owning multiple 7800's. Quote Link to comment Share on other sites More sharing options...
