The TI-99/4A Operating System
Operating System Monitor GPL Interpreter KSCAN ISR XML Utilities
29 replies to this topic
#1 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Sun Mar 13, 2016 10:34 AM
This project to augment and enhance the Assembly Language Code (ALC) listing of TI-99/4A’s Console ROM Operating System is largely obviated by the DX-10 Assembler ALC source code discussed below the second separator bar further down.  It appears to be the original source code.
Startup Message for this Thread—
I am in the process of attempting to enhance the annotation and instruction labelling of the ALC of the TI-99/4A’s console ROM so that I can better wend my way through the code.  My starting point is Tursi’s TI994A_CPU.asm, which he ported from Heiner Martin’s TI99/4A INTERN.  Right now, I am calling it TI994A_CPU.a99.  I will maintain an up-to-date version, serialized by date, in this post of this thread.  Please, feel free to suggest modifications, including the file name (perhaps, with only a different extension, it is too close to Tursi’s file’s name), the name of this thread and its tags—I’m flexible.
I have barely begun this effort with the file below; but, it should give you an idea of what I am trying to do:
  • I would like clarification of lines where I have the comment, “???LES???”, because I have not yet discovered why the lines are there.  [Now known from ROM-4A files below]
  • Labels and comments thus far:  Lines 1 – 111, 464, 669, 1101, 1116, 1186 – 1356, 1499, 2446 (I will not continue itemizing the changes going forward.  This is just to give you ideas.)
  • More spacing around comment lines—especially, section headings.
  • Page-number lines include the book referenced.
Attached File  TI994A_CPU_20160313.a99   117.99KB   38 downloads
Eventually, I want to extend this effort to the console GROMs; but, for now, I am limiting it to the console ROM.
...lee
Original(?) Commented Assembly Language Code (ALC)—
The following code has been modified by Yours Truly to  be successfully assembled by Corey Burr’s ASM994A assembler.  My changes are marked with “*==LES==*”.  Items I have questions about are marked with at least “???”:
ROM-4A_20160317.zip
...lee
Edited by Lee Stewart, Thu Mar 17, 2016 10:25 PM.
#2 Ksarul OFFLINE
Ksarul
  • 4,783 posts
Posted Sun Mar 13, 2016 11:40 AM
How about TI994A-CROM (for Console ROM) and then you can add files later called CGROM0, CGROM1, and CGROM2. . .
#3 Tursi OFFLINE
Tursi
  • 5,290 posts
  • HarmlessLion
Posted Sun Mar 13, 2016 2:46 PM
Filename looks fine to me :)
The DATA >0008 is used in the ROM in two places for keyboard scanning (the FCTN part of FCTN-4 and FCTN-=) and as part of the VDP address setup in GPL MOVE.
The question marks for the >001E at >0014 and >001A I couldn't find a use for. :)
#4 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,240 posts
Posted Sun Mar 13, 2016 3:55 PM
Pretty sure >1E00 is "SBZ 0".   I think I have some files that may help in this endeavor.
Edit: from the file below - debugging entry points?
SCNKEY B    @KSCAN
HX0008 DATA >0008            USED IN COC & LDCR
* ENTRY NOT KNOWN
C014   SBZ  0                 DEBUG BOARD INSTRUCTIONS
       B    @>007A
*ENTRY NOT KNOWN
C01A   SBZ  0                 DEBUG BOARD INSTRUCTIONS
       B    @>0078
Edited by InsaneMultitasker, Sun Mar 13, 2016 4:17 PM.
#5 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,240 posts
Posted Sun Mar 13, 2016 4:05 PM
The disk containing these source files is labeled with the following hand-written info:
TI-intern (ROMS-source code in DX10 Assm)
I do not recall whether I have ever posted these files before nor do I recall how I obtained the disk.  The handwriting is not my own.  I've had it in my library since the early-to-mid 90s.
#6 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Sun Mar 13, 2016 7:20 PM
Thanks for this, Tim! :-o   I have my work cut out for me, now.  I will work on assembling these to see that they produce the same binary as TI99/4A INTERN and then, I guess, I will attempt a consolidation of comments and labelling.
