CoolCV emulator for Mac OS X, Linux, Windows and Raspberry
Colecovision Emulator Mac Windows
564 replies to this topic
#551 alortegac OFFLINE
alortegac
    Chopper Commander
  • 194 posts
Posted Wed Jan 23, 2019 5:49 PM
Thanks for your response. May you tell me please the correct display settings for Coolcv to work? Thanks again so much! Al
#552 knievel1 OFFLINE
knievel1
    Space Invader
  • 41 posts
I've got CoolCV 0.6.6 on Mojave -
At the risk of sounding dense, I click on the app to open. Didn't work.
Then, I tried dragging a game onto the app icon.
Nope. "CoolCV cannot be opened due to a problem"
Downloaded CoolCV all zip from thread here -- am I missing something?
A install step?
Tried dragging Buck Rogers SGM to icon as well as the SGM test ROM.
No luck.
thanks all for the help....
#553 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,797 posts
  • Coding something good
Posted Wed Jan 23, 2019 5:56 PM
You need to download and install libSDL https://www.libsdl.o.../SDL2-2.0.9.dmg
#554 knievel1 OFFLINE
knievel1
    Space Invader
  • 41 posts
Posted Thu Jan 24, 2019 6:44 PM
So for all us iMac users - install libSDL, run the CoolCV application - that's it?
#555 mumbai ONLINE
mumbai
    Dragonstomper
  • 751 posts
Posted Thu Jan 24, 2019 7:33 PM
Should be, for macOS users. This is a known issue mentioned upthread a while back (posts #338 to #340) where the libSDL packaged in the application bundle isn't (always? sometimes?) recognized as intended.
EDIT: "OS X" -> "macOS"
Edited by mumbai, Thu Jan 24, 2019 7:41 PM.
#556 alortegac OFFLINE
alortegac
    Chopper Commander
  • 194 posts
Posted Sat Jan 26, 2019 12:13 PM
Sorry! I don't know what happens. I don't know Launchbox nor I've tested it.
If CoolCV already worked in your setup, and doesn't work after installing LaunchBox, and also makes another emulator to fail, then it's pretty probable LaunchBox messed up your display settings.
The problem was the monitor. In case someone ever has a similar issue. I swapped to other monitor...and is now working fine. Weirdest issue.
#557 nanochess OFFLINE
nanochess
  • 5,797 posts
Posted Sat Jan 26, 2019 1:25 PM
Just searched for problem reports in libSDL and apparently there is a unsolved problem with different DPI settings in separate monitors https://stackoverflo...-second-monitor
#558 bhall408 ONLINE
bhall408
    Space Invader
  • 45 posts
Posted Tue Jan 29, 2019 9:56 PM
Yes, that will get the app to launch (without libSDL it will fail silently).
However I do find that the audio can be choppy compared to (for example) OpenEMU.
#559 ColecoJoe OFFLINE
ColecoJoe
    Dragonstomper
  • 514 posts
Posted Wed Jan 30, 2019 9:23 AM
That's weird, I have the opposite problem. By the way, OpenEmu is not a emulator, it's a collection of emulators. I believe it uses CrabEMU for Colecovision roms.
#560 alortegac OFFLINE
alortegac
    Chopper Commander
  • 194 posts
Posted Wed Jan 30, 2019 9:29 AM
Has anyone tried to set up WiiPro controller via mayflash?. Coolcv does not recognize them at all. Do I need call them differently (other than joy) in the config mappings? I am setting up mayflash in dinput mode, the controller is recognized successfully and it is working properly in all other applications. OS id won 7 64. Thanks!
Edited by alortegac, Wed Jan 30, 2019 9:29 AM.
#561 EVEGames OFFLINE
EVEGames
    Combat Commando
  • 3 posts
Posted Sun Feb 17, 2019 2:09 PM
@Nanochess,
Glad to see this thread is still chuggin'.
I recently installed CoolCV on a Raspberry Pi Zero W for the first time, and while I got it fully up and running, controller mapped properly, still it runs a bit laggy.
It starts with sound slightly stuttering and it seems to get progressively worse with time while playing a game.
Just wondering if there are any tips or tricks to squeeze additional performance out of CoolCV.
I have not yet gone as far as to overclock my Pi, I want to save that as a last resort.
Any tips from the creator?
Thanks again for all you do with CoolCV!
-Dave
#562 fdr4prez OFFLINE
fdr4prez
  • 1,882 posts
Posted Mon Feb 18, 2019 4:08 PM
@Nanochess,
-Dave
The Pi Zero isn't really overclockable
https://www.raspberr...ic.php?t=177743
https://www.raspberr...ic.php?t=127934
and many more topics floating around out there
You can try the new RPi3 A+ is you want a smallish formfactor
I've used coolcv on my RPi3B builds, but not in my Pi0 builds (for no particular reason).
#563 nanochess OFFLINE
nanochess
  • 5,797 posts
Posted Mon Feb 18, 2019 5:18 PM
@Nanochess,
-Dave
I don't have tested with Pi Zero, but it has performance equal less perfomance in comparison to Pi 2. I remember overclocking the Pi 2 to get the required speed but once I updated the base system it got slow again.
As I've been using Pi 3 I don't have yet returned to it to check if I can improve perfomance. Sorry.
#564 fdr4prez OFFLINE
fdr4prez
  • 1,882 posts
Posted Mon Feb 18, 2019 6:32 PM
I don't have tested with Pi Zero, but it has performance equal to Pi 2. I remember overclocking the Pi 2 to get the required speed but once I updated the base system it got slow again.
As I've been using Pi 3 I don't have yet returned to it to check if I can improve performance. Sorry.
The performance of the Pi0 and the Pi2 are not quite the same.
The Pi0 has 1-core CPU @1000MHz (1GHz) and 512MB of ram, but the Pi2 had 4-core CPU @900MHz and 1GB of ram
There is a fairly complete comparison chart:
http://socialcompare...dels-comparison
#565 nanochess OFFLINE
nanochess
  • 5,797 posts
Posted Mon Feb 18, 2019 6:58 PM
I stand corrected
Also tagged with one or more of these keywords: Colecovision, Emulator, Mac, Windows
2 user(s) are browsing this forum
1 members, 1 guests, 0 anonymous users
