Synapse SynCalc-program & source code now in PD
Synapse SynCalc source code
32 replies to this topic
#26 luckybuck OFFLINE
luckybuck
    Dragonstomper
  • 959 posts
Posted Mon May 2, 2016 4:06 PM
Hi Mike,
SynCalc was the best spreadsheet and had the best protection, too.
Further, I remember my Filemanager 800+ dongle in the 1st joystick port.
Recently, someone in the Netherlands found, that an original Wordprocessor disk from Atari had a 2nd index hole...
So, even 30 years later, they work! :)
#27 MikeSilva OFFLINE
MikeSilva
    Space Invader
  • 30 posts
Posted Mon May 2, 2016 5:16 PM
(well I STILL can't make the "quote" reply feature work in this forum - crazy!!)
Anyway, about the board, I'm sure they're all in landfill somewhere in Marin County, where Broderbund was located.  I don't remember how many they made, maybe 6 to 10?  Anyway, just imagine the PCB of a standard cartridge, but on the top the board grows out to maybe 14" wide and 10" high (35x25 cm).  Lots of 2102 memory chips, enough to hold all the possible transitions in a single track - I just did a really rough calculation now and I come up with maybe 60 2102 memory chips, assuming 18 sectors * 200 total bytes/sector * 8 bits/byte * 2 transitions/bit.
Edited by MikeSilva, Mon May 2, 2016 5:20 PM.
#28 Heaven/TQA ONLINE
Heaven/TQA
  • 11,163 posts
Posted Tue May 3, 2016 12:40 AM
I guess I should try SynCalc on my 800 and show my wife and the "youngsters" here in the office who think that Excel was here forever. :D
#29 ijor OFFLINE
ijor
  • 2,166 posts
Posted Tue May 3, 2016 7:20 AM
That's amazing! Yes, it's around 3250 bytes per unformatted track at nominal speed.
But you used regular Atari drives, didn't you? Just modified to accept the input from this board, I guess.
Also, do you know if you duplicated disks for other companies (besides Broderbund after the acquisition)? I ask because a couple of other publishers had similar characteristics.
#30 MikeSilva OFFLINE
MikeSilva
    Space Invader
  • 30 posts
Posted Tue May 3, 2016 8:43 AM
No, the drives were not Atari, just regular IDE drives, lined up on their sides.  And I'm not aware that they ever duped disks for any other companies.
Mike
#31 ijor OFFLINE
ijor
  • 2,166 posts
Posted Tue May 3, 2016 9:42 AM
I see. So you had to slow down the drives to the nominal Atari drives RPM (288 vs 300). Or you compensated the frequency with the on board clock.
I was going to say that you also ignored the disk index, as Atari drives do, because I can see that the tracks are not aligned. But of course, if you recorded on multiple drives at the same time, then you didn't have much choice!
I assume you implemented a dummy index pulse based on a timer (again, as Atari drives do)? At least for the regular tracks because the WD FDC won't format a track without the pulse.
#32 MikeSilva OFFLINE
MikeSilva
    Space Invader
  • 30 posts
Posted Tue May 3, 2016 11:12 AM
I'm going to disappoint you by tossing the "I don't remember" card now.  For example, I don't even remember if I was aware of the difference in motor speeds between Atari and standard drives (!), but we certainly didn't change the speed of the drives.  And I don't remember anything about handling the index pulses, sorry!  I just remember that it all worked.  :D
#33 ijor OFFLINE
ijor
  • 2,166 posts
Posted Tue May 3, 2016 3:10 PM
That's ok, don't worry. It is understandable, and even expected, of course. Thank you very much!
Also tagged with one or more of these keywords: Synapse, SynCalc, source code
