How many mods will fit in a 600XL?
u1mb vbxe transkey pokey stereo 600XL u-switch tk-ii rapidus
25 replies to this topic
#1 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 454 posts
Posted Thu May 19, 2016 1:06 PM
How many mods has someone actually squeezed into a 600XL?  I love the small size, but realistically I know there is limited real estate inside.  It would be great to have everything: U1MB, VBXE, stereo pokey board, u-switch, TK-II or AKI, Rapidus, and I'd have to do the 64k and a/v mods.
Is it doable or do I need to play it safe with a larger model?
#2 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Thu May 19, 2016 1:27 PM
I have Ultimate 1MB, VBXE, Stereo Pokey, and U-Switch in a 600XL. The secret to getting Stereo Pokey in there is to plug U1MB into the BASIC socket, but even then it's a fairly tight squeeze. I'm not sure if it would be physically possible to fit Rapidus in there as well, but that has as much to do with the obstruction from Stereo Pokey as it does the 600XL's size. I'm not sure which lateral direction Adaptus (the forthcoming XL Rapidus adapter) will throw the board. TK-II and AKI are going to be problematic alongside Stereo Pokey.
#3 mytek OFFLINE
mytek
  • 3,220 posts
Posted Thu May 19, 2016 6:20 PM
Two different ways exist to put a PS/2 keyboard adapter in there. The easiest would be to use Steve Carden's KRH-II which is a small solder-in solution. Another option would be to use a TK-II-XEGS-S and either mount it internally with a D-Sub15 ribbon cable soldered to Pokey, or if you don't mind having a small interface board plugged in from outside, just wire in a D-Sub15 panel mount jack mounted wherever you can fit it on the 600XL's enclosure. In fact with that last option you could just plug in an XEGS keyboard. This all assumes that you would want a remote keyboard.
- Michael
Edited by mytekcontrols, Thu May 19, 2016 6:21 PM.
#4 Marius OFFLINE
Marius
  • 4,803 posts
Posted Fri May 20, 2016 12:24 AM
Sorry for my totally off topic yell:
The 600xl absolutely kicks ass!!!
I love it. Mine has the Hias 576k sram upgrade, a built in rtc, and dual os (stock and mybios). I fixed video output by removing one single disc capacitor. This is one of my most favorite atari 8bit machines.
#5 mimo OFFLINE
mimo
    Preppie!
  • 6,821 posts
  • It's easy living in a bubble
Posted Sat May 21, 2016 2:05 AM
my old PAL 600xl had the following
Internal 64k
Ultimate 1meg RAM upgrade (1 meg RAM, spartados x, real time clock, multiple OS)
Stereo pokey
Covox
Internal sio2pc
Ps2 keyboard adaptor
Vbxe2
It was a LOT of work to get it all to fit, quite a few components had to be moved underneath the motherboard.
Not for the feint hearted
And I never should have sold it
#6 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Sat May 21, 2016 2:59 AM
my old PAL 600xl had the following...
Did that ever come to my house? It sounds familiar.
Edited by flashjazzcat, Sat May 21, 2016 2:59 AM.
#7 mimo OFFLINE
mimo
    Preppie!
  • 6,821 posts
Posted Sat May 21, 2016 3:28 AM
It did indeed. I think the vbxe had a problem.
If you remember it was pretty full. Not sure you could get much more in there
#8 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Sat May 21, 2016 3:33 AM
Yep: very cute machine, though. Only time I saw a Candle stereo board in the flesh. :)
#9 Jinks OFFLINE
Jinks
  • 4,591 posts
Posted Sat May 21, 2016 7:16 PM
Mine has 64kb ram, u1mb board, internal sio2bt, svideo and composite outs. I never want to open it ever...
#10 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 756 posts
Posted Wed May 25, 2016 1:44 PM
Sure. There´s a lot space! :-D
Look, this is one modded 600XL I´m working on for an ABBUC member. Ultimate 1 MB, VBXE, Stereo. Of course already 64 KB main memory upgrade, S-Video Upgrade. The stereo PCB is my own and includes an SIO2PC-USB, for that I will install an USB jack over the SIO jack. When I´m going totally nuts, I will try also to include a SIO2SD using one of the very small displays used by Panos for the external Micro-SIO2SD.
As FJC already told, you´ve to use BASIC ROM´s place. I replace the 24 pin socket, solder a 28 pin socket into. Also you´ve the change the both "jumperfields" (look at the red jumpers upper right corner in picture 2) to the opposite places.
And, it´s a good idea to remove the plastic mylar cable from keyboard to the adapter PCB used in the 600 XL and use some standard ribbon cable.
Jurgen
#11 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Aug 19, 2017 6:14 AM
Jurgen
Hey Jurgen do you have a picture of how you did that ?
Edited by Level42, Sat Aug 19, 2017 6:14 AM.
#12 ClausB OFFLINE
ClausB
  • 1,578 posts
Posted Sat Aug 19, 2017 2:54 PM
Let's find out. One, two-who, three, crunch! Three.
#13 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 756 posts
Posted Mon Aug 21, 2017 12:53 AM
Sorry, not now. The machine shown in the picture was made for an ABBUC member. I didn´t make photos from that, but in the next weeks a new machine must be optimised, then I will make photos from that.
Also I have planned a little adapter PCB for using standard IDC connectors. Be patient :)
#14 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Sep 4, 2017 5:10 PM
Since I really don't like unnecessary long cables and space is of course always an issue in a 600XL, I moved the IDC connectors of my U1MB and cut the cables short. Much tidier IMHO.
