Star Raiders Source Code to be released?
233 replies to this topic
#176 Rybags OFFLINE
Rybags
  • 15,347 posts
Posted Sun Nov 1, 2015 6:10 AM
You need to stay in front view and steer the crosshair in higher modes during warp, that's been the way always.
In Novice you can select an alternate view/map and warp accurately so long as you don't inadvertantly steer it off course yourself.
It's a worthwhile shortcut in Novice to save a few seconds (unsure if it affects energy use, might save a couple of units) by just leaving it on the Galactic Map.
I would suggest speed clamping might be needed if warp becomes too fast, especially considering what a 7+ MHz slave processor might be able to accomplish.
#177 JamesD OFFLINE
JamesD
  • 7,959 posts
Posted Sun Nov 1, 2015 6:11 AM
Well. That would happen if the difficulty is set higher than Novice, because then you need to use the front view to control the crosshairs manually when you are in hyperspace, Or you might end up in a different quadrant then you selected in the map, This normal behaviour in Star Raiders orginal Atari game.
I was on Novice, so that behavior seems to have changed then?
#178 a8isa1 ONLINE
a8isa1
  • 1,395 posts
Posted Sun Nov 1, 2015 9:35 AM
In novice mode, forward view, you don't have to steer.
but In galactic map mode your destination will be random.
IIRC there was a cheat for the higher difficulty modes.  I can't remember what it is.  Long range scanner mode then warp?
[EDIT - I thought this cheat existed but I was wrong]
Edited by a8isa1, Sun Nov 1, 2015 9:59 AM.
#179 JamesD OFFLINE
JamesD
  • 7,959 posts
Posted Sun Nov 1, 2015 12:04 PM
Ugh, I wen't back and played the cart version to compare behavior and the lag seems so much worse now.
#180 potatohead OFFLINE
potatohead
  • 4,397 posts
Posted Sun Nov 1, 2015 2:03 PM
I actually really like the lag.
Technically, I've enjoyed reading all the discussion to improve this game in that respect.  Fun stuff.
But, that feel in battle makes it seem intense in a way similar to how DEFENDER feels when one manages to overdrive that one.
Just an observation.
Maybe all the extra time could be put to good use doing more stuff, so that when it does reach slow do1n, it is harder to do with more going on.
#181 Grevle OFFLINE
Grevle
    Moonsweeper
  • 373 posts
Posted Sun Nov 1, 2015 5:08 PM
This version (Fastdiv 3) is amazingly fast, Even on PAL Atari it plays so smoothly, on NTSC Atari is almost insainly fast, To me this verison is so fast on Pal that maybe we could have a Pal version with edited colors so that the when playing on Pal Atari would have the same colors as the NTSC (Bluish color on the shield and so on).
The feel when shooting Zylons are quite different in this version, feels more like proper dogfighting and quick reaction is needed to avoid when Zylons shooting at you. i Like it :thumbsup: .
#182 ClausB OFFLINE
ClausB
  • 1,432 posts
Posted Sun Nov 1, 2015 9:38 PM
Here's the fast divide I did 5 years ago. It uses fast and small reciprocal and quarter-square LUTs similar to my FAFMUL, except in binary instead of BCD, and signed and scaled fractional instead of unsigned integer. It also prescales the divisor and dividened for maximum resolution in the 8-bit quotient. The prescaler is a big unrolled shifting loop with extra optimizations to shift either left or right, whichever is shorter. It normalizes X so the hi bit is always 1 and then shifts Y and Z by the same amount. Then X goes through a reciprocal LUT before being multiplied by Y and Z.
The quarter-square LUT method works because 4*a*b = (a+b)^2 - (a-b)^2. So the small 1-D LUT only stores squares, as opposed to a huge 2-D multiplication LUT. Also the constant multiplier of 80 is built into the quater-square LUTs. It's very fast but can jitter in the lo bit.
