CF7+ power supply
110 replies to this topic
#76 Schmitzi OFFLINE
Schmitzi
  • 4,330 posts
  • ToXiC
Posted Wed Feb 10, 2016 4:36 PM
It normally uses 5 Volts (on inside)
#77 FarmerPotato OFFLINE
FarmerPotato
    Star Raider
  • 85 posts
Posted Wed Mar 16, 2016 4:01 PM
I have two non-functioning CF7+. About five years ago, I sent one off to Jamie for repair and I think he replaced the FPGA. It seems he has closed up his business now, but I emailed him anyway.
I suspect static shock (I only ever used the correct power supplies, and the first time one fried, I actually saw the spark.)
So where do I go next for solid state storage?
One crazy idea that occured to me today:
Remove the Xilinx FPGA
Reverse engineer the hardware that's left
Wire up that to one of my Xilinx developer boards and begin re-inventing the system.  Crazy, yeah.  And I don't need another project.
#78 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 12,325 posts
Posted Wed Mar 16, 2016 4:20 PM
You may not need another project, but if you do this, you'll probably make some people VERY happy.  I'm also sure whatever you decide, you would not go cheap on a few extra components and eliminate basic voltage protections on the board.  From what I've been able to discern, this was a problem that  plagued numerous units causing many headaches for people.
#79 Ksarul OFFLINE
Ksarul
  • 4,679 posts
Posted Wed Mar 16, 2016 6:19 PM
And if you build it on a Speech Synthesizer-sized board, it will fit into a really nice case too, especially if that case is surplus because the original board has been moved to a PEB. . .recycling at its best.  :)
#80 FarmerPotato OFFLINE
FarmerPotato
    Star Raider
  • 85 posts
Posted Wed Apr 6, 2016 12:37 PM
My first hardware hacking platform!
Nobody told me the Speech Synthesizer was not a proto board.
#81 sparkdrummer ONLINE
sparkdrummer
    Dragonstomper
  • 918 posts
  • Status? I don't need no stinkin' status!
Posted Thu Jul 13, 2017 11:03 AM
Ciro,
Yes, I tested with a digital vom and got 5.1 volts at the +5 shown in the image.
See the attached where I tapped in on another speech synth. I didn't want to take the modified one apart because I'm still testing it.
#82 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 12:26 PM
Necro time:
DavidC, did you ever prove the battery pack supply?
#83 OLD CS1 OFFLINE
OLD CS1
  • 5,326 posts
  • Technology Samurai
Posted Wed Mar 21, 2018 1:38 PM
I am using a USB power pack on my nanoPEB and CF7+.  Some USB power supplies ("chargers") are noisy and will introduce that noise into the cassette audio output.  My guess is probably referenced to line voltage.
tl;dr Is that what you were asking about?
#84 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 1:42 PM
I dont have a proper power supply for my CF7+ (v1old-school) and I stumbled across this thread.
I was just curious for the sake of completion whether the OP was able to prove out the AA battery pack idea (to power his CF7+)
#85 OLD CS1 OFFLINE
OLD CS1
  • 5,326 posts
Posted Wed Mar 21, 2018 1:57 PM
Oh, using real batteries.  You cannot get 5V from AAs, only 4.5V or 6V (or 4.8V and 6V if you use rechargeable AAs.)  I measured the power draw of my nanoPEB to be ~40mA under use from XB (32k in use) or idle, and 100mA when accessing the CF.  I suspect a good set of NiMH should run the unit for quite a while if the unit is happy with 4.8V.
#86 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 2:20 PM
I have a 5v 500 mA adapter with the proper barrel. From what Ive read here though, 500 mA wont cut the mustard
#87 OLD CS1 OFFLINE
OLD CS1
  • 5,326 posts
Posted Wed Mar 21, 2018 2:40 PM
Which I do not understand.  It only draws 100mA from my USB.
#88 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 2:43 PM
I have one of the old CF7s. Perhaps the requirements are different?
Either way, I can plug it in and the LEDs come on... that doesnt necessarily mean it has functional power though. Last thing I want to do is harm this CF7. There are not many like it out there, as it was one of the first ones off the *assembly line*. :D
It is very sturdy, robust, and has a voltage regulator. Plus Ive had it since 2008, so its basically *vintage* now. :)
Edited by Opry99er, Wed Mar 21, 2018 2:46 PM.
