Bunsen Posted January 18, 2016 Share Posted January 18, 2016 Your program is mindblowing... Had some tests with my new tenliner wip. Your program don't like my program . The parser expects a string in the TEXT command, but I want to print it a number through a variable: TEXT 60,0,VAR Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 19, 2016 Author Share Posted January 19, 2016 Hi!, Your program is mindblowing... Thanks! Had some tests with my new tenliner wip. Your program don't like my program . The parser expects a string in the TEXT command, but I want to print it a number through a variable: TEXT 60,0,VAR Fixes this and other minor errors: - Parsing of *F / *B / *L with +/-. - Parser could crash with invalid counts in extended strings. - Bogus error in some cases with extended strings. - Parsing of CIRCLE with 4 parameters (ellipses). - Parsing of TEXT with a numeric argument instead of string. As always, download the new release at github: https://github.com/dmsc/tbxl-parser/releases/tag/v9.2 4 Quote Link to comment Share on other sites More sharing options...
Bunsen Posted January 19, 2016 Share Posted January 19, 2016 Great!! Now I am struggling with Atari special characters like inverse characters or graphics characters. I want to program in a windows text editor and parse it to tokenized turbo basic program. If I haven't overseen anything then it is not possible. Perhaps the ATASCI code in square brackets could be translated (parsed/transformed/...) to the special character in the tokenized basic file? [0] would become the heart character and [160] would become inverse space for example. The square brackets are barely used and could function as signal characters. Quote Link to comment Share on other sites More sharing options...
pirx Posted January 19, 2016 Share Posted January 19, 2016 heeeey, this is a basic functionality of dmsc tool! Just type "\AF\00\9B" and you are good. And look up https://github.com/dmsc/tbxl-parser)))) Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 19, 2016 Author Share Posted January 19, 2016 Hi!, Great!! Now I am struggling with Atari special characters like inverse characters or graphics characters. I want to program in a windows text editor and parse it to tokenized turbo basic program. If I haven't overseen anything then it is not possible. Perhaps the ATASCI code in square brackets could be translated (parsed/transformed/...) to the special character in the tokenized basic file? [0] would become the heart character and [160] would become inverse space for example. The square brackets are barely used and could function as signal characters. heeeey, this is a basic functionality of dmsc tool! Just type "\AF\00\9B" and you are good. And look up https://github.com/dmsc/tbxl-parser )))) Yes!, you can also use "extended strings", like: print ["{clr} Press ~START~ to continue. "]This will be converted to a character 125 (clear screen) and the "START" to inverse video. See another example at https://github.com/dmsc/tbxl-parser/blob/master/samples/sample-3.txt Quote Link to comment Share on other sites More sharing options...
Bunsen Posted January 19, 2016 Share Posted January 19, 2016 Wow, I HAVE overseen it. What a mighty tool. Quote Link to comment Share on other sites More sharing options...
Savetz Posted January 21, 2016 Share Posted January 21, 2016 I'd like to try this — it looks amazing and I'm having real trouble this year with the tokenizer in TBXL (a problem I haven't had in previous contests.) But I use a Mac and don't see a macos build. (I downloaded it and tried to just "make" but that didn't work, and anyway I'm lazy.) Is there a Mac build? Thanks Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 22, 2016 Author Share Posted January 22, 2016 Hi!, I'd like to try this it looks amazing and I'm having real trouble this year with the tokenizer in TBXL (a problem I haven't had in previous contests.) But I use a Mac and don't see a macos build. (I downloaded it and tried to just "make" but that didn't work, and anyway I'm lazy.) Is there a Mac build? Thanks Sorry, I don't have a Mac and don't know of any Linux based cross-compiler available, so can't build here. But, here is a source version with all generated C sources already built, this should be easier to compile by just typing make. I recommend using the command: make CC=gcc CROSS= EXT= CFLAGS='-Wall -O2 -flto -DNDEBUG' dist If your compiler is not "gcc", replace it in the "CC=" part and remove the "-flto" (link-time-optimization) if it does not work. After compilation, the above command will generate an output ZIP file (if the zip utility is in the PATH) with the executable, README, samples and license files. If the make command does not work, the last resort is simply calling the compiler directly: gcc -Wall -O2 -DNDEBUG -Ibuild/src src/ataribcd.c src/basexpr.c src/basic.c src/baswriter.c src/convertbas.c src/darray.c src/defs.c src/expr.c src/lister.c src/listexpr.c src/main.c src/optconst.c src/optconstvar.c src/optimize.c src/optlinenum.c src/optrmvars.c src/parser.c src/procparams.c src/program.c src/sbuf.c src/vars.c build/src/statements.c build/src/tokens.c -o basicParser -lm The above command will produce an executable "basicParser" directly in the base directory. Note that not all C files are in the above command line, so simply "build/src/*.c" does not work.basicParser-source-v9.2.0.zip Quote Link to comment Share on other sites More sharing options...