	CPU     6502
QSP1:	EQU	0CBH
QSP2:	EQU	0CDH
XL:	EQU	0CBH
XH:	EQU	0CDH
YL:	EQU	0D4H
YH:	EQU	0D0H
ZL:	EQU	0D5H
ZH:	EQU	0D1H
	ORG	TL-6	; .OBJ file header
	DFB     0FFH,0FFH,<TL,>TL,<END,>END
	ORG	09000H
TL:	PLA             ; BASIC arg stack for testing
	PLA
	STA	XH
	PLA
	STA	XL
	PLA
	STA	YH
	PLA
	STA	YL
	PLA
	STA	ZH
	PLA
	STA	ZL
DIV:	LDA	#>QSQS  ; Patched divide routine
	STA	QSP1+1
	LDA	#>QSQD
	STA	QSP2+1  ; QS LUT page addresses - QS tables are already scaled by 80
	CLD
	LDA	XH
	BNE	SHH
	JMP	SHL
SHH:	BMI	SH0     ; Shift X until hi bit is 1 and then shift Y and Z by the same
	ASL	XL
	ROL	A
	BMI	SH1
	ASL	XL
	ROL	A
	BMI	SH2
	ASL	XL
	ROL	A
	BMI	SH3
	ASL	XL
	ROL	A
	BMI	SH4
	ASL	XL
	ROL	A
	BMI	SH5
	ASL	XL
	ROL	A
	BMI	SH6
	ASL	XL
	ROL	A
	BMI	SH7
SH3:	ASL	YL
	ROL	YH
	BCS	OVF
	ASL	ZL
	ROL	ZH
	BCS	OVF
SH2:	ASL	YL
	ROL	YH
	BCS	OVF
	ASL	ZL
	ROL	ZH
	BCS	OVF
SH1:	ASL	YL
	ROL	YH
	BCS	OVF
	ASL	ZL
	ROL	ZH
	BCS	OVF
SH0:	ASL	XL
	ROL	A
	TAY
	LDA	RCP,Y   ; Reciprocal of shifted X
	STA	QSP1
	EOR	#0FFH
	TAY
	INY
	STY	QSP2    ; Negate
	LDY	YH
	LDA	(QSP1),Y
	SEC
	SBC	(QSP2),Y
	LSR	A
	STA	YL      ; 80*Y/X = QS(Y+1/X)-QS(Y-1/X)
	LDY	ZH
	LDA	(QSP1),Y
	SEC
	SBC	(QSP2),Y
	LSR	A
	STA	ZL      ; 80*Z/X = QS(Z+1/X)-QS(Z-1/X)
	RTS
SH4:	LSR	YH
	ROR	YL
	LSR	ZH
	ROR	ZL
SH5:	LSR	YH
	ROR	YL
	LSR	ZH
	ROR	ZL
SH6:	LSR	YH
	ROR	YL
	LSR	ZH
	ROR	ZL
SH7:	LSR	YH
	BNE	OVF
	ROR	YL
	LSR	ZH
	BNE	OVF
	ROR	ZL
	ASL	XL
	ROL	A
	JMP	DVL
OVF:	LDA	#0FFH   ; Overflow if Y or Z much more than X, or X=0
	STA	YL
	STA	ZL
	RTS
SHL:	LDA	YH
	BNE	OVF
	LDA	ZH
	BNE	OVF
	LDA	XL
	BEQ	OVF
	BMI	SH8
	ASL	A
	BMI	SH9
	ASL	A
	BMI	SHA
	ASL	A
	BMI	SHB
	ASL	A
	BMI	SHC
	ASL	A
	BMI	SHD
	ASL	A
	BPL	OVF
SHE:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SHD:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SHC:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SHB:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SHA:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SH9:	ASL	YL
	BCS	OVF
	ASL	ZL
	BCS	OVF
SH8:	ASL	A
DVL:	TAY
	STA	QSP1
	EOR	#0FFH
	TAY
	INY
	STY	QSP2    ; Negate
	LDY	YL
	LDA	(QSP1),Y
	SEC
	SBC	(QSP2),Y
	LSR	A
	LDY	ZL
	LDA	(QSP1),Y
	SEC
	SBC	(QSP2),Y
	LSR	A
	RTS
	DFB     0       ; Pad to page-align LUTs
	DWL     0,0,0,0,0,0
	DWL     0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
RCP:    DFB     0FFH,0FEH,0FDH,0FCH,0FBH,0FAH,0F9H,0F8H,0F7H,0F6H,0F5H,0F5H,0F4H,0F3H,0F2H,0F1H
        DFB     0F0H,0EFH,0EEH,0EDH,0EDH,0ECH,0EBH,0EAH,0E9H,0E8H,0E8H,0E7H,0E6H,0E5H,0E4H,0E4H
        DFB     0E3H,0E2H,0E1H,0E0H,0E0H,0DFH,0DEH,0DDH,0DDH,0DCH,0DBH,0DAH,0DAH,0D9H,0D8H,0D8H
