marlowe221 Posted January 22, 2016 Share Posted January 22, 2016 (edited) Sorry! Edited January 22, 2016 by marlowe221 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 22, 2016 Share Posted January 22, 2016 The jitter implies dirty POTs that need to be cleaned. If your joysticks work correctly in the left and right directions then the fire button issue is within the paddle controllers - either the button itself or the wiring/connection to the Atari. If you're not able to resolve it look into getting a set of At Game paddles for the Flashback units. They're brand new, so jitter free, and work great with a real Atari. Looks like they're on back order though, might be able to find them elsewhere. Quote Link to comment Share on other sites More sharing options...
marlowe221 Posted January 22, 2016 Author Share Posted January 22, 2016 The jitter implies dirty POTs that need to be cleaned. If your joysticks work correctly in the left and right directions then the fire button issue is within the paddle controllers - either the button itself or the wiring/connection to the Atari. If you're not able to resolve it look into getting a set of At Game paddles for the Flashback units. They're brand new, so jitter free, and work great with a real Atari. Looks like they're on back order though, might be able to find them elsewhere. Thanks, I will see if I can give them a good cleaning. Any idea why the controller seemed to work better the more I used it? Maybe I was scraping off some grime as I went along? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted January 22, 2016 Share Posted January 22, 2016 Scraping it off implies it went away - it's still in there, you're just moving it around. Due to how the Atari and its paddles work, each game uses a different range of the paddles so it ends up just shifting the grime around from game to game. Quote Link to comment Share on other sites More sharing options...
marlowe221 Posted January 22, 2016 Author Share Posted January 22, 2016 Gotcha. I'll try to make some time to get them cracked open this weekend and follow the guide you posted. Thanks for the advice! Quote Link to comment Share on other sites More sharing options...
