TI-99/4A Megademo
178 replies to this topic
#51 orbitaldecay OFFLINE
orbitaldecay
    Space Invader
  • 41 posts
Posted Mon May 2, 2016 6:09 PM
I think it's been covered, but just to be clear, the bank switching captures the address bits when you write to cartridge space (so it doesn't matter if you write a value or clear it). The least significant bit is ignored, because every access becomes two 8-bit accesses. Classic99's naming convention is documented in the PDF manual shipped with the emulator, although it doesn't go into detail on the banking itself.
Just to help with the ini, though, when you are specifying type 8 or type 9 in the INI, you actually are providing addresses in EPROM space rather than TI memory space. So your one example should have worked like this:
[usercart0]
; *** Lena
name="Lena"
; this would become the first bank on the EPROM
rom0=8|0000|2000|mods\lenac.bin
; this would be the second
rom1=8|2000|2000|mods\lenad.bin
; this would be the third
rom2=8|4000|2000|mods\lenae.bin
And Classic99 would end up with a 32k EPROM (rounding up to the next power of 2) with data in the first 24k and the last 8k unused. Since it's type 8 for non-inverted, >6000 would select the '0000' bank, >6002 the '2000' bank, >6004 the '4000' bank, and >6006 the empty '6000' bank.
Sorry it's so obtuse... it's a format that has grown too slowly over far too long a time. :)
I took a quick look at the Lena GIF too.. I got good results with the default options in Convert9918A, but the one change I'd recommend is change the "Fill Mode" to "Middle". This makes it zoom the image up to fill the screen and drop the edges ('left/top' and 'bottom/right' crop based on the listed position instead of the middle of the image). Having just a few extra pixels to work with makes a big difference. :)
Thanks for the clarification, Tursi. I also managed to get better results with the Lena pic by tweaking the Luma and turning on the histogram.
Yep, something like this.  Either that, or use 8K of the 32K for the actual control routines (which aren't overwritten) and then use the other upper 16K for data in/out of the cart.  We've proven that copy routines from ROM to RAM are pretty darn fast by implementing the "copy to 32K and run" cartridges.
I know it gets dicey when copying into lower 8K due to other stuff that's expected to be living there, but you might be able to get away with that as well if you can not stomp on whatever's expected to be there.
So, bottom line, something like:
Lower 8K:  Maybe some character sets and other static stuff?
8K >A000, Control program
8K >C000->FFFE, data being copied from cart
Yeah, that's pretty good thinking. Right now I'm toying with keeping the control code and various common routines in lower 8k (like the music player -- there is also plenty of space leftover for character sets and what not) and then keeping the currently playing song in the upper 24k. This will make it easy to have one song play over multiple screens (and it's pretty much the only place a song will fit contiguously). Depending on the song, there will probably be some memory leftover for various screens to tinker with.
Edit: Also, Tursi, any clue why the following code isn't working when I have a psgmod 2.04 example song loaded at >A000?
       LI R0,>A000
       BL @SGPLAY
SPIN   LIMI 2
       LIMI 0
       JMP SPIN
Edited by orbitaldecay, Mon May 2, 2016 6:11 PM.
#52 Tursi OFFLINE
Tursi
  • 4,967 posts
  • HarmlessLion
Posted Mon May 2, 2016 11:20 PM
SGPLAY is the PSGMod player, which I haven't actually looked at for many years. ;)
I downloaded and took a peek, though, and it looks like it should work. Do you have interrupts enabled in the VDP? Is SGTICK getting called at all?
#53 orbitaldecay OFFLINE
orbitaldecay
    Space Invader
  • 41 posts
Posted Tue May 3, 2016 12:54 PM
For anyone else who may be wondering, I was making two mistakes:
1. I was using a PSGMOD file when I should have been using an EPSGMOD file (there is a difference)
2. VDP register one didn't have interrupts enabled!
#54 xjas OFFLINE
xjas
    Space Invader
  • 20 posts
Posted Tue May 3, 2016 4:58 PM
Hey all, time to dust off my account here. I'm a demoscene musician and was Orbitaldecay's collaborator on this demo among other things; I'm one of the poeple he mentioned in the first post about discussing doing something on the TI. ;) I haven't gone through the whole thread yet but it looks like some great ideas here, will read through better when I have more time.
FYI I did some musical experiments last year with DefleMask in VGM format. It's a great little tracker and I'd love to work in that if possible but could easily switch to something else if easier. I also call myself an artist and have done pixel gfx / ASCII/ANSI stuff for various projects before so I'm happy to get involved on the art side of things too.
For hardware, I have a badly under-used complete "dev" system including a silver console, RS232-type NanoPEB, several cart PCBs including a 512kB Ubergrom board, an EPROM burner, and an original E/A cart for running stuff. So there's that!
The TI isn't the most graphical or musical oldschool system out there but I really think we can make something cool on it. Should be fun. :D
Edited by xjas, Tue May 3, 2016 5:08 PM.
#55 orbitaldecay OFFLINE
orbitaldecay
    Space Invader
  • 41 posts
Posted Wed May 4, 2016 11:16 PM
Pretty much all discussion of this project has moved over to the (very active) slack page at https://ti-994megademo.slack.com. If you're interested in contributing art, music, or code then shoot me an e-mail at orbitaldecay@gmail.com and I'll get you hooked up with a login.
Edited by orbitaldecay, Wed May 4, 2016 11:16 PM.
#56 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,874 posts
Posted Thu May 5, 2016 8:54 AM
Is the site open for those who are interested in reading the discussions?