        DFB     0D7H,0D6H,0D5H,0D5H,0D4H,0D3H,0D3H,0D2H,0D1H,0D1H,0D0H,0CFH,0CFH,0CEH,0CDH,0CDH
        DFB     0CCH,0CBH,0CBH,0CAH,0CAH,0C9H,0C8H,0C8H,0C7H,0C7H,0C6H,0C5H,0C5H,0C4H,0C4H,0C3H
        DFB     0C2H,0C2H,0C1H,0C1H,0C0H,0C0H,0BFH,0BEH,0BEH,0BDH,0BDH,0BCH,0BCH,0BBH,0BBH,0BAH
        DFB     0BAH,0B9H,0B9H,0B8H,0B7H,0B7H,0B6H,0B6H,0B5H,0B5H,0B4H,0B4H,0B3H,0B3H,0B2H,0B2H
        DFB     0B1H,0B1H,0B1H,0B0H,0B0H,0AFH,0AFH,0AEH,0AEH,0ADH,0ADH,0ACH,0ACH,0ABH,0ABH,0ABH
        DFB     0AAH,0AAH,0A9H,0A9H,0A8H,0A8H,0A7H,0A7H,0A7H,0A6H,0A6H,0A5H,0A5H,0A5H,0A4H,0A4H
        DFB     0A3H,0A3H,0A3H,0A2H,0A2H,0A1H,0A1H,0A1H,0A0H,0A0H,09FH,09FH,09FH,09EH,09EH,09DH
        DFB     09DH,09DH,09CH,09CH,09CH,09BH,09BH,09AH,09AH,09AH,099H,099H,099H,098H,098H,098H
        DFB     097H,097H,097H,096H,096H,096H,095H,095H,094H,094H,094H,093H,093H,093H,092H,092H
        DFB     092H,092H,091H,091H,091H,090H,090H,090H,08FH,08FH,08FH,08EH,08EH,08EH,08DH,08DH
        DFB     08DH,08DH,08CH,08CH,08CH,08BH,08BH,08BH,08AH,08AH,08AH,08AH,089H,089H,089H,088H
        DFB     088H,088H,088H,087H,087H,087H,086H,086H,086H,086H,085H,085H,085H,085H,084H,084H
        DFB     084H,083H,083H,083H,083H,082H,082H,082H,082H,081H,081H,081H,081H,080H,080H,080H
QSQD:   DFB     050H,050H,04FH,04EH,04EH,04DH,04DH,04CH,04BH,04BH,04AH,04AH,049H,048H,048H,047H
        DFB     047H,046H,045H,045H,044H,044H,043H,043H,042H,041H,041H,040H,040H,03FH,03FH,03EH
        DFB     03DH,03DH,03CH,03CH,03BH,03BH,03AH,03AH,039H,039H,038H,038H,037H,037H,036H,036H
        DFB     035H,035H,034H,034H,033H,033H,032H,032H,031H,031H,030H,030H,02FH,02FH,02EH,02EH
        DFB     02DH,02DH,02CH,02CH,02BH,02BH,02AH,02AH,029H,029H,029H,028H,028H,027H,027H,026H
        DFB     026H,026H,025H,025H,024H,024H,023H,023H,023H,022H,022H,021H,021H,021H,020H,020H
        DFB     01FH,01FH,01FH,01EH,01EH,01DH,01DH,01DH,01CH,01CH,01CH,01BH,01BH,01AH,01AH,01AH
        DFB     019H,019H,019H,018H,018H,018H,017H,017H,017H,016H,016H,016H,015H,015H,015H,014H
        DFB     014H,014H,013H,013H,013H,013H,012H,012H,012H,011H,011H,011H,010H,010H,010H,010H
        DFB     00FH,00FH,00FH,00FH,00EH,00EH,00EH,00EH,00DH,00DH,00DH,00DH,00CH,00CH,00CH,00CH
        DFB     00BH,00BH,00BH,00BH,00AH,00AH,00AH,00AH,009H,009H,009H,009H,009H,008H,008H,008H
        DFB     008H,008H,007H,007H,007H,007H,007H,007H,006H,006H,006H,006H,006H,006H,005H,005H
        DFB     005H,005H,005H,005H,004H,004H,004H,004H,004H,004H,004H,003H,003H,003H,003H,003H
        DFB     003H,003H,003H,002H,002H,002H,002H,002H,002H,002H,002H,002H,002H,002H,001H,001H
