Darren01274 Posted August 28, 2015 Share Posted August 28, 2015 Hello got an Atari 2600 Jr and only displaying black and white, thought it might be the RF modulator, so av modded it and still black and white. Replaced black and white switch still same and even repaced the colour pot. Any ideas? Doesnt seem to be any bad solder joints on board, all capacitors look ok. Quote Link to comment Share on other sites More sharing options...
+RichG1972 Posted August 28, 2015 Share Posted August 28, 2015 Hello got an Atari 2600 Jr and only displaying black and white, thought it might be the RF modulator, so av modded it and still black and white. Replaced black and white switch still same and even repaced the colour pot. Any ideas? Doesnt seem to be any bad solder joints on board, all capacitors look ok. Did you try making an adjustment to the color potentiometer inside the unit? Looks like a flat white disc with a slot in it Quote Link to comment Share on other sites More sharing options...
+RichG1972 Posted August 28, 2015 Share Posted August 28, 2015 Did you try making an adjustment to the color potentiometer inside the unit? Looks like a flat white disc with a slot in it https://d3nevzfk7ii3be.cloudfront.net/igi/l6IGIygVLUPYeOwJ.medium In this photo it is the item with the black square around it Quote Link to comment Share on other sites More sharing options...
Darren01274 Posted August 28, 2015 Author Share Posted August 28, 2015 Hi yes made no difference at all, still black and white. Quote Link to comment Share on other sites More sharing options...
Darren01274 Posted August 28, 2015 Author Share Posted August 28, 2015 Wonder if it could be two faulty black and white switches? If I soldered underneath from midle pin to top pin would that put it in always colour? Quote Link to comment Share on other sites More sharing options...
darthkur Posted August 28, 2015 Share Posted August 28, 2015 I was just having this problem on my original light sixer. Turns out that the internal contacts in the cartridge port were dirty. I took a swab doused in rubbing alcohol and applied it to a cartridge. I then immediately inserted it and withdrew it from the console, repeatedly. Cleaned the crud off the cart and repeated the process until there was no new contaminants on the cart contacts. Quote Link to comment Share on other sites More sharing options...
Darren01274 Posted August 28, 2015 Author Share Posted August 28, 2015 I was just having this problem on my original light sixer. Turns out that the internal contacts in the cartridge port were dirty. I took a swab doused in rubbing alcohol and applied it to a cartridge. I then immediately inserted it and withdrew it from the console, repeatedly. Cleaned the crud off the cart and repeated the process until there was no new contaminants on the cart contacts. Hi tried that, still same, wonder if it could be bad TIA Quote Link to comment Share on other sites More sharing options...
