KidGameR186496 Posted April 1, 2016 Share Posted April 1, 2016 Hi, i have recently installed the virtual jaguar emulator,but i don't know how i have to insert the ROMs or which folder i need to put them on. Can you guys help me? Quote Link to comment Share on other sites More sharing options...
Willard Posted April 1, 2016 Share Posted April 1, 2016 select Jaguar in the menu bar, then configure. it should allow you to set the path for where you place the games. 2 Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted April 1, 2016 Author Share Posted April 1, 2016 I'm trying but i can't,i'm not a expert when it comes to emulation on PC Quote Link to comment Share on other sites More sharing options...
Willard Posted April 2, 2016 Share Posted April 2, 2016 Once in the configure screen the path goes here: You can find the path to your software folder (in windows) by right clicking the folder and selecting properties Then copy the location and paste it into the virtual jaguar configure screen make sure to add the software folder in the path (put \software at the end) 2 Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted April 2, 2016 Author Share Posted April 2, 2016 Thanks Quote Link to comment Share on other sites More sharing options...
+LS650 Posted April 2, 2016 Share Posted April 2, 2016 I haven't messed with VJ for a couple of years at least. At that time I found it was not that great, either for compatibility or for performance.... Has VJ improved much since then? 1 Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted April 2, 2016 Author Share Posted April 2, 2016 now i'm dealing with another problem,the controller response from the keyboard just flat out doesn't work,what do i need to do to resolve the issue Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted April 2, 2016 Author Share Posted April 2, 2016 now i'm dealing with another problem,the controller response from the keyboard just flat out doesn't work,what do i need to do to resolve the issue i found out the problem,when i map the keys,suddenly they don't work,what should i do now? Quote Link to comment Share on other sites More sharing options...
Willard Posted April 2, 2016 Share Posted April 2, 2016 (edited) I haven't messed with VJ for a couple of years at least. At that time I found it was not that great, either for compatibility or for performance.... Has VJ improved much since then? I personally use it only for frame grabs. I have not found it to be all that great for playing games either. i found out the problem,when i map the keys,suddenly they don't work,what should i do now? I think somebody around here is still working on it, maybe he can explain. I had it working once but wiped my computer and can't be bothered to figure it out again. I just used an older version for my purposes. All I can say is that it is possible Edited April 2, 2016 by Willard 1 Quote Link to comment Share on other sites More sharing options...
Shamus Posted April 3, 2016 Share Posted April 3, 2016 What version are you using? If it's an official point release, you might want to try using one of the latest GIT snapshots: http://outrage.the-crow.co.uk/builds http://virtualjaguar.kicks-ass.net/builds 3 Quote Link to comment Share on other sites More sharing options...
Willard Posted April 3, 2016 Share Posted April 3, 2016 (edited) I have tried the versions from your second link (20151002). The key mapping seems a little bugged out. Profiles that I delete re-appear after I close and re-open the config pane. None of the configurations that I make seem to take effect. The default configuration doesn't work because only like 3 keys are actually responsive. When I create a new profile and choose it then exit the config screen, it is no longer selected when I re-open the config screen. I've had similar issues and gotten it working before. But recently re-installed it to take some screen grabs and the same thing happened this time didn't feel like figuring it out :/ The old versions before it was picked back up work fine. Maybe it's a computer hardware thing or something. Edited April 3, 2016 by Willard Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted April 3, 2016 Author Share Posted April 3, 2016 What version are you using? If it's an official point release, you might want to try using one of the latest GIT snapshots: http://outrage.the-crow.co.uk/builds http://virtualjaguar.kicks-ass.net/builds I'm using version 2.1.2 Quote Link to comment Share on other sites More sharing options...