        DFB     001H,001H,001H,001H,001H,001H,001H,001H,001H,001H,001H,001H,000H,000H,000H,000H
        DFB     000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H
QSQS:   DFB     000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H,000H
        DFB     000H,000H,000H,000H,000H,001H,001H,001H,001H,001H,001H,001H,001H,001H,001H,001H
        DFB     001H,001H,001H,002H,002H,002H,002H,002H,002H,002H,002H,002H,002H,002H,003H,003H
        DFB     003H,003H,003H,003H,003H,003H,004H,004H,004H,004H,004H,004H,004H,005H,005H,005H
        DFB     005H,005H,005H,006H,006H,006H,006H,006H,006H,007H,007H,007H,007H,007H,007H,008H
        DFB     008H,008H,008H,008H,009H,009H,009H,009H,009H,00AH,00AH,00AH,00AH,00BH,00BH,00BH
        DFB     00BH,00CH,00CH,00CH,00CH,00DH,00DH,00DH,00DH,00EH,00EH,00EH,00EH,00FH,00FH,00FH
        DFB     00FH,010H,010H,010H,010H,011H,011H,011H,012H,012H,012H,013H,013H,013H,013H,014H
        DFB     014H,014H,015H,015H,015H,016H,016H,016H,017H,017H,017H,018H,018H,018H,019H,019H
        DFB     019H,01AH,01AH,01AH,01BH,01BH,01CH,01CH,01CH,01DH,01DH,01DH,01EH,01EH,01FH,01FH
        DFB     01FH,020H,020H,021H,021H,021H,022H,022H,023H,023H,023H,024H,024H,025H,025H,026H
        DFB     026H,026H,027H,027H,028H,028H,029H,029H,029H,02AH,02AH,02BH,02BH,02CH,02CH,02DH
        DFB     02DH,02EH,02EH,02FH,02FH,030H,030H,031H,031H,032H,032H,033H,033H,034H,034H,035H
        DFB     035H,036H,036H,037H,037H,038H,038H,039H,039H,03AH,03AH,03BH,03BH,03CH,03CH,03DH
        DFB     03DH,03EH,03FH,03FH,040H,040H,041H,041H,042H,043H,043H,044H,044H,045H,045H,046H
        DFB     047H,047H,048H,048H,049H,04AH,04AH,04BH,04BH,04CH,04DH,04DH,04EH,04EH,04FH,050H
        DFB     050H,051H,052H,052H,053H,053H,054H,055H,055H,056H,057H,057H,058H,059H,059H,05AH
        DFB     05BH,05BH,05CH,05DH,05DH,05EH,05FH,05FH,060H,061H,061H,062H,063H,064H,064H,065H
        DFB     066H,066H,067H,068H,068H,069H,06AH,06BH,06BH,06CH,06DH,06EH,06EH,06FH,070H,071H
        DFB     071H,072H,073H,074H,074H,075H,076H,077H,077H,078H,079H,07AH,07AH,07BH,07CH,07DH
        DFB     07DH,07EH,07FH,080H,081H,081H,082H,083H,084H,085H,085H,086H,087H,088H,089H,08AH
        DFB     08AH,08BH,08CH,08DH,08EH,08FH,08FH,090H,091H,092H,093H,094H,094H,095H,096H,097H
        DFB     098H,099H,09AH,09AH,09BH,09CH,09DH,09EH,09FH,0A0H,0A1H,0A1H,0A2H,0A3H,0A4H,0A5H
        DFB     0A6H,0A7H,0A8H,0A9H,0AAH,0ABH,0ABH,0ACH,0ADH,0AEH,0AFH,0B0H,0B1H,0B2H,0B3H,0B4H
        DFB     0B5H,0B6H,0B7H,0B8H,0B8H,0B9H,0BAH,0BBH,0BCH,0BDH,0BEH,0BFH,0C0H,0C1H,0C2H,0C3H
        DFB     0C4H,0C5H,0C6H,0C7H,0C8H,0C9H,0CAH,0CBH,0CCH,0CDH,0CEH,0CFH,0D0H,0D1H,0D2H,0D3H