Delicate job though, not for the clumsy :)
#15 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Sep 4, 2017 5:13 PM
I ordered decent IDC connectors for the PCB following Jazflashcat's suggestion, that way the U1MB will fit over the PBI. Also waiting for mounting studs to fix the U1MB but everything fits fine already.
Edited by Level42, Mon Sep 4, 2017 5:13 PM.
#16 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Wed Sep 6, 2017 2:31 PM
So today I received the IDC connectors.
I couldn't find a 30 pin version on RS's website so I sent them an email to ask if they had it anyway.....so they suggested the one on the right. From the picture on their website i couldn't see how exactly it was like.....clear enough it's not the same.....and I don't want to use it really. This would permentaly fix the ribboncable to the U1MB board. Although.........it would be a lot lower in profile than the push on connector.
Because....with the "type 4" keyboard I have....the height AND the stereo Pokey and U-switch PCBs the height IS becoming an issue....
Edited by Level42, Wed Sep 6, 2017 2:32 PM.
#17 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Wed Sep 6, 2017 4:38 PM
I think I left off the strain relief clips on the 600XL.
#18 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Sep 23, 2017 4:06 PM
Yeah, I did the same now and it fits....JUST.....
I am actually now thinking about installing that one on the right. I don't really need it, but it WILL lower the profile of the PCB immensely at the cost of it not being removable.....but you can always remove the PCB from the IC socket connectors.
All in all....the U1MB should stay inside anyway....so I might get another one just like that for the smaller connector on the left....I'm not too keen about leaving the relief clips off.....
But since I received the plastic supports I mounted the PCB and it fits JUST right.
Oh....and I just finally PayPalled you a small amount of money for all your hard work on the U1MB firmware etc....thanks Jon !
#19 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Sun Sep 24, 2017 6:06 AM
Many thanks for that! It is more helpful right now than you could possibly realise.
#20 Gunstar ONLINE
Gunstar
    Gunstar
  • 10,051 posts
Posted Sun Sep 24, 2017 7:59 AM
You did this with a 1200XL too, right? If so, What Wxx jumper positions do you use for OS in the BASIC position on a 1200XL? Can you use the OS slot for another rom? (one rom chip in a socket can fit under my stereo board) Wouldn't it just be a matter of reverse-OPTION key function once the jumpers are changed? Or is there more to it?
I have a piggy-back stereo job i did myself due to the same problem with my MetalGuy66 stereo board and my Atarimax Warp OS board. \at first I tried the stereo board on a ribbon cable, but that was problematic.
Edited by Gunstar, Sun Sep 24, 2017 8:07 AM.
#21 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Sun Sep 24, 2017 9:42 AM
Just had a look and on the loaded 1200XL, only W11 is jumpered. Whether this works without U1MB I don't know, but since U1MB is present, the second ROM slot is completely superfluous anyway. With the correct jumpers (and no U1MB), you can certainly put any 8K ROM you like (or BASIC) in the other slot. You'd use the jumper positions described in the AtariMax 32-in-1 instructions for the 1200XL in that case (the board comes with BASIC on an EPROM for the second socket).
#22 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Wed Sep 27, 2017 5:31 AM
Although I managed to close the "lid" of my 600XL I felt it was still touching the keyboard or just the case......so I decided to install that ultra low profile connector on my U1MB. This was advised to me incorrectly by RSonline as a connector for a ribbon cable but it turned out to be for direct connecting a ribbon to a PCB....without a way to remove it from the PCB.
This got me thinking though as, especially the left connector, is still sitting just too high....i already removed the strain relief but mmm...it looks like I'm going to do this on the left connector too....
The only issue with this is you have to be very careful when tightening the connector....I put a piece of cardboard under the PCB before abusing my pliers to install the ribbon but even so the solder-ends bent a little bit either way...check for any shorts if you do this....
Also of,course, the ribbons will now be fixed to the PCB, but ......where would it need to go.....if you really need to remove it you can still remove the connectors to the IC sockets.
Now need to find a 20 pin version of this connecto....
#23 flashjazzcat ONLINE
flashjazzcat
  • 14,328 posts
Posted Wed Sep 27, 2017 8:36 AM
Where have you mounted the board exactly?
EDIT: Ah - I see from the photos the issue with dual Pokey clearance. ;)
Edited by flashjazzcat, Wed Sep 27, 2017 8:36 AM.
#24 MrFish OFFLINE
MrFish
  • 5,365 posts
Posted Wed Sep 27, 2017 8:52 AM
First time I opened this topic today and I was thinking exactly the same thing when I read the topic title.
Shows what era we're from...
#25 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Wed Sep 27, 2017 3:26 PM
Crap.
I think I somehow killed my U1MB.....although I don't get it.
Getting a red screen ever since I replaced that connector......arghhh
I swapped all large chips, even the RAM....i even installed some header pins for the ROM socket selection jumpers so I could go back to the original OS ROM socket......installed the old OS ROM and sure enough the machine works just fine....
Hook up the U1MB to that socket....RED screen.
I checked all solderings of the connector....even beeped out the traces to the large chip on the back of the PCB....
See pics......I kept scratching my head if I maybe should have run the ribbon cable from the other side but my brain tells me that could not matter.....???
Also tagged with one or more of these keywords: u1mb, vbxe, transkey, pokey, stereo, 600XL, u-switch, tk-ii, rapidus
