Is there a name for a 60th of a second (an NTSC/PAL60 cycle)?
Best "60th of a Second" Synonym
20 members have voted
  1. 1. What is your favorite word or phrase that means 60th of a second?
    • Third.
      0
    • Sexagintisecond.
      0
    • Hexacontasecond.
      0
    • Cycle.
    • Frame.
      13
    • Jiffy.
    • Tick.
      0
    • 60th of a second.
      0
    • Sixtieth of a second.
      0
    • 1/60 second.
    • 60 FPS divided by 60.
      0
    • I don't care.
      0
    • Other. (I'll post my favorite.)
      0
  • Please sign in to vote in this poll.
Me too.
I've had a lot of fun programming video displays over the last 10 years. (Micro controller based things) The analog world has a lot of advantages over the digital one when it comes to little systems and making signals. It just takes less, and the results can be excellent.
As I look into digital things, like HDMI, there is some equally good engineering. It just seems harder to grok and a lot harder to program and tinker with... sigh.
Here's a better picture of how the interlacing is meant to work in NTSC
(from this page)
If the scan returns to the top at the same place horizontaly (instead of being displaced by half as in that picture) you would presumably
scan the even and odd fields in exactly the same place horizontaly
In the olden days that wasn't possible be cause the half line displacement was built into the TV it's self and it could take seconds
or minutes (or never) for the television to sync with the signal
Edited by bogax
  • 3 weeks later...
How can you call it a frame when a frame does not have to do anything with a 1/60 of a second... you can have a game running at 15 fps...
When a game is said to run at 15 fps, it means that it can it can do calculations to render 15 new frame of graphics per seconds, but the video signal must still be at 60Hz (or 30Hz interlaced or any other standard signal accepted by the TV or PC monitor in use). Some frame in the video output will be duplicated to reach the required framerate. This is achieved either by hardware (the video chip will just output the same image until it's updated by the cpu) or by software (as in the case of the 2600, when the programmer must ensure that the video timing is correct). I think that the only 2600 game that can have occasional framerate drop is Boulder Dash, which takes more time to calculate a new frame when there are many objects on screen. But it stills outputs a steady 60Hz signal, or the TV would lose sync...