        DFB     0D4H,0D5H,0D6H,0D7H,0D8H,0D9H,0DAH,0DBH,0DCH,0DDH,0DEH,0DFH,0E0H,0E2H,0E3H,0E4H
        DFB     0E5H,0E6H,0E7H,0E8H,0E9H,0EAH,0EBH,0ECH,0EDH,0EEH,0EFH,0F1H,0F2H,0F3H,0F4H,0F5H
        DFB     0F6H,0F7H,0F8H,0F9H,0FAH,0FBH,0FDH,0FEH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
        DFB     0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
END:	DFB	0FFH
#183 phaeron OFFLINE
phaeron
  • 2,342 posts
Posted Mon Nov 2, 2015 11:13 PM
The algorithm I use in fastdiv3 is essentially the log() based algorithm proposed by others earlier in the thread, although with a lot of massaging:
   result = ptab[exp2(log2(y) - log2(x))]
The logarithm is computed base 2 as a 16-bit result in 8.8 fixed point. The argument is first normalized via left shift until bit 16 is set (separately for each argument, not together). Since bit 16 is then known to be 1, it is discarded and bits 15-7 are used to look up in a table of log2(1 + x/256). The high byte is set based on the length of the left shift needed to normalize.
That leaves how to do the normalization shift quickly. The amount of shift needed can be determined by looking up the high byte or low byte in a 256 byte table, depending on whether the high byte is zero. Shifting a bit at a time is slow, so shift tables are used instead. This requires a left shift on the high byte and a right shift on the low byte followed by a blend:
  norm_value = SHL(hi, shift) + SHR(lo, 8-shift).
It is also possible to do this with one set of rotate left tables, rather than both left shift and right shift tables:
  norm_value = (ROL(hi,shift) AND mask) OR (ROL(lo,shift) AND NOT mask)
Rotates are distributive with bitwise operations, however, and the blend can be rewritten to be two-arg friendly:
  norm_value = ROL(hi XOR ((hi XOR lo) AND rotated_mask), shift)
This is then used as the argument for the log table lookup. Except... there's no need to have 8 rotate tables and one log table when we could just have 8 rotated log tables, giving the final algorithm for the low byte:
  log2_lo = rol_log_tab[shift][hi XOR ((hi XOR lo) AND rotated_mask)]
The high byte of the log2 result is just computed from the amount of normalization shift required. An additional simplification is possible there, however. Since we are only going to use the difference between two logarithms, the log values can be biased by any amount and the result will be the same. We choose the high address byte of the rotate/log table as the log high byte, saving an instruction to look up the table address.
