Cjug Posted November 13, 2015 Share Posted November 13, 2015 (edited) I tried the following video connection: Atari 1040STFM->Retrogamingcables ST SCART cable->XRGB-2 plus->CRT VGA monitor The image I got was fine but with vertical lines accross it (photo below). Anyone had this problem? Any ideas to have it solved? Edited November 13, 2015 by Cjug Quote Link to comment Share on other sites More sharing options...
Christos Posted November 13, 2015 Share Posted November 13, 2015 Assuming the ST is working ok with the SCART connection to a crt tv, it's probably the non standard video output of the ST that's causing the issue. Searching this forum for R431 resistor will yield a result that might help you. I haven't tried it personally but the user who posted has. Quote Link to comment Share on other sites More sharing options...
exxosuk Posted November 13, 2015 Share Posted November 13, 2015 Normally bad ram which causes odd problems like that. Quote Link to comment Share on other sites More sharing options...
Cjug Posted November 15, 2015 Author Share Posted November 15, 2015 (edited) Assuming the ST is working ok with the SCART connection to a crt tv, it's probably the non standard video output of the ST that's causing the issue. No, I found out that the problem is with the computer, because I tested it with a SC1224 monitor and it showed the same bars. Normally bad ram which causes odd problems like that. It might be what you say. Edited November 15, 2015 by Cjug Quote Link to comment Share on other sites More sharing options...
420kb Posted December 2, 2015 Share Posted December 2, 2015 (edited) Assuming the ST is working ok with the SCART connection to a crt tv, it's probably the non standard video output of the ST that's causing the issue. Searching this forum for R431 resistor will yield a result that might help you. I haven't tried it personally but the user who posted has. Just in case anyone finds this thread thru google or whatever, i have a XRGB 2+, my SCART connection is fine on it. it has to be a problem with OP's computer. Edited December 2, 2015 by 420kb Quote Link to comment Share on other sites More sharing options...