#57 orbitaldecay OFFLINE
orbitaldecay
    Space Invader
  • 41 posts
Posted Thu May 5, 2016 9:12 AM
The site cannot be accessed without an invitation. The unspoken demoscene rule is to remain quiet about what we're working on until it is finished for maximum wow factor :) Code is being actively developed at this time and I don't want it distributed (yet). But you can expect some screen shots to get posted here as progress is made.
Edited by orbitaldecay, Thu May 5, 2016 9:13 AM.
#58 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,874 posts
Posted Thu May 5, 2016 10:33 AM
That makes sense ;)   With a small community, learning how things work is as important as the wow factor, so I hope some of the tricks and code can be shared after the fact to help raise the bar for us all ;)
#59 orbitaldecay OFFLINE
orbitaldecay
    Space Invader
  • 41 posts
Posted Thu May 5, 2016 11:21 AM
I will certainly be happy to share the code I have written once it is released, and I'm sure Asmusr will be too. So you can expect to read up on some new tricks once we have this thing out in the wild :)
#60 OLD CS1 OFFLINE
OLD CS1
  • 4,588 posts
  • Technology Samurai
Posted Thu May 5, 2016 1:12 PM
Rules 1 and 2, eh? ;)
#61 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Fri Jan 6, 2017 3:17 PM
I'm very pleased to announce that the TI-99/4A Megademo is ready and will be released at the end of this month.
#62 RamonB5^dSr OFFLINE
RamonB5^dSr
    Combat Commando
  • 3 posts
Posted Sat Jan 7, 2017 4:09 AM
I have seen it evolve and am hyped to release it to the public. Only few more days to wait.... Great work by all involved !!!   :thumbsup:
#63 sometimes99er OFFLINE
sometimes99er
  • 4,083 posts
Posted Sat Jan 7, 2017 4:47 AM
Nice. Looking forward to seeing it.
What are hardware specifications and/or requirements ?
#64 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sat Jan 7, 2017 5:51 AM
32K RAM is required. There is a bit of speech that you will only hear if you have a speech synth attached. The demo will be released as both a 180K disk image (stuffed to the last sector) and a 512K cart image. The cart is recommended since it eliminates the loading time, but it still requires 32K RAM. The disk has two loaders: one that loads between effects, which is kind of disruptive - especially on slow floppy disks, and another that loads everything into SAMS at the beginning and then runs as smoothly as the cart version. Using the latter requires a SAMS card with at least 512K.
Edit: Regarding emulation, it runs in MAME/MESS, JS99er.net and the latest version of Classic99. The requirement is that the emulator must allow code to be executed while the screen is drawn.
#65 --- Ω --- OFFLINE
--- Ω ---
    오메가
  • 11,129 posts
Posted Sat Jan 7, 2017 7:26 AM
* I'm available for early release BETA testing!  ;)
#66 Ksarul OFFLINE
Ksarul
  • 4,354 posts
Posted Sat Jan 7, 2017 9:07 AM
Ooooohh! More SAMS-aware software!  :)
#67 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sun Jan 29, 2017 3:48 AM
The Megademo "Don't mess with Texas" has just been participating in the Synchrony 2017 demo compo. The result of the compo is, at the time of writing, a bit unclear to me. :-)
http://www.pouet.net...php?which=68783
The attached zip archive contains the files and instructions required run the demo on emulation or real hardware. For the best experience, we recommend either the ROM or the SAMS option.
Enjoy!
#68 sometimes99er OFFLINE
sometimes99er
  • 4,083 posts
Posted Sun Jan 29, 2017 4:17 AM
Love it !   :thumbsup:
#69 --- Ω --- OFFLINE
--- Ω ---
    오메가
  • 11,129 posts
Posted Sun Jan 29, 2017 5:24 AM
I wonder how many expansion systems and SAMS cards would have sold back in the day if we had a demo like this then?
If only, and what could have been.  I agree very impressive.
#70 fabrice montupet OFFLINE
fabrice montupet
    Chopper Commander
  • 215 posts
Posted Sun Jan 29, 2017 6:32 AM
The TI-99/4A as we have never seen!
Congratulation to all the demo team, it is very impressive!
#71 Lee Stewart OFFLINE
Lee Stewart
  • 3,554 posts
Posted Sun Jan 29, 2017 6:45 AM
Very nice, indeed!  :-o
...lee
#72 mizapf OFFLINE
mizapf
  • 2,893 posts
Posted Sun Jan 29, 2017 7:40 AM
Please note that you need a memory expansion in MAME; either you have to turn on the internal 32K mod (OSD menu), or you have to insert a 32K card in the PEB. By default, MAME starts the unexpanded console.
Very cool work, indeed.
Or, for my lack of appropriate words to reflect my emotions, using my mother tongue, I'd say:
Sehr, sehr geil.
Edited by mizapf, Sun Jan 29, 2017 7:45 AM.
#73 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sun Jan 29, 2017 8:45 AM
So, it appears we won the compo.  :) According the jmph who participated in person there were three demos in the oldskool category, one wasn't shown and we beat the other one fair and square.
#74 ti99iuc ONLINE
ti99iuc
  • 1,278 posts
Posted Sun Jan 29, 2017 9:17 AM
Really Thanks !!!!  This is a lovely DEMO ! i always dreamed to see something similar on our little but BIG computer.
Thanks Guys !! :D
it is spectacular to see and listen !
:love:  :lust:  :lust:  :-o  :-o  :lust:  :lust:  :love:
#75 Lee Stewart OFFLINE
Lee Stewart
  • 3,554 posts
Posted Sun Jan 29, 2017 9:41 AM
Congratulations!!   :thumbsup:  :thumbsup:  :thumbsup:
...lee