The log2() core routine is therefore:
;input is in A:TEMP
;compute normalization shift
tay
ldx  aligntab,y
;check if more than an 8 bit shift is required
beq  ilog_small
stx  rotptr
;merge low and high bytes
eor  temp
and  shr2tab-[>logtab8],x
eor  temp
;rotate it and look up log approximation
tay
lda  $0100,y
rotptr = *-1
;result is in X:A
28 cycles for common case. Small arguments (<$0100) take a side branch not shown here that looks up using the low byte only and biases the high log byte by -8. This happens for about 10% of the cases. Zero is special cased off the small argument path by returning a large negative number (biased).
The exp2() + ptab[] side is simpler: do a 16-bit subtraction of the log2 values, look up a table with the high byte, and look up in that table with the low byte. One table for the high byte lookup, 7 tables for regular low byte lookups, one underflow table, and one overflow table. Even here a simplification is possible, though: pre-negate the log2(x) value and use it to bias the table lookups for the log2(y) and log2(z) values. This requires extending the table by two additional pages and treating it as one long 2.8K table. The result (partially merged with the log2):
eor  temp
eor  temp
tay
;bias by -log2(x) high byte and look up table
lda  logbiastab,x		;!! - LSB modified by X-divisor ilog code
logh_bias = *-2
sta  rotptr
;look up log2(y) low byte
ldx  $0100,y
rotptr0 = *-1
;add -log2(x) low byte, do exp2() lookup and apply FOV (PTAB) scale
lda  $0100,x
logl_bias = *-2
rotptr = *-1
log2() + exp2() combined is 40-42 cycles. log2(x) negation and self-modification takes 18 cycles. Thus, doing the y/x and z/x divides and the FOV/PTAB lookup takes about 140 cycles, using around 5K of tables.
I've experimented with doing a direct lookup for computing log2() and it isn't much faster, due to the 6502's weakness in doing table lookups with 16-bit indices. The good news is that a full 16-bit table isn't required, since the high byte can be computed the same way as shown here, given careful rounding on the table. For values in the range $0000-0FFF this requires 4.25K of tables.
#184 ClausB OFFLINE
ClausB
  • 1,432 posts
Posted Tue Nov 3, 2015 5:17 AM
Nicely done! (Aside from the hideous underscores and lower case mnemonics)
#185 JamesD OFFLINE
JamesD
  • 7,959 posts
Posted Thu Nov 5, 2015 7:13 PM
I don't see that as hideous.
I normally use lowercase.
A few older assemblers I used didn't like underscores and I haven't used them since but I wouldn't call them hideous.
#186 Savetz OFFLINE
Savetz
    Dragonstomper
  • 888 posts
Posted Mon Nov 30, 2015 11:00 AM
The team that converted the scanned Star Raiders source to text on github is done. Now, who can get it to compile?
https://github.com/XioNYC/StarRaiders
#187 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 730 posts
Posted Mon Nov 30, 2015 11:11 AM
Hi Kevin!
Will forward that to 2 Jedis here. Thank you so much.
Maybe we will have others jobs of that impact in the near future... ;-)
So, the multiplayer Star Raiders with up to 8 users and one Atari-Server is right around the corner? ;-)
#188 Bryan OFFLINE
Bryan
  • 10,782 posts
  • Cruise Elroy = 4DB7
Posted Mon Nov 30, 2015 11:15 AM
I imagine it depends on what era you learned assembly in. I also find mnemonics easier to read in lower-case.
I wonder if anyone has tried to make an assembly that uses icons to show functions rather than mnemonics...
#189 JamesD OFFLINE
JamesD
  • 7,959 posts
Posted Mon Nov 30, 2015 1:57 PM
And that will be different than the code that has already been posted?