devwebcl Posted January 22, 2016 Share Posted January 22, 2016 I compiled directly with Mac OS X and it worked, though I haven't test it much Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 22, 2016 Author Share Posted January 22, 2016 Hi!, I compiled directly with Mac OS X and it worked, though I haven't test it much If you can post here the generated ZIP file (or the executable only), I can upload it to the github page, so it is available for anyone. Thanks, Quote Link to comment Share on other sites More sharing options...
devwebcl Posted January 22, 2016 Share Posted January 22, 2016 I had the following warnings: $ make >> stdout.txt fatal: Not a git repository (or any of the parent directories): .git In file included from src/basic.c:50: build/src/basic_peg.c:10200:1: warning: unused label 'l453' [-Wunused-label] l453:; ^~~~~ build/src/basic_peg.c:242:15: warning: unused function 'yyAccept' [-Wunused-function] YY_LOCAL(int) yyAccept(yycontext *yy, int tp0) ^ 2 warnings generated. When I check the version, I get: (no version at all) $ ./basicParser -help TurboBasic XL parser tool - version https://github.com/dmsc/tbxl-parser Usage: ./basicParser [options] filename -l Output long (readable) program. -b Output binary (.BAS) program. (default) -s Output short listing program. -n In short listing, sets the max line length before splitting (120). -f Output full (long) variable names in binary output. -x Makes binary output protected (un-listable). -a In long output, convert comments to pure ASCII. -v Shows more parsing information (verbose mode). -q Don't show parsing information (quiet mode). -o Sets the output file name or extension (if starts with a dot). -c Output to standard output instead of a file. -O Defaults to run the optimizer in the parsed program. -h Shows help and exit. basicParser-source-v9.2.0-macosx.zip Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 22, 2016 Author Share Posted January 22, 2016 Hi!, I had the following warnings: $ make >> stdout.txt fatal: Not a git repository (or any of the parent directories): .git In file included from src/basic.c:50: build/src/basic_peg.c:10200:1: warning: unused label 'l453' [-Wunused-label] l453:; ^~~~~ build/src/basic_peg.c:242:15: warning: unused function 'yyAccept' [-Wunused-function] YY_LOCAL(int) yyAccept(yycontext *yy, int tp0) ^ 2 warnings generated. The two warnings are expected, this is the code generated by PEG, so I can't modify it.When I check the version, I get:(no version at all) $ ./basicParser -help TurboBasic XL parser tool - version https://github.com/dmsc/tbxl-parser Yes, I missed that the makefile uses GIT to generate the version string, a shame but the binary should work. I built and uploaded a binary archive to github, see at: https://github.com/dmsc/tbxl-parser/releases/tag/v9.2 Thanks again! Quote Link to comment Share on other sites More sharing options...
Savetz Posted January 24, 2016 Share Posted January 24, 2016 Thank you for the Mac binary — I've been able to test the program, and it shows promise! But now a problem. I ran my program through basicParser to create a BAS file, but when I try to LOAD it back into the Atari, I get ERROR- 140 NOT IMPL AT LINE 0. I did it again, creating a LST file — when I do ENTER"D: ... same thing, NOT IMPL. I don't know why, or what to do to fix it. What's not implemented? My original first line: DIM L(4),M(4),F$(40),Z$(4):F$="EIMR3IRI3RIRIJJRI3JR":FOR X=1 TO 5:L(X-1)=20*X+X:NEXT X:Q=500 The parsed version: 0DIMA(4),B(4),A$(40),B$(4):A$="EIMR3IRI3RIRIJJRI3JR":F.A=1TO5:A(A-1)=20*A+A:N.A:B=500 I tried again with -f to preserve my variable names, and got ERROR- 140 NOT IMPL AT LINE 100. help? Thanks Kevin Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 24, 2016 Share Posted January 24, 2016 Try FOR X=0 TO 4 Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 24, 2016 Author Share Posted January 24, 2016 Hi!, Thank you for the Mac binary I've been able to test the program, and it shows promise! But now a problem. I ran my program through basicParser to create a BAS file, but when I try to LOAD it back into the Atari, I get ERROR- 140 NOT IMPL AT LINE 0. I did it again, creating a LST file when I do ENTER"D: ... same thing, NOT IMPL. I don't know why, or what to do to fix it. What's not implemented? My original first line: DIM L(4),M(4),F$(40),Z$(4):F$="EIMR3IRI3RIRIJJRI3JR":FOR X=1 TO 5:L(X-1)=20*X+X:NEXT X:Q=500 The parsed version: 0DIMA(4),B(4),A$(40),B$(4):A$="EIMR3IRI3RIRIJJRI3JR":F.A=1TO5:A(A-1)=20*A+A:N.A:B=500 I tried again with -f to preserve my variable names, and got ERROR- 140 NOT IMPL AT LINE 100. help? Thanks Kevin There are a few strange thinks in your example: - Your program works here, both as saved ".BAS" or as listed ".LST". - Error 140 is "serial bus error". - "NOT IMPL" is error 146. So, both errors are SIO errors, not BASIC errors. My guess is that you are LOADing or ENTERing the program with a bad file name, or no DOS. Normally, you should type LOAD "D:MYPROG.BAS" or ENTER "D:MYPROG.LST" Quote Link to comment Share on other sites More sharing options...
