iesposta Posted September 3, 2015 Share Posted September 3, 2015 Heavy Sixers are heavy. Much more case plastic and thicker, heavier aluminum motherboard shielding. The suggestion of weighing is good suggestion. Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted September 3, 2015 Share Posted September 3, 2015 FYI. A Heavy Sixer weighs slightly over 4.5 pounds and a Light Sixer weighs 3.33 pounds. Quote Link to comment Share on other sites More sharing options...
boxpressed Posted September 3, 2015 Share Posted September 3, 2015 (edited) Sorry if this has already been mentioned in this thread, but check out this thread:http://atariage.com/forums/topic/76656-the-official-heavy-sixer-serial-number-list/Look at the second post, near the bottom, under "Other Units."Based on the similarities in serial number with the first two listed in that section, I think it's likely that you have a Dimerco Taiwanese Heavy Sixer. EDIT: It's also possible that it is a light sixer. See this thread: http://atariage.com/forums/topic/142404-the-light-sixer-list/ Edited September 3, 2015 by boxpressed Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted September 3, 2015 Share Posted September 3, 2015 FYI. A Heavy Sixer weighs slightly over 4.5 pounds and a Light Sixer weighs 3.33 pounds. One pound and a couple ounces is more than enough to detect the console when weighing the box. The foam inserts and paperwork probably don't weigh much. We need to know exactly how much a CIB weighs for both models though. Quote Link to comment Share on other sites More sharing options...
Philflound Posted September 4, 2015 Share Posted September 4, 2015 That's why I suggested weighing both. You have to take into account the game, power supply, and controllers. Unless someone wants to just weigh items that come in the box separately and just add them together to come up with an approximate weight. Phil Quote Link to comment Share on other sites More sharing options...
Shawn Posted September 4, 2015 Share Posted September 4, 2015 Put it on a scale. Post the exact weight. Thread over. Quote Link to comment Share on other sites More sharing options...
MaximRecoil Posted September 26, 2015 Share Posted September 26, 2015 FYI. A Heavy Sixer weighs slightly over 4.5 pounds and a Light Sixer weighs 3.33 pounds. My "light sixer" (serial number: 81367396, made by Dimerco Electronics in Taiwan) weighs 3 lbs., 8.9 oz. (3.56 lbs.) That's with the RF cable included (since it isn't removable without taking the Atari apart). It is also missing 3 screws, and the front left corner of the case bottom is broken off, so it would probably weigh 3 lbs., 9 oz. normally. Quote Link to comment Share on other sites More sharing options...
Tree Posted May 29, 2018 Share Posted May 29, 2018 Did you ever sell the sealed 2600 Heavy Sixer? I would be interested. Thanks! Tree Quote Link to comment Share on other sites More sharing options...
Tree Posted May 29, 2018 Share Posted May 29, 2018 Sorry, it's a light sixer that you have...you can tell by the Made In Taiwan on the bottom right corner. Quote Link to comment Share on other sites More sharing options...
