Drive!
homebrew assembly paddles
96 replies to this topic
#1 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Tue Mar 8, 2016 12:08 PM
[Make sure you download the files attached to this post, as they are the most recent. I only have permission to edit this post.]
Hello, everyone!
I've been developing an Atari 2600 homebrew game for the last little while, and I think it's nearing completion, but I'd like to get more feedback before I call it final. It's a 4K, single player paddle game with SaveKey/AtariVox support.
Plot:
In this game, you are an explorer from the year 2050. Much of the world's rainforests have been logged, leading to the discovery of a large temple constructed by ancient civilizations eons ago. You are among the first to be allowed to explore it.
The entrance to this temple is across a long stone bridge, which you have chosen to drive across. Inside the temple you find a golden idol on a stone pedestal. Although you are supposed to leave everything you find, your greed gets the better of you and you remove the idol from where it has sat for thousands of years.
Suddenly, the ground begins to shake. Bricks fall from the ceiling. Maybe this wasn't such a good idea! You run outside just as the entrance caves in. As you get in your car and drive away, you realize that the bridge's supports have dislodged and it's all collapsing behind you! There's no time to think - just drive!
In this game, you must use the paddle controllers to steer your car left and right, avoiding obstacles in your path while collecting treasures.
When you touch a treasure, you will get 1500 points and it will be added to your collection (the yellow dots on the left side of the status bar). You can have up to 5 treasures in your collection at a time. At any point, you can press the paddle controller's trigger to "burn" a treasure, giving you the energy to jump a short distance over any obstacles in your path. Any treasures you have left when your game ends will grant you an extra 1500 points. The game is won upon reaching 99,999 points.
There are different kinds of treasures. Some of them will grant you unique powers:
coin.png Gold coin: Does not grant any powers, is only worth points.
necklace.png Necklace: Gives you an extra life (the red dots on the right side of the status bar). You can have up to four lives at a time.
jar.png Jar: Lets you pass through all barriers for a few seconds.
statuette.png Statuette: Lets you jump as much as you want with no penalties for a few seconds.
The game will speed up when you get enough points. There will be a transition period where the game stops generating obstacles briefly, and the speed-up will occur while there are no obstacles on the screen.
The difficulty switches toggle certain features. I highly recommend setting both to A for the full experience (Note: Stella sets both to B by default):
- The left difficulty switch will make obstacles farther apart (B) or closer together (A).
- The right difficulty switch turns moving obstacles off (B) or on (A).
If the game feels too easy for you, enable Speed Freak mode! Simply press the game select switch at any point. When the title screen's background is red, this mode is enabled.
Finally, the most important feature: if you press the paddle trigger while you have no treasures in your collection, you can honk the horn! Wow!
As previously mentioned, the SaveKey and AtariVox are fully compatible for saving high scores (although there are no AtariVox speech functions). It saves unique high scores for Normal and Speed Freak modes. If you want to clear your high scores, press the game select and game reset switches at the same time.
So, that's everything you need to know! Feel free to give feedback. However, there is very little free space in the ROM, so I probably won't be able to implement any extensive new features. Sorry about that.
[Please make sure you download the following files]
Attached File  Drive! v1.5.3 NTSC.bin   4KB   257 downloads
Attached File  Drive! v1.5.3 PAL.bin   4KB   145 downloads
Edited by Lumi, Sat Jul 2, 2016 3:54 PM.
#2 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Tue Mar 8, 2016 2:23 PM
An update that fixes a rare bug.
Edited by Lumi, Tue Mar 8, 2016 3:21 PM.
#3 mehguy OFFLINE
mehguy
    Moonsweeper
  • 263 posts
Posted Tue Mar 8, 2016 3:00 PM
Seems very interesting! I will be trying it out very soon!
#4 Jinks OFFLINE
Jinks
  • 4,682 posts
Posted Tue Mar 8, 2016 7:27 PM
Excellent!! Looks interesting!
#5 chavert OFFLINE
chavert
    Moonsweeper
  • 391 posts
Posted Wed Mar 9, 2016 6:21 AM
it works wellno bug. :)
#6 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 299 posts
  • Also known as "Urbinoo"
Posted Thu Mar 10, 2016 2:34 AM
Nice job ! I love the music, did you use your own music routine ?
I noticed a lot of jittering though my paddles were cleaned quite recently. Did someone else noticed that too (PAL60) ?
#7 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Thu Mar 10, 2016 3:30 PM
Thanks, everyone!
Yes, actually! I designed the music routine to play only that one song, so it's easy on RAM and ROM space, but isn't very useful if you want other songs.
Hmm. I don't know why it would be jittering, I hope it doesn't have anything to do with it being PAL60. In any case, here's a standard PAL version that's been speed optimized (except for the sound effects):
Attached File  Drive! v1.3 PAL.bin   4KB   149 downloads
Edited by Lumi, Thu Mar 10, 2016 3:36 PM.
#8 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 299 posts
Posted Sat Mar 12, 2016 2:58 PM
Thanks for this rom ! It doesn't jitter anymore ! Well except for some rare times but they are for sure caused by my paddles. It's now far more playable en enjoyable, great :thumbsup:
I haven't ckecked how many scanlines you're firing, but just to let you know, I'm afraid this is not the right amount for pal 50, as I get artifacts on the top of the screen.
Drive! PAL
Edited by Cambouis de l'Atari, Sat Mar 12, 2016 3:01 PM.
#9 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Sat Mar 12, 2016 3:54 PM
Hmmm.
According to Stella the PAL version is 312 lines, so I have no idea why there would be artifacts.
I'm mainly guessing at this point because I can't test it, but try this. I may have misunderstood how PAL sets interpret the VBLANK signal.