...lee
#7 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,240 posts
Posted Sun Mar 13, 2016 7:45 PM
...lee
Have fun! There are some comments, including a few that look like TIs storage paths, that lead me to wonder if this came from TI. In fact, it reminded me of the ti writer source code. Want another project? :).
#8 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Sun Mar 13, 2016 7:52 PM
Hah!  I think my next project will be TI Logo II in fbForth 2.0 or, possibly, an fbForth 2.0 DBMS.  Before those, I should probably update the fbForth 2.0 Manual.
...lee
#9 Ksarul OFFLINE
Ksarul
  • 4,783 posts
Posted Sun Mar 13, 2016 9:28 PM
I had fun turning the ROM-A files into a PDF tonight. I'll get to the others tomorrow.
Edited by Ksarul, Sun Mar 13, 2016 9:28 PM.
#10 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Mon Mar 14, 2016 11:08 PM
Well—I attempted to assemble the code Tim posted in post #5 above, but ASM994A just threw up! :woozy:  I am not sure why; but, I have already found some code that needs to be changed for a successful assembly with ASM994A:
  • There are a handful of “SPIN” instructions in the casette I/O routines, which must be for a macro-assembler.  They will need to be changed to “<label>  JMP  <label>”
  • There are some labels that are the same as the conditional-assembly directives used by ASM994A, such as IF, ELSE, ....  (I had trouble with those assembling fbForth.)
  • There are multiply-defined EQUates that ought to be identical, but may not be so because of some assembly error.  The assembler ought to be OK with them.
  • I need to check the RORG and AORG directives because ASM994A is a little hinky where they are concerned.
Anybody wanting to look over my shoulder, feel free.
...lee
#11 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,240 posts
Posted Mon Mar 14, 2016 11:13 PM
Is there such a beast as a dx-10 assembler? I find references to the ti-990 when I look up dx10.
#12 Ksarul OFFLINE
Ksarul
  • 4,783 posts
Posted Mon Mar 14, 2016 11:20 PM
I have the manuals for the DX-10 Assembler from a recent purchase. . .they are also available in the TI-990 portion of Bitsavers.
#13 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Wed Mar 16, 2016 7:58 AM
I’m getting there.  It appears that TI (if that is where the DX10 source files are from) assembled these in 3 separate operations to produce an object file for each major segment of the ROM:
  1. T.I. 99/4A GRAPHICS LANGUAGE INTERPRETER  (program identifier: GPLINT)
  2. T.I. 99/4A FLOATING POINT & CASSETTE      (program identifier: FLTPT)
  3. T.I. 99/4A BASIC INTERPRETER              (program identifier: BASICI)
Unfortunately, during this process, they reused about 7 labels that cause conflict when the source code is all assembled to a single object file. At least, now, I have a listing that shows most of what I need to fix.  My first attempt had left me guessing because the assembler had aborted without producing a listing!  It shouldn’t be long, now.
...lee
#14 Willsy OFFLINE
Willsy
  • 3,079 posts
Posted Wed Mar 16, 2016 10:37 AM
...lee
Is there any reason why you have to assemble it as a single file? Why not leave it as three files, as TI did?
#15 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Wed Mar 16, 2016 10:45 AM
Success!!  :-o  :lolblue:
All of my mods are marked with “*==LES==*”.  I combined the fourteen, numbered, source-code files into three ‘A’, ‘B’ and ‘C’ files.  I may eventually consolidate them into a single source file, as with the TI99/4A-INTERN-derived source file.
I will probably remove the cross-module-reference EQUates just as I did the DEFs because they are superfluous when assembled as a single object file.  I am not sure what I should do with the other duplicate EQUates.  They do serve to show which module (GPL Interpreter, Floating Point & Casette or Basic Interpreter) requires them.  I am inclined to put all EQUates at the beginning of the first file regardless of which module uses them.
The following ZIP file contains ROM-4A-a.a99, ROM-4A-b.a99, ROM-4A-c.a99 and ROM-4A.lst:
Attached File  ROM-4A_20160316.zip   114.7KB   16 downloads
...lee
#16 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Wed Mar 16, 2016 11:19 AM
There are many references to “NUD” in the TI source code for the Basic Interpreter portion of the ROM.  Heiner Martin (“Add NUD table address”) and Thierry Nouspikel (“NUD table for assembly language routines”) use the term, as well.  Does anyone know what it stands for?
