dymus9 Posted July 23, 2015 Share Posted July 23, 2015 (edited) Hey Atariage! This is actually atariaction here but facebook seemed to sign me in under my super old user id! Anyways I've tried everything and now I'm certain that is is an internal component. Is there a chip or capacitor that is the typical cause of no video showing up? I have a solder iron as of late. Back in the day I tossed out dozens of systems. Nowadays I will try to repair. I'm hoping to save this one from the old fate. It is a 4 switch woodgrain. Let me know what you think. Thanks! Edited July 23, 2015 by dymus9 Quote Link to comment Share on other sites More sharing options...
zylon Posted July 24, 2015 Share Posted July 24, 2015 does it go to black screen or just "snow"? black screen is likely an IC, but snow could be voltage regulator or RF modulator. Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 22, 2015 Author Share Posted September 22, 2015 (edited) Thanks for the reply. Only took me 2 months to test and get back to you The screen is just black. Which IC chip do you think it is? Or s there only one? I have a parts machine I can steal an IC chip from maybe. If not are they pretty readily available like at my local electronics store? Also would an IC from a 6 switch work for the 4 switch system? Edited September 22, 2015 by dymus9 Quote Link to comment Share on other sites More sharing options...
zylon Posted September 22, 2015 Share Posted September 22, 2015 Chips from 6ers are the same as a 4sw. I would try the TIA first. That's the one on the bottom. 2nd choice is the RIOT, which is right under the cart slot. Riots can be bought from suppliers, but TIA' s can only be had from either Best Electronics or from another system. Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 23, 2015 Author Share Posted September 23, 2015 ok sweeeet thanks. will try that. just discovered they are socketed so no soldering needed! Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 23, 2015 Author Share Posted September 23, 2015 Ok I replaced the top and bottom chip. I get some fuzzyness now but stil no video. Does this all look correct? This pic shows the board with the 2 replacement chips installed to it. Quote Link to comment Share on other sites More sharing options...
zylon Posted September 23, 2015 Share Posted September 23, 2015 Did the parts machine work before removing the IC's? Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 24, 2015 Author Share Posted September 24, 2015 Crap. actually I found my note that said it was broken (but not sure what was wrong with it)! Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 24, 2015 Author Share Posted September 24, 2015 (edited) What about ic chips from an atari 2600 jr, will they work? Edited September 24, 2015 by dymus9 Quote Link to comment Share on other sites More sharing options...
zylon Posted September 24, 2015 Share Posted September 24, 2015 What about ic chips from an atari 2600 jr, will they work? Yes, but they are soldered in on Jr models. You can look up new RIOTs (6502) on ebay cheaply. Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 24, 2015 Author Share Posted September 24, 2015 OK thanks. Should I try the TIA 1st? Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted September 24, 2015 Share Posted September 24, 2015 I wish there was a 2600 Chipset, complete, ready for purchase and installation. Swapping chips is sort of a pain. But, necessary. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted September 25, 2015 Share Posted September 25, 2015 (edited) What about ic chips from an atari 2600 jr, will they work? Yes, but they are soldered in on Jr models. You can look up new RIOTs (6502) on ebay cheaply. Zylon mis-typed. You want a 6532 chip, NOT a 6502. But yes, they're cheaply available online. Edited September 25, 2015 by DrVenkman Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 25, 2015 Author Share Posted September 25, 2015 Zylon mis-typed. You want a 6532 chip, NOT a 6502. But yes, they're cheaply available online. ok thanks! ill grab one and try er out! Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 25, 2015 Author Share Posted September 25, 2015 (edited) do you have a link for ebay? i cant seem to find one? wait....would help if i put in the correct number Edited September 25, 2015 by dymus9 Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 25, 2015 Author Share Posted September 25, 2015 will this work? http://www.ebay.com/itm/1PCS-R6532P-R6532-8-BIT-Microprocessor-DIP-40-IC-CHIP-/250893307700?hash=item3a6a680f34 Quote Link to comment Share on other sites More sharing options...
zylon Posted September 25, 2015 Share Posted September 25, 2015 yes. I bought some of those. Only had one bad one in the bunch. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted September 25, 2015 Share Posted September 25, 2015 Like zylon, I bought a batch of 5 from an eBay seller in Hong Kong. One of them was bad but the second works great. Haven't yet tried the other three. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dymus9 Posted September 28, 2015 Author Share Posted September 28, 2015 Ok super. Im going to order me one up! I'll reply in a month when I get it in the mail Quote Link to comment Share on other sites More sharing options...
