Gury Posted July 30, 2015 Share Posted July 30, 2015 Hi, here are two examples incorporating core and alternative circle routines written in Mad Pascal. Just for fun! How about putting your circle examples here, maybe new circle masterpieces and algorithms? Example 1: // // Graphics 8 Circles Demonstration // by Bostjan Gorisek 2015 // // Developed in Mad-Pascal by Tebe / Madteam // // Alternative circle routine procedure CircleEx(x : Word; y, r : Byte); var a, c : Word; begin c := 0; a := r - 1; while r >= c do begin PutPixel(x+c, y+r); PutPixel(x+c, y-r); PutPixel(x-c, y-r); PutPixel(x-c, y+r); PutPixel(x+r, y+c); PutPixel(x+r, y-c); PutPixel(x-r, y-c); PutPixel(x-r, y+c); Inc(c); a := a + 1 - c - c; if (a and $8000) <> 0 then begin Dec(r); a := a + r + r; end; end; end; // Graphics mode 8 with text window procedure InitGraph8; begin asm { mwa #320 @command.mWidth mva #192 @command.mHeight }; asm { stx @sp ldy #08 ldx #$60 lda #%00010000 @graphics ldx @sp }; end; var i : Word; begin InitGraph8; Poke(710, 0); Poke(712, 0); Poke(752,1); SetColor(1); WriteLn('1... Core circle first, alt. one next'); Circle(30,20,20); CircleEx(72,20,20); Line(0,42,319,42); WriteLn('Press any key to continue!'); repeat until KeyPressed; WriteLn('2... Core circle first, alt. one next'); Circle(40,74,30); CircleEx(120,74,30); WriteLn('Press any key to continue!'); repeat until keypressed; WriteLn('3... Core circle first, alt. one next'); for i := 0 to 23 do begin Circle(70+i,100+i,20+i); end; for i := 0 to 23 do begin CircleEx(164+i,100+i,20+i); end; repeat until keypressed; end. Example 2: // // Graphics 8 Circles Demonstration // by Bostjan Gorisek 2015 // // Developed in Mad-Pascal by Tebe / Madteam // // Alternative circle routine procedure CircleEx(x : Word; y, r : Byte); var a, c : Word; begin c := 0; a := r - 1; while r >= c do begin PutPixel(x+c, y+r); PutPixel(x+c, y-r); PutPixel(x-c, y-r); PutPixel(x-c, y+r); PutPixel(x+r, y+c); PutPixel(x+r, y-c); PutPixel(x-r, y-c); PutPixel(x-r, y+c); Inc(c); a := a + 1 - c - c; if (a and $8000) <> 0 then begin Dec(r); a := a + r + r; end; end; end; // Graphics mode 8 with text window procedure InitGraph8; begin asm { mwa #320 @command.mWidth mva #192 @command.mHeight }; asm { stx @sp ldy #08 ldx #$60 lda #%00010000 @graphics ldx @sp }; end; var i : Word; begin InitGraph8; Poke(710, 0); Poke(712, 0); Poke(752,1); SetColor(1); WriteLn(' Visual effect :)'); for i := 0 to 18 do begin CircleEx(87+i,60+i,20+i*2); CircleEx(193+i,60+i,20+i*2); end; repeat until keypressed; end. I modified InitGraph routine to invoke text window in graphics mode 8, which is disables in core graph.pas library. circles.zip 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted July 30, 2015 Share Posted July 30, 2015 good example, thx p.s. http://www.freepascal.org/docs-html/rtl/graph/initgraph.html InitGraph - this function should be extended by an additional parameter Quote Link to comment Share on other sites More sharing options...
funkheld Posted July 30, 2015 Share Posted July 30, 2015 Hello, wonderful Grafik. Can you Grafik7 with text ? thanks Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 1, 2015 Share Posted August 1, 2015 The graphics library in this application is doing a strange CIO call to S: with the command PUT RECORD ($09) and a length of 0 in order to write a byte from the A register to plot a pixel. This breaks under the current version of AltirraOS, which I can fix, but shouldn't this be using PUT CHARACTERS ($0B) instead? The special case behavior for length=0 is a documented in the OS Manual for PUT CHARACTERS, but not for PUT RECORD. Arguably, this is a bug in CIO, because according the documentation it should be writing an EOL instead. Quote Link to comment Share on other sites More sharing options...
tebe Posted August 1, 2015 Share Posted August 1, 2015 mads/examples/libraries/graph_os/lib authors: Slawomir 'SERO' Ritter, Jakub Cebula, Winfried Hofacker Quote Link to comment Share on other sites More sharing options...