...lee
#17 Stuart OFFLINE
Stuart
    Dragonstomper
  • 792 posts
Posted Wed Mar 16, 2016 12:42 PM
...lee
"Not usually dangerous"
#18 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,240 posts
Posted Wed Mar 16, 2016 2:32 PM
...lee
Perhaps the segments were worked on concurrently by different teams.  Have you noticed any differences between this and the TI Intern compiled sources?
#19 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Wed Mar 16, 2016 3:15 PM
The binaries are identical.  The ALC has register references that use the ‘R’ designation, which is always easier to follow than just register numbers.  It is also rich with labels and comments that appear to be by the original programmers, which makes this code much easier to wade through.  Heiner Martin did a remarkable job of commenting the disassembled code, but the lack of mnemonic labels and comments from divining the ALC’s function, along with number-only register references, are necessarily less desirable.
...lee
#20 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Wed Mar 16, 2016 11:35 PM
Eventually, the files in ROM-4A_20160316.zip of post #15 above will find their way to post #1 because they assemble to the same code as the file that is currently there, but are easier to follow.
Right now, I just wanted to give a few interesting tidbits gleaned from my perusal of the ROM-4A files.  Though many of us know that there are odd references to the console ROM that harvest values from code that is actually part of instruction code, it is kind of cool to see it documented in the comments of the original(?) programmers.  There may be more labelled some other way, but I have found five such locations commented with “NASTY”.    :twisted:  They are
  • C025
  • C030
  • HX20
  • HX06
  • HX0300
I should also note that I found one and only one mistake in the code.  It is the EQUate for SAVVDP in the code for the Basic Interpreter (currently, ROM-4A-c.a99).  It evaluates to >83D8 rather than the correct >83D4 from the code for the GPL Interpreter (currently, ROM-4A-a.a99).  I guess the two different calculations support the notion that different programming teams may have worked on the ALC.  The first instance has it as
SAVVDP EQU  PAD+>D4    <---PAD + >D4 = >8300 + >D4 = >83D4
and the second, as
SAVVDP EQU  WKSC+R12+R12    <---WKSC + R12 + R12 = >83C0 + >0C + >0C = >83D8
which, of course, conflicts with the previous value.  The following would correct it:
SAVVDP EQU  WKSC+R10+R10    <---WKSC + R10 + R10 = >83C0 + >0A  + >0A = >83D4
...lee
#21 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Thu Mar 17, 2016 11:21 AM
To avoid unnecessary clutter (at least, for now), I decided to remove all of my changes to the ROM ALC except for those that are absolutely necessary
  • for successfully assembling the three “modules” to a single object file,
  • to avoid conflicts with the ASM994A assembler,
  • to inline the SPIN macro (because I don't know how to define macros for ASM994A or if it is even possible—for that I would need to start using ralphb’s xas99) and
  • to remove the single error in the third module (mentioned in my last post)
Here is the current set of files:
Attached File  ROM-4A_20160317.zip   114.88KB   36 downloads
...lee
#22 Asmusr OFFLINE
Asmusr
  • 2,892 posts
Posted Thu Mar 17, 2016 12:28 PM
Which tool do you use to turn the object file into a binary file?
#23 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Thu Mar 17, 2016 1:35 PM
I use Tursi’s tiobj2bin, which, I’m guessing, you already have and probably know it will only convert absolute code with no external references.
...lee
[Edits in this color]
Edited by Lee Stewart, Thu Mar 17, 2016 1:43 PM.
#24 Asmusr OFFLINE
Asmusr
  • 2,892 posts
Posted Thu Mar 17, 2016 2:09 PM
...lee
No I wasn't aware of that. Thank you.
#25 Lee Stewart ONLINE
Lee Stewart
  • 3,766 posts
Posted Fri Mar 18, 2016 8:10 AM
Oops! :woozy:  Here’s the context that led me astray: post #928 of “Classic99 Updates”.
Thank you.
You’re most welcome.
...lee
Also tagged with one or more of these keywords: Operating System, Monitor, GPL Interpreter, KSCAN, ISR, XML Utilities