Attached File  Drive! v1.3.1 PAL.bin   4KB   148 downloads
#10 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 299 posts
Posted Sun Mar 13, 2016 5:49 AM
Sorry, the artifact is different, but the top of the screen is still bent to the right, I'll make you a picture later if you want.
I'm sorry I can't help you more right now. Till now I never programmed a PAL 50 rom, only PAL 60 (and never a paddle handling routine).
#11 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 299 posts
Posted Sun Mar 13, 2016 11:17 AM
Hey, me again ;)
I distella'd your rom. I modified the start of frame in a more traditional way : 2 > vsync, 3 wsync then 0 > vsync. To keep the count, I removed 3 following wsync and 0 > vsync, between F061 and F0BD
In your code, vsync is asked at scanline 276 and closed at 312, which is probably in the visible section of the screen.
Your game is now perfect on a PAL console ! :)
Drive! PAL 50 ok
Edited by Cambouis de l'Atari, Sun Mar 13, 2016 11:22 AM.
#12 mrlars OFFLINE
mrlars
    Combat Commando
  • 6 posts
Posted Sun Mar 13, 2016 12:44 PM
Hi,
Really fun game you got there, works perfect on my PAL as well  :)
#13 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Mon Mar 14, 2016 10:17 AM
Hey, me again ;)
Really? Vsync is kept on for that long? That's not how I programmed it! (But I guess mistakes happen when you don't comment your code thoroughly...)
I'll take another look at it to see where it went wrong. Unfortunately my laptop had to go in for repairs, along with the most recent version of the source code, so I can't check it at the moment. But thank you for taking the time to fix my mistake! I'm very happy to know PAL users can play it without jitter or artifacts now :)
By the way, just a question... I'm not saying it will, but if this game were sold as a cartridge in this form, would anyone actually buy it?
Edited by Lumi, Mon Mar 14, 2016 10:46 AM.
  • SSG likes this
#14 sramirez2008 OFFLINE
sramirez2008
  • 2,893 posts
  • Stella Foreva
Posted Mon Mar 14, 2016 9:50 PM
Hello. I added both NTSC versions to my Harmony cart and can't get the game to start. I see the main menu and the music plays (very nice by the way), but I can't start the game. :?
Should it not work on the Harmony?
#15 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Mon Mar 14, 2016 10:08 PM
Hmm, it should definitely work on a Harmony.
Two ideas:
1) Are you using paddle controllers? This game is like Kaboom! or Circus Atari in that it can't be played with a joystick.
2) Are you trying to start the game with the game reset switch? That switch is used to re-boot the game. You have to use the left paddle's fire button to progress past the title screen. It also has to be plugged into the left controller port (you used to be able to plug it into either port, but it caused issues with the AtariVox features).
Edited by Lumi, Mon Mar 14, 2016 10:12 PM.
#16 sramirez2008 OFFLINE
sramirez2008
  • 2,893 posts
  • Stella Foreva
Posted Mon Mar 14, 2016 10:43 PM
My apologies.  :dunce: I had switched to racing controllers earlier and thought I had switched back to paddles.  The game works fine on the Harmony.
#17 Crispy OFFLINE
Crispy
    Star Raider
  • 65 posts
Posted Mon Mar 14, 2016 11:06 PM
Looks good and works well on my hardware. At first I was going to suggest adding some inertia to the steering, but then when the game speed ramped up, I decided that it was better without it.
#18 sramirez2008 OFFLINE
sramirez2008
  • 2,893 posts
  • Stella Foreva
Posted Mon Mar 14, 2016 11:09 PM
This game has me hooked. The crash sound scares me and make me jittery.
HS save is working fine via AtariVox.
Definitely has that "one more try" appeal. - Thanks.
Did I say, one more try? Gosh, 30,050 is hard to beat. Hats off to chavert!
#19 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Wed Mar 16, 2016 9:59 AM
I'm glad you're enjoying it! Let me know if you encounter any bugs. :)
#20 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Tue Mar 29, 2016 10:32 PM
How does this label look?
#21 walaber OFFLINE
walaber
    Chopper Commander
  • 159 posts
Posted Tue Mar 29, 2016 11:20 PM
looks nice, but the brown background on a black cartridge makes it a bit bland... maybe do a much larger zoom-in on the car and focus on it instead?
#22 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Wed Mar 30, 2016 12:01 AM
Hmm... I see what you mean. How about this, then? I tried to make it look more dynamic.
Edited by Lumi, Wed Mar 30, 2016 12:13 AM.
#23 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Wed May 11, 2016 1:21 AM
As of version 1.4, I think I'm ready to call this game finished! I can't find any bugs to fix, the NTSC60 and PAL50 versions run at the same speed, and there isn't really any space left to add new features.
Unless anyone finds serious bugs, I think I can officially call this the final version!
A big thank you to everyone to helped me and offered advice and suggestions. I learned a lot, and I'm quite happy with the final product! :)
#24 Arenafoot OFFLINE
Arenafoot
  • 1,375 posts
  • videogamestores.net
Posted Wed May 11, 2016 12:25 PM
Very good game Lumi!
But for some reason, Drive v1.3 played thru Stella 4.0 will let me use my computer mouse as a controller (paddle) but not on v1.2 or v1.4.
#25 Lumi OFFLINE
Lumi
    Star Raider
  • 82 posts
Posted Thu May 12, 2016 11:12 PM
Thank you! :)
Hmm... you might need to manually switch to paddle mode. Try pressing tab while the game is running > Game Properties > Controller. Then set P0 Controller to Paddles in Left Port. Then you'll have to close the ROM and reopen it for the changes to take effect.
(Also, if you want to be able to save your high scores, set P1 Controller to AtariVox in Right Port.)
Also tagged with one or more of these keywords: homebrew, assembly, paddles
