New video upgrade coming soon!
video upgrade clearpic supervideo UAV
811 replies to this topic
#726 Bryan OFFLINE
Bryan
  • 10,927 posts
  • Cruise Elroy = 4DB7
Posted Wed Oct 12, 2016 2:19 PM
The resistors help reduce the influence of high frequency noise (the logic input capacitance causes a natural roll off, so you just pick a value that allows you to drive at the required speed - and you're right, it would prevent any overshoot effects). The extra benefit is that although HC can handle inputs about a half-volt outside the rails, it does have protection diodes. The resistors assure there won't be much current drawn if the main supply is 5.1V or so. The reason I run much of the circuit at 4.5V is that I needed to re-regulate the 5V down to another voltage for a clean local supply, and CMOS stuff works just fine over a wide range.
I think I know how I'm going to proceed with a new Rev D prototype. Ever notice you frequently can't find that one perfect logic chip that does exactly what you want?
#727 mytek ONLINE
mytek
  • 3,409 posts
Posted Wed Oct 12, 2016 11:31 PM
Yep tell me about it  :(  That is why you may have noticed me resorting to diode-resistor logic in some of my designs. But I guess that's what PAL's or GAL's were made for, although that gives you yet one more device that needs to be programmed (unfortunately).
- Michael
#728 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Sat Oct 15, 2016 8:51 AM
I've got a new Rev D design. The trick is now to get my new proto boards in Costa Rica. This country is not set up for shipping convenience and the government has cracked down on the independent shippers who were skirting the system (right now there's about $1000 of stuff I sent that I'll probably never see).
#729 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 714 posts
Posted Thu Oct 27, 2016 9:05 AM
Any luck Bryan? We here in S.Ontario canada will need about 10.. so when that thread gets started.. ;)
James
#730 mytek ONLINE
mytek
  • 3,409 posts
Posted Fri Oct 28, 2016 8:00 PM
James
I'm also hoping that the new version is ready pretty soon. I would like to verify its compatibility with the V-gate project I am working on. Presently his first released version is doing fine, so unless something has drastically changed I would think the new version would also be OK, but better to find out in case I can make a change to accommodate the difference. So yes, I too will want to buy a couple of these when they are released.
- Michael
#731 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Sat Oct 29, 2016 4:30 AM
Right now here's my schedule: I'm packing my things for a shipment back to the US and I'll be dealing with receiving that in early December. While in the US I plan to build a few new Rev D prototypes. If everything's okay then I'll get pricing for semi-assembled boards and start pre-orders again which will ship when I move back for good in Mar/Apr unless I make an earlier trip back for some reason. This means I'll do another direct sale and won't begin supplying to the AA store until after I've completed my move and have a shop set up again.
#732 mytek ONLINE
mytek
  • 3,409 posts
Posted Sat Nov 12, 2016 8:30 PM
Here's an accessory that can make life easier for those that want to hook their UAV output into a newer TV or Up-Converter that supports the standard S-Video Mini-Din connector.
DSC_0257_684ab003-a21d-46c0-ba2f-f8ab0da
mDIN4-F-BO-V1A, Mini Din 4 Female connector S-video Breakout Board
I have two on order  :)
- Michael
#733 mytek ONLINE
mytek
  • 3,409 posts
Posted Thu Nov 24, 2016 3:31 PM
Here's a pic of the S-Video Mini Din 4 breakout board (link) installed on an XEGS and connected to the UAV via two shielded cables (one for Luma and the other for Chroma).
Header Connections
  1. Luma Shield (GND on UAV)
  2. Chroma Shield (GND on UAV)
  3. To UAV: Luma Out
  4. To UAV: Chroma Out
  5. Chassis GND (green wire soldered to RF shield motherboard grounding trace)
Works great!
- Michael
EDIT: I mounted it with two 4-40 screws, nuts, and four #4 nylon washers (one set as spacers between the boards, and the other as an insulator on the top side of the breakout board).
Edited by mytekcontrols, Thu Nov 24, 2016 3:35 PM.
#734 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Thu Nov 24, 2016 4:38 PM
Quick update, I've ordered the new protos and I'll be picking them up when I go back to the States in a week.
Edited by Bryan, Thu Nov 24, 2016 4:39 PM.
#735 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 714 posts
Posted Sun Nov 27, 2016 12:33 AM
Hey Bryan, I did your older simple video mod on a Hong Kong socketed 800xl and the results were not great. On the other hand I have done this on other 800xl machines and better results.
Can I send you screen pics and maybe you can give me an idea how to improve it?
