Dennis90 Posted March 15, 2016 Share Posted March 15, 2016 I was wondering how you really do to double 2k ROMs if you gonna burn them into 2732 EPROMs? Cus i think you need to do that if I am right? I have a TL866 MiniPro programmer and I'm not sure how I should do that really, like what settings you press or so, anybody here that has experience with that programmer or something similar? And if you want to burn 4k ROMs to 2732 EPROMs I guess you just burn them as normal without change any settings or something if i am right? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted March 15, 2016 Share Posted March 15, 2016 "Open" the file a second time, but this time change the "to buffer start addr" in the window that appears to 800 (if I've got that correct = 2K). Make sure the selection at the bottom of the window (clear buffer when loading the file) is set to "Disable". Quote Link to comment Share on other sites More sharing options...
Dennis90 Posted March 15, 2016 Author Share Posted March 15, 2016 Ok! Think i know how to do it then! And just to make sure, this should be the right settings?First time opening the file: Second time opening the file: Quote Link to comment Share on other sites More sharing options...
+5-11under Posted March 15, 2016 Share Posted March 15, 2016 Yep, I think that should do it. Check the listing afterward to see that the lower half is the same as the upper half. You can save you doubled results in a new file, too, if you want to re-use it later. Quote Link to comment Share on other sites More sharing options...
Dennis90 Posted March 15, 2016 Author Share Posted March 15, 2016 Ok! Thanks for your help! Quote Link to comment Share on other sites More sharing options...