#190 Keatah OFFLINE
Keatah
  • 19,217 posts
Posted Mon Nov 30, 2015 6:49 PM
Symbol table is missing. It's just a few pages so I don't see why it was left out. Give it to me and I'll type it in.
#191 1050 OFFLINE
1050
    Dragonstomper
  • 862 posts
Posted Fri Dec 4, 2015 10:43 PM
The team that converted the scanned Star Raiders source to text on github is done. Now, who can get it to compile?[/size]
Attached File  STAR.zip   123.6KB   147 downloads
#192 1050 OFFLINE
1050
    Dragonstomper
  • 862 posts
Posted Sun Dec 6, 2015 2:14 PM
More errata after second go around:
pg 010 one extra tab on most lines
pg 021 extra tab on line 33
pg 028 LDA for LDY on line 33
pg 036 HTARGT for HTRGT on line 58 instead of 56 in 1st errata
pg 060 address correction on line 10 to be B138
pg 060 missing line inserted to be line 11:
B13A 30 25 BMI CRATE3
To save time and effort for those in the project here is a zip of the corrected pages - these are only the ones that need correction and I believe I did it right but only when the git hub team says it's good is it good. One issue with these text files is that they are not exactly ascii as I understand it to be, they do not use #0d,#0a pair for end of line, carriage return as most ascii to atascii translators might be expecting - they use only #0a. How metapad doesn't stomp all over that I can't fathom except that I don't know enough about it. Not that I want to either. These text files also follow a rigid outline concerning tab use, I think I gathered it correctly but the team needs to weigh in on this issue. Hopefully someone fluent in GitHub can inform them where to find the corrected pages? I thought I was doing pretty good over there just to leave the errata sheet so I left before I could ruin that much. TIA for any assistance.
Attached File  Fixed Pages.zip   33.93KB   109 downloads
#193 fujidude OFFLINE
fujidude
  • 4,828 posts
Posted Sun Dec 6, 2015 3:12 PM
The single 0x0A for EOL is the 'nix (Unix, Linux, BSD, OS-X) way of doing it.  DOS/Win uses a 0x0D 0x0A combo for EOL.  The good news is that my program AAC (ASCII ATASCII Converter) can handle either style of EOL encoding to and from ATASCII.  AAC is a command line driven program.  There is a native version for the Atari8 (written in Action), and a Windows and 'nix version as well (written in Python).
Oh and PS: Anyone interested in command line driven text file converters that convert between different ASCII types, search for the DOS2UNIX/UNIX2DOS and family of utilities.  AAC only handles conversion between ATASCII and the DOS/Win and Unix style ASCII text files, so these other utilities are good for non ATASCII files.
Edited by fujidude, Sun Dec 6, 2015 3:19 PM.
#194 1050 OFFLINE
1050
    Dragonstomper
  • 862 posts
Posted Thu Dec 10, 2015 1:10 AM
Thanks fujidude, I was expecting the lesson to be painful, along the lines of a root canal which is why I alluded that I might be better off not knowing, but that one didn't hurt all and makes perfect sense all over. Nice to know the 'nix crowd has unity like that.
I don't mean to beat this to death, but there are few more errors to report on. First my own, I neglected to include page 007 in the fixed pages zip and it's such a small fix I'll only report that it's missing. And then they will need further work too as below.
The other two errors stem from the rigid tab rule on these files. Each line that is not a blank line must start with 13 character slots followed by one tab and that gets you to the column that would be column one when converted to source code. I'll call it 13+Tab error and pages 021 and 101 both have it on lines 33 and 9 respectively. These errors might be complexed within previous errata reports from me as a further complication but there it is.
First time around I didn't understand why there were errors with page 021 and 101 but I was able to fix it within Mac/65 source code, same for second time around, but the third time was just too much so I dived in to find the why of it exactly. Turns out it wasn't as complicated as rocket surgery after all, but with all the other stuff going on in previous attempts, I couldn't make heads or tails of it so the errors and any hope for fix got lost in the shuffle.
