JankenTheGreat Posted April 14, 2003 Share Posted April 14, 2003 I guess this could have gone into off-topic, but here it is anyway... While I as at a friends house, my baby brother discovered my Atari 800XL...... This means NOT GOOD! DALTON + ATARI 800XL = NOT GOOD! He spilled milk in the keyboard, now its all sticky and won't work. Can I clean it just, any way? I know it was my brother, but it really makes me look like a slob. Link to comment Share on other sites More sharing options...
A2600 Posted April 15, 2003 Share Posted April 15, 2003 I head once that these could be dish washed!! just given the fact of a 2-3 day drying period!!! Im not so sure but I heard it form a guy he said it in his site and he did it with his 65XE!! So you could try!! also get a sponge with some soap and rub the keyboard down! Link to comment Share on other sites More sharing options...
Gunstar Posted April 15, 2003 Share Posted April 15, 2003 your going to have to open up the computer and remove the keyboard, then, you'll have to take out all the screws on the back of it to access the inside, the keys will come off easy in this state too, they should pop off. then, either use something like windex or rubbing alcohol and some paper towels to carefully clean it all up, then re-assemble it all. lots of small pieces though, so have a bowl or something ready to store them in, and you may want to make sure you remember where everything goes, by sketching or writing it down, or something (I'm assuming you've never done anything like this before-disassembling a keyboard). It sould work fine after that. Link to comment Share on other sites More sharing options...
JankenTheGreat Posted April 15, 2003 Author Share Posted April 15, 2003 your going to have to open up the computer and remove the keyboard, then, you'll have to take out all the screws on the back of it to access the inside, the keys will come off easy in this state too, they should pop off. then, either use something like windex or rubbing alcohol and some paper towels to carefully clean it all up, then re-assemble it all. lots of small pieces though, so have a bowl or something ready to store them in, and you may want to make sure you remember where everything goes, by sketching or writing it down, or something (I'm assuming you've never done anything like this before-disassembling a keyboard). It sould work fine after that. I doubt my 800XL would work after me doing that. Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 15, 2003 Share Posted April 15, 2003 You can always just lift off all of the keys (the space bar is a bit tricky though). Use a butter knife to gently pry up a key. Once they are all off, you can just dump them in a bowl of soapy water, and wipe down the inside of the keyboard itself. Then you just snap them all back down. Works OK on my Atari800...dunno if the XL/XE keyboards differ too much to do this. Link to comment Share on other sites More sharing options...
Gunstar Posted April 15, 2003 Share Posted April 15, 2003 You can always just lift off all of the keys (the space bar is a bit tricky though). Use a butter knife to gently pry up a key. Once they are all off, you can just dump them in a bowl of soapy water, and wipe down the inside of the keyboard itself. Then you just snap them all back down. Works OK on my Atari800...dunno if the XL/XE keyboards differ too much to do this. that will work as long as none of the milk go down INSIDE the key shafts AND onto the membrane underneath...otherwise, he'll have to go the whole 9 yards! Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 16, 2003 Share Posted April 16, 2003 How are the keyboards designed on the XL's? The top area of mine is completely sealed (besides the raised holes for the keys...which are covered by the keycaps). No chance of any fluids getting in there, it would run off onto the motherboard underneath (which could be wiped down with alcohol). Link to comment Share on other sites More sharing options...
sashswash Posted May 1, 2003 Share Posted May 1, 2003 I recently took apart my 800xl's keyboard to clean it. It was really easy. It consists of the keys with a bunch of little springs inside them (be careful not to lose these), and the membrane with the contacts. They keys snap right off, and back on for easy cleaning. The whole job took probably about an hour and a half. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