#89 OLD CS1 OFFLINE
OLD CS1
  • 5,326 posts
Posted Wed Mar 21, 2018 2:47 PM
I will check my CF7+ tonight for power draw (I have one of the old ones like you.)  I powered it at VCF last year on a USB power supply.
#90 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 3:01 PM
That would be most helpful... thank you!!
#91 Schmitzi OFFLINE
Schmitzi
  • 4,330 posts
  • ToXiC
Posted Wed Mar 21, 2018 3:07 PM
I think 500 mA is a bit weak. I only use 1500mA and more. The more, the better.
(Ampere, NOT ! the voltage)
PS And I slightly remember somebody speaking of 7 Volt on an older model,
but I would NOT try this. If wrong, you will definitely brick it.
#92 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 7:07 PM
So... related, but unrelated....
What is the largest size SanDisk CF card you can use on the CF7+?
I only ask because the larger cards are somehow less expensive than the smaller ones. (I get it, availability)....
I can get a 16 Gig for $8, and the 2 Gig are $15. I need to buy two, so Id rather spend $16 than $30.
#93 Torrax OFFLINE
Torrax
    Chopper Commander
  • 111 posts
Posted Wed Mar 21, 2018 7:51 PM
I have one of the older CF7+ versions that use 7V.  Using 5V on these versions make them very flaky & finiky.
#94 OLD CS1 OFFLINE
OLD CS1
  • 5,326 posts
My CF7+ pulls around 10mA~20mA, up to 50mA when running the CF card.  Interesting is it pulls 100mA when the console is switched off.
Another interesting discovery: the "QI" console does not care if the nanoPEB/CF7+ is powered or not.  Neither of my units are modified to draw power from the console.  When connected to a standard console, the console will hang on power-up if the device is not powered.  With the "QI" console the device just becomes unavailable.
#95 arcadeshopper OFFLINE
arcadeshopper
  • 3,408 posts
Posted Wed Mar 21, 2018 8:13 PM
ITS NOT THE SIZE THAT COUNTS .. er.. its the method of writing data..  4gb is the largest I've tried which is about 3gig more than you'd ever use
I have cheap 2gig ones on my site now.
Greg
#96 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 11:47 PM
So, I don't currently have a CF card...  I plugged the CF7 into my machine, expecting to see the title with the CF7+ bit, and it was just a blue screen with no title screen.
I guessed it was just under-powered.  The power lights illuminate on the board, but it didn't seem to have enough juice to push the system.  So I took the power supply from my US Robotics modem (a universal PowerLine with a voltage selector switch) and tried 5v.  Nothing.  I tried 6v.  Nothing again.  I tried 7.5v.  Nothing again.
So, I either have a faulty CF7+ (something I've believed for quite a while) or the CF7 requires a CF card to be installed on the board for it to get me to the title screen.
Can anyone confirm that a missing CF card gets you to a blue screen?  I was sure that the CF7+ firmware was in ROM, and not something you loaded onto the card itself.  If that's the case, I will likely start a new thread to help me trouble shoot the device.
Thanks in advance
#97 Opry99er OFFLINE
Opry99er
  • 9,789 posts
Posted Wed Mar 21, 2018 11:55 PM
This is my device.
#98 Schmitzi OFFLINE
Schmitzi
  • 4,330 posts
  • ToXiC
Posted Thu Mar 22, 2018 3:13 AM
Hi, can you post some detailed pics of your device?
#99 Schmitzi OFFLINE
Schmitzi
  • 4,330 posts
  • ToXiC
Posted Thu Mar 22, 2018 3:21 AM
hmm, so do I miss an SRAM chip on my card ? see the empty socket on the left...
Attached File  CF7plus-01-RMS-IMG_5229-CUT.jpg   81.6KB   1 downloads Attached File  CF7plus-Opry99er-01.jpg   29.45KB   1 downloads
#100 RickyDean OFFLINE
RickyDean
    Dragonstomper
  • 872 posts
Posted Thu Mar 22, 2018 5:56 AM
attachicon.gifCF7plus-01-RMS-IMG_5229-CUT.jpg attachicon.gifCF7plus-Opry99er-01.jpg
Yes Schmitzi, that is for a 32k memory chip, thereby giving you the ability to have a small PEB. I have one of these, but blew the CPLD chip with the wrong PS, (mine didn't have the reg). Got with Jamie and ordered a new CLPD and my 32k hasn't worked since(believe he gave me a different burn, my 32k is socketed and has been changed with a known good one).
Edited by RickyDean, Thu Mar 22, 2018 5:57 AM.