When you get this far then all the other errors that Mac/65 report on are the forward reference and really old school syntax issues. And these have nothing to do the source code project itself. And to that end here is a 'nix ascii version of the scanned pdf with all corrections applied and verified to compile to the byte when further adjusted for Mac/65 foibles and the mystery 07 byte at BFFB.
Attached File  combo.zip   45.86KB   81 downloads
Jeeze - as individual pages too
Attached File  1_thru_112.zip   68.76KB   72 downloads
Edited by 1050, Thu Dec 10, 2015 1:22 AM.
#195 fujidude OFFLINE
fujidude
  • 4,828 posts
Posted Thu Dec 10, 2015 3:03 PM
No prob.  Also, it's not just the 'nix crowd that has them.  Those programs are also built for Windows.  See this page.
#196 thedoctor OFFLINE
thedoctor
    Combat Commando
  • 3 posts
Posted Sat Jan 9, 2016 12:46 PM
More optimizations... slightly faster divide, slightly faster rotation (EORing another value into RANDOM is pointless), faster motion routine, faster star brightness routine.
I also extended the VCONL/VCONH tables to full pages to fix the intermittent crash. The problem occurs because the explosion routine presets HPOS/VPOS for the new explosion particles, which results in a weird grid pattern for the first frame. STVPOS is bypassed when VPOS is set, so the vertical positions are not clipped and can wrap. The out of bounds VPOS values are now clamped.
The game can now hold 30 fps during an explosion, but it'll be hard to get it to 60 fps locked. The divide can possibly be sped up a bit more by adding direct tables for the very common $0000-0FFF range, and it looks like the star store/clear routines could be sped up by adding LMS lines to the display list so no mode line crosses a page boundary. The rotation routines, however, are going to be hard to speed up more as there's only so fast that four shear matrices can be applied to 47 points every tick. Hyperwarp is just barely short of 60 fps because of the extra overhead of all of the new stars that it generates, but arguably that is already running too fast as it is.
One other thing that's apparent is that the constant use of RANDOM everywhere would complicate hoisting Star Raiders into Veronica. A possible approach would be to have the 6502 generate a new page of random numbers every frame, since it's wouldn't have much else to do.
Uh, mind being a little bit more specific? I don't see anything wrong myself, although on higher difficulties it can be hard to stay on target and avoid miswarping.
Hi,
I am sort of new to this whole thing.  I love Star Raiders and played the heck out of it in the 80's and 90's.  I am really interested in this version with the faster explosions.  But, I do not know how to make a version that will run in Altirra.  Can anyone help me out?
Thank you so very much!
#197 phaeron OFFLINE
phaeron
  • 2,342 posts
Posted Sat Jan 9, 2016 6:05 PM
Just make sure BASIC is disabled and then boot the .obx file.
#198 thedoctor OFFLINE
thedoctor
    Combat Commando
  • 3 posts
Posted Sat Jan 9, 2016 7:54 PM
Wow, thanks!  That was easy!  And wow, the game plays so much better!  Thank you to phaeron!
#199 thedoctor OFFLINE
thedoctor
    Combat Commando
  • 3 posts
Posted Mon Jan 11, 2016 1:02 PM
Hyperspace does seem a bit more sensitive to me.  Or is it just me?  You have to be more precise to get in the intended sector.
#200 kiwilove OFFLINE
kiwilove
    Dragonstomper
  • 742 posts
Posted Mon Jan 11, 2016 1:39 PM
Hi,
I would like a Star Raiders in which the shield on - is the standard black background working in place - Green could be the text window, instead of blue? to indicate shields are on.
I do love the feeling of travelling through deep space and would let the game run in this mode, in a darkened room. I am not at the Commander skill level to be able to play the game with no shields.
Would love the other enhancements too - faster explosions, etc?
Harvey
