sh3-rg Posted August 31, 2015 Share Posted August 31, 2015 Good effort that! Will definitely make use of this myself, cheers :0) 1 Quote Link to comment Share on other sites More sharing options...
ggn Posted August 31, 2015 Share Posted August 31, 2015 Hey, thanks for taking the time to do this! This will surely end up in rb+ one way or another (with your permission of course). I just want to take some time to optimise the code a bit (from briefly looking at it I think that all floating point instructions can be replaced with fixed point and the division(s) replaced by inverse multiplication). Anyway, I don't think I should attempt this tonight . 2 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted August 31, 2015 Author Share Posted August 31, 2015 No problems. I left it fairly verbose to make it more obvious what it was doing too. Feel free to use anywhere including examples etc. 2 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted September 1, 2015 Author Share Posted September 1, 2015 (edited) Also, please note that I added 1 to the width and height after retrieving from rgetobj near the beginning. This is so it worked out correctly and the sprite stayed more central. I can understand having to add 1 to the height because of the known issue but i'm not sure why adding 1 to the width helped it look better. Might just be rounding errors in the horrible math I used Edited September 1, 2015 by Sporadic 1 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted October 6, 2015 Share Posted October 6, 2015 (edited) Was just looking at scaled stuff and wanted to position an object centrally as a few different things throw values at the scale factor every frame. I remembered this thread but thought I'd muck about anyway. I found that, to position my spite centrally in x, if I did this: bingo=32-scale_factor ' normalise scale factor to 0 (probably the wrong term, a long time since I needed to know these things), 32 being 1:1 x_pos=x_offset+(bingo*2) ...that seems to place it where I want it and was working for scale values of 8 to 128. If anyone wants to give that a go and see if it works OK for their needs, that would be nice, and if not there's probably something close we can figure out that will. The actual code from my game is this: bingo=32-x_scale RSETOBJ(web,R_sprite_x,(x_off+(bingo*2))<<16) Edited October 6, 2015 by sh3-rg 1 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted October 6, 2015 Author Share Posted October 6, 2015 (edited) That looks similar to what I started with. Does that work for other sprite sizes? EDIT: Also, how is xoffset defined in your code? Its not shown in your post. Funny you should post this as I was looking at this code/thread today too! Edited October 6, 2015 by Sporadic Quote Link to comment Share on other sites More sharing options...
ggn Posted October 6, 2015 Share Posted October 6, 2015 Well, the hardware manual states: This eight bit field contains a three bit integer part and a five bit fractional part. The number determines how many pixels are written into the line buffer for each source pixel. Unless I'm grossly mistaken, if your width (or height) is "a" and your scale factor is "b" (from 0 to 255) then you can calculate the scaled size like this: a*b/(1<<5)=a*b/32. So, half the scaled size in order to find the centre would be a*b/64 (or (a*b)>>6). Add that to the corner coordinate and you have your centre coordinate. If you keep your coordinates in a longword variable (since raptor has 16 bits integer and 16 fraction) and perform the above calculation you'll end up with the fractions shifted to the proper bits. Problem is, the 68000 can't perform a 32bitsx16bits multiplication internally so gcc calls a helper function for this which consumes a few more cycles. So my advice would be if possible to perform these calculations offline, store them in a table of longs and then load them as needed. Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted October 6, 2015 Share Posted October 6, 2015 (edited) Well, the hardware manual states: Unless I'm grossly mistaken, if your width (or height) is "a" and your scale factor is "b" (from 0 to 255) then you can calculate the scaled size like this: a*b/(1<<5)=a*b/32. So, half the scaled size in order to find the centre would be a*b/64 (or (a*b)>>6). Add that to the corner coordinate and you have your centre coordinate. If you keep your coordinates in a longword variable (since raptor has 16 bits integer and 16 fraction) and perform the above calculation you'll end up with the fractions shifted to the proper bits. Problem is, the 68000 can't perform a 32bitsx16bits multiplication internally so gcc calls a helper function for this which consumes a few more cycles. So my advice would be if possible to perform these calculations offline, store them in a table of longs and then load them as needed. Why do you need to know the centre? That's probably the bit I'm not 100% on... maybe in some circumstances it's good to know the centre, I thought the issue was keeping a sprite centered as it scales. Edited October 6, 2015 by sh3-rg Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted October 6, 2015 Share Posted October 6, 2015 (edited) x_off is just the x position, sorry for that wording, it makes sense in my game but not typed out here. The stuff I posted doesn't take account of sprite width, it's only concerned with the scale factor vs the coordinate. If you wanted to position an object centrally on a given x coordinate, you'd offset what I did by half the sprite width... so e.g. with a 64-wide sprite you'd subtract 64/2 from your x position. Edited October 6, 2015 by sh3-rg Quote Link to comment Share on other sites More sharing options...
ggn Posted October 6, 2015 Share Posted October 6, 2015 Why do you need to know the centre? That's probably the bit I'm not 100% on... Sometimes it definitely helps if the origin is the middle of the sprite rather than in the corner. I thought sporadic asked for this? Also, if you know the centre coordinates of a sprite it's easier to move it around, especially if you're scaling up and down all the time. Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted October 6, 2015 Share Posted October 6, 2015 I thought sporadic asked for this? Also, if you know the centre coordinates of a sprite it's easier to move it around, especially if you're scaling up and down all the time. OK, so if you want to place a scaled sprite centred at x=160: bingo=32-x_scale RSETOBJ(web,R_sprite_x,(160-(sprite_width/2)+(bingo*2))<<16) something like that? Quote Link to comment Share on other sites More sharing options...
Sporadic Posted October 6, 2015 Author Share Posted October 6, 2015 Ill have a play tomorrow cheers guys. Ive gotta run Quote Link to comment Share on other sites More sharing options...
Sporadic Posted October 7, 2015 Author Share Posted October 7, 2015 bingo=32-scale_factor ' normalise scale factor to 0 (probably the wrong term, a long time since I needed to know these things), 32 being 1:1 x_pos=x_offset+(bingo*2) ...that seems to place it where I want it and was working for scale values of 8 to 128. If anyone wants to give that a go and see if it works OK for their needs, that would be nice, and if not there's probably something close we can figure out that will. Sorry, but this doesn't work for all sprite sizes. Please see attached scaler project that has a 64px sprite and a 128px sprite. The 128px scales in place correctly but the 64px sprite gets smaller from the left. Run it to see. DPad left/right to change scale sizes. This is why in my original scaler project, it took account of the scaled half sprite width, because it has to adjust the xpos accordingly to stop the sprite from moving left or right and scale it "in place". I think it works with the 128px sprite because that just "fits in" with the formula you posted. Yes, I was after a scale operation that scales the sprite centrally (so it gets bigger to the left and right), I wasn't after something to find the middle or to position the sprite based on the middle. Certainly if your sprite is about 128px then the above formula will be the quickest method as it just works for that size scaler_new.zip 1 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted October 7, 2015 Share Posted October 7, 2015 bugger, ok then :0) Quote Link to comment Share on other sites More sharing options...