I am doing this because I am waiting for your UAV.. and could not wait anymore.. lol
#736 slx OFFLINE
slx
  • 1,863 posts
Posted Sun Nov 27, 2016 4:24 PM
I have the physical PCB boards and they are tiny, It will take three wires soldered from the motherboard and one wire for audio out. With the size of the board I determined it would be better to avoid a header so all wires will be soldered direct. The hardest part will be locating it and insulating it from the motherboard.
Things got busy here recently and I am working to get some time to finish this up.
(I'll put a picture up of the PCB later so you can see how small it is)
Any news on the audio boards for the 400? Would greatly appreciate to be able to get them to get two 400s converted.
#737 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Fri Dec 2, 2016 9:01 AM
New boards are here!!
When I get back to Costa Rica I'll get them built and tested and hopefully we'll be rolling soon!
I'm pretty busy for the next couple weeks, but I'll try to help. Are the pictures posted in the other video upgrade thread?
-Bry
#738 Smokeless Joe OFFLINE
Smokeless Joe
    Moonsweeper
  • 289 posts
Posted Fri Dec 2, 2016 12:45 PM
I got my 400 audio board from orpheuswaking and it works nicely. I think he had a bunch, so it might be worth it to message him.
#739 slx OFFLINE
slx
  • 1,863 posts
Posted Fri Dec 2, 2016 1:44 PM
Thanks. I thought he initially offered them at a show only. I have PM'ed him.
#740 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 714 posts
Posted Fri Dec 2, 2016 2:10 PM
Ahhhh well if you have boards, then I will live with the output for now! .. getting close!! :)
James
#741 Sugarland OFFLINE
Sugarland
    Moonsweeper
  • 260 posts
Posted Fri Dec 9, 2016 12:38 AM
Hi! I'm interested in at least one, please. Depending on supply and availability I will probably want more than one (three max). Thank you for making these!
#742 mytek ONLINE
mytek
  • 3,409 posts
Posted Fri Dec 9, 2016 8:33 AM
When these get into the AtariAge Store I'll definitely be buying at least 4 of them.
- Michael
#743 Sandor / HARD OFFLINE
Sandor / HARD
    Star Raider
  • 52 posts
Posted Fri Dec 16, 2016 9:57 AM
Hello,
This looks like a very nice piece of upgrade that preserves the retro feel of the picture.
I got myself a 130 XE (PAL) recently. (only interested in 64K of it though ;) )
Is it possible for me to get this mod for it?
I'd really appreciate a PM with the details.
Thank you.
#744 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Sun Dec 18, 2016 9:25 AM
My subscription had lapsed so I was unable to receive PM's for a bit.
I'm assembling some new boards and I'll be working on getting a price for partial assembly (now that one side has 0603 stuff on it, it's near the limit of what I can do by hand). Anyway, this might make the price a little higher but hopefully in the same ballpark.
If everything looks good, I'll start a Rev D thread and take orders again.
-Bry
#745 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Tue Dec 20, 2016 10:09 AM
I'm almost done testing the new boards. After I found a couple mistakes and fixed a cracked board in my test monitor (it got manhandled on its way to Costa Rica.. see pic for the rather time consuming repair!) things started looking very nice. I'm just tweaking a few component values at this point.
#746 JoSch OFFLINE
JoSch
    Dragonstomper
  • 539 posts
Posted Tue Dec 20, 2016 11:22 AM
.. fixed a cracked board in my test monitor (it got manhandled on its way to Costa Rica.. see pic for the rather time consuming repair!) ..
:-o
Edited by JoSch, Tue Dec 20, 2016 11:22 AM.
#747 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Tue Dec 20, 2016 11:53 AM
Yeah, I hate Phenolic PCB's as they're very brittle- especially when they're supporting something heavy like a flyback transformer. Both edges of the board had cracks but the break through all those little traces was especially painful.
#748 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Tue Dec 20, 2016 11:58 AM
Oh man that hurts just looking at it...
#749 mytek ONLINE
mytek
  • 3,409 posts
Posted Tue Dec 20, 2016 3:16 PM
I tried to do the same thing on a broken up Sony PAL/NTSC/RGB studio monitor, but unfortunately didn't succeed at getting it to work. Congrats on your success and diligence  :)
- Michael
#750 MrFish OFFLINE
MrFish
  • 5,474 posts
Posted Tue Dec 20, 2016 3:29 PM
Reminds me of a repair I did, a little less than two years ago, on a moisture-stricken dishwasher PCB. Close to the same amount of trace connections, and a series of connections on several ribbon cables. The repair was a success; no pictures, though, as it's on my sister's dishwasher.
Edited by MrFish, Tue Dec 20, 2016 3:29 PM.
Also tagged with one or more of these keywords: video, upgrade, clearpic, supervideo, UAV