Savetz Posted January 24, 2016 Share Posted January 24, 2016 You're right, it was error 146 — I mistyped it. I've narrowed the problem: I can't do ANYTHING with those files, even delete them in DOS, on the Atari. Something about using Atari800MacX to import the files from the Mac is creating invalid files. Aaaargh. thanks -K Quote Link to comment Share on other sites More sharing options...
Savetz Posted January 25, 2016 Share Posted January 25, 2016 I've gotten everything working, and wow — the Basic Parsing and Transformation Tool is amazing. Well done! It is already changing how I code 10-liners for the better. (Now I wish Atari800Mac X had hooks to make it automatic to import and run files created with BPTT.) Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted January 25, 2016 Share Posted January 25, 2016 (Now I wish Atari800Mac X had hooks to make it automatic to import and run files created with BPTT.) Maybe this: http://atariage.com/forums/topic/244686-turban-turbobasic-nifty/?p=3346930helps? Quote Link to comment Share on other sites More sharing options...
Savetz Posted January 25, 2016 Share Posted January 25, 2016 Oh that looks amazing. Now I'm trying to figure out if it works with Mac. Quote Link to comment Share on other sites More sharing options...
pirx Posted January 26, 2016 Share Posted January 26, 2016 hello dmsc just a humble feature request to mighty $incbin directive: $incbin *defineName$* , "*fileName*" could you pls extend it similarly to mads "INS" command: INS 'filename'["filename"][*][+-value][,+-ofset[,length]] The INS pseudo-command allows inclusion of an external binary file. The included file does not have to be in the same directory as the main file being assembled. Search paths for the file can be configurated using the /i switch (see assembly switches). Additionally, you can perform the following operations on the binary data: * invert bytes +-VALUE increase or decrease each byte by the value of the expression VALUE +OFSET skip OFSET bytes at the beginning of the file (seek to OFSET) -OFSET read OFSET bytes at the end of the file (seek to FileLength-OFSET) LENGTH read LENGTH bytes from the file If the LENGTH value is not specified, the default behavior is to read to the end. Definitely a sufficient addition would be: $incbin *defineName$* , "*fileName*", OFFSET, LENGTH (skip OFFSET bytes and read LENGTH bytes). It would make it possible to e.g. include a whole font from one file to a bunch of variables. Also including (bmp) and other _almost_ plain picture format would be easier. Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 27, 2016 Author Share Posted January 27, 2016 Hi!, hello dmsc just a humble feature request to mighty $incbin directive: $incbin *defineName$* , "*fileName*"could you pls extend it similarly to mads "INS" command: INS 'filename'["filename"][*][+-value][,+-ofset[,length]] The INS pseudo-command allows inclusion of an external binary file. The included file does not have to be in the same directory as the main file being assembled. Search paths for the file can be configurated using the /i switch (see assembly switches). Additionally, you can perform the following operations on the binary data: * invert bytes +-VALUE increase or decrease each byte by the value of the expression VALUE +OFSET skip OFSET bytes at the beginning of the file (seek to OFSET) -OFSET read OFSET bytes at the end of the file (seek to FileLength-OFSET) LENGTH read LENGTH bytes from the file If the LENGTH value is not specified, the default behavior is to read to the end.Definitely a sufficient addition would be: $incbin *defineName$* , "*fileName*", OFFSET, LENGTH(skip OFFSET bytes and read LENGTH bytes). It would make it possible to e.g. include a whole font from one file to a bunch of variables. Also including (bmp) and other _almost_ plain picture format would be easier. Ok, here is a new version with optional "OFFSET" and "LENGTH" added to the $incbin directive: https://github.com/dmsc/tbxl-parser/releases/tag/v9.3 Please, test the new version and review the "README.md" 1 Quote Link to comment Share on other sites More sharing options...
pirx Posted January 27, 2016 Share Posted January 27, 2016 (edited) Wow! I haven't expected the feature this quick, your TBXL based language gets better and better!!! Thanks Edited January 27, 2016 by pirx Quote Link to comment Share on other sites More sharing options...
pirx Posted January 27, 2016 Share Posted January 27, 2016 BTW - it works as advertised Quote Link to comment Share on other sites More sharing options...
pirx Posted January 28, 2016 Share Posted January 28, 2016 hello dmsc, incbin works like a charm now, so i've got another, quite bold request this time. it would be really nice to be able to type: $incbin sprite$, "char6.fnt", (16+5)*8, 12*8 instead of $incbin sprite$, "char6.fnt", 176, 96 i reckon this ain't no easy, but i see in README.md poke @PCOLR0+2, $1F : ' Replaced by: POKE 706,31 so you basically have some arithmetic already. best, pirx Quote Link to comment Share on other sites More sharing options...
dmsc Posted January 29, 2016 Author Share Posted January 29, 2016 Hi!, ... macos version ... I uploaded a new MAC build at https://github.com/dmsc/tbxl-parser/releasesfor version 9.3, cross-compiled from Linux, can you test it? If it works, I can add the build recipe to my release script, and compile on each releas. Quote Link to comment Share on other sites More sharing options...
